Page 278 of 280 FirstFirst ... 178228253268269270271272273274275276277278279280 LastLast
Results 6,926 to 6,950 of 6981
Thread: Butters project GO-FAST (LOUNGE STYLE)
  1. #6926
    NY
    skateboard
    Quote Originally Posted by M-technik-3 View Post
    Wow even this thread has nearly died. Happy Holiday's New England
    Korrekt
    ― George Orwell
  2. #6927
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Attachment 642955Many sort of hibernate during the cold dark days of winter. I am hoping to get my shop heater running this weekend. It’s mounted and exhaust is plumbed but I still have to do the gas line. Luckily in the fall I put the AC in the wall and it has a built in 12k heater that can keep the room at 60F.
  3. #6928
    NY
    skateboard
    Awesome Phil
    ― George Orwell
  4. #6929
    Jul 2011
    Dell Rapids, SD
    2-97 M3 sedan, 2015 STI
    Just mind blowing!
    THE TIME DRAWS NEAR!
  5. #6930
    NY
    skateboard
    Giving this place a bump since its a bit dusty in here. Is Monica on break?
    ― George Orwell
  6. #6931
    Jun 2005
    New England
    I saw Butters about 10 days ago and don’t think he has started his turbo E36 yet this year. I have not driven mine since March. Waiting on an 80lb tune and also need to finish up my GS6-53 swap. Maybe August. Different priorities lately. I think my wife’s E61 535xi wagon needs new turbos so the E36 must come off the lift soon. It has been resting 7 feet in the air for months.
  7. #6932
    NY
    skateboard
    My ever long wait for my e30 m3 has caused me to make an impulse purchase of another e36 m3. This time an obd2 Texas rust free example.
    ― George Orwell
  8. #6933
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Yea Butters is a busy guy. Right now I believe he's in the process of tearing apart his kitchen and doing it over. As for my car it has about 2000 miles on the new engine we put together and the new setup. Only been able to make it to the track 2 times last time being like a 90 degree day which the trans and clutch hated. Lol at around 14-15 psi so far I've gotten a 11.7 @ 122 with only a 1.8 60'. We're thinking my slave cylinder is failing so I have a new one ready to go with the rogue adjustable rod. Once that's done we'll hopefully be back at the track with mine and Greg's car.
    Sent from my SM-A505U using Tapatalk
    PTE6262 .63 A/R, Stock S52, Cutring/Copper Spacer/Arp Studs Combo, Water Methanol Injected
    10.9@131mph. #AngerMotorsports
  9. #6934
    Jun 2005
    New England
    Once you are up to 22 psi, the turbo will wake up and you will be beating last year’s trap speed. Your ET is already great so that will be harder to improve.
    GG needs a turbo kit for his E36.
  10. #6935
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    I think with the CAE in the car now I can improve my e.t. that 10.9 was with a 1.8 60'. I've gotten it down to 1.6 before. With more trap + a lower 60' it'll be interesting to see where it ends up. My goal is mid 10s at least. The car is also sub 3000 lbs now.
  11. #6936
    NY
    skateboard
    Send it over I’ll take freebies ;-)
    ― George Orwell
  12. #6937
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Hey Phil, btw what do you adjust the Rogue adjustable slave rod to in the slave cylinder in terms of length. I know they go from 85mm to 95mm. I'm hoping that's the only issue and it didn't cause me to mess up a brand new twin disc.
  13. #6938
    Jun 2005
    New England
    I am not using the Rogue pin.
  14. #6939
    Manchester, N.H.
    96 332IS 6466 turbo
    I mean.... 😘
  15. #6940
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
  16. #6941
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
  17. #6942
    NY
    skateboard
    Hrmmmiii
    ― George Orwell
  18. #6943
    NY
    skateboard
    Where’s the coffee?
    ― George Orwell
  19. #6944
    Jun 2005
    New England
    No one has been very active. Mod Addict ran a 10.1 or something like that at 145mph and E36Myelo ran very high 10s at a little over 130 a couple of weeks ago. Butters has barely driven his car this year. He mostly drives a WRX wagon. I finally wrapped up the loose ends on my GS6-53 swap, but then the car would not start. Butters came over before I crushed the car and we swapped in his ECU and it fired right up. Turned out the new tune for 60 lb injectors did away with the previous ews delete. We aligned the ews and it fired right up. Now I have to break in the twin disk ceramic clutch and get used to the late and high release. Probably everyone will go into hibernation in 2 months.
  20. #6945
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Good to see you got that worked out. That program came in handy for me too. Lol such a simple little program can decide whether a car works or not. Yes we went to the track a few weeks ago and mod addict ran a 10.0 I believe spinning a bunch. He did trap his new PB of 144 mph though. I went 10.9 @ 130 on around 18 psi of boost with a crappy 1.8 60'. This past weekend at an IFO event I wanted to turn the car up and run a lot more boost and see if I can go a low 10 at higher than 135 but ended up dumping the clutch accidentally at the light at like 5500 rpm lol. The axle broke somewhere and I towed the car home. I'll be taking it out this weekend hopefully so we can see what broke and hopefully fix it quick. I was matched up against a GTR that was running 10.7-10.8 all day long so I knew I had to tree him because he'd have a better 60' then me. I had turned my boost controller up to 70% duty cycle right before that pass. The 130 mph pass was at 40% to put that into perspective. The issues I was having before was I was rolling through the beams because I was still on the clutch slightly at launch and then it would take off causing the crappy 60 foots. I tried to take care of that but dumped the clutch by accident and the car dead hooked and broke the axle. I've done a PB of 1.6 60' with the car and a bunch of 1.7s. The cars good for a low to mid 10 if I can get back into that range. Got some good pictures though!
  21. #6946
    NY
    skateboard
    Which turbo is Mod Addict running . Nice traps
    ― George Orwell
  22. #6947
    Jun 2005
    New England
    I think he is still on the GT4094R. He originally had a 0.85 turbine housing and I don’t know whether he changed it to a bigger one. He has a true drag car — automatic, full cage, race gas.
  23. #6948
    NY
    skateboard
    Sounds fancy which manifold
    ― George Orwell
  24. #6949
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Quote Originally Posted by GG///M3 View Post
    Steedspeed
  25. #6950
    NY
    skateboard
    I remember when I used to have one of those
    ― George Orwell
