Page 13 of 280 FirstFirst ... 345678910111213141516171819202122233863113 ... LastLast
Results 301 to 325 of 6981
Thread: Butters project GO-FAST (LOUNGE STYLE)
  1. #301
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    The lounge was inactive for so long I thought maybe it lost its liquor license.
  2. #302
    Jun 2012
    boston
    1995 325i
    Thanks, I've been welding for years as well. I have a couple migs, and a plasma cutter. But if you have access to a tig, I might be able to use you for a couple things. A buddy of mine is going to let me borrow a tig to fab up some pipes, but not sure when its available.
    I run a miller synchrowave 300 tig at work. I can kinda do side stuff their when my boss isn't in a mood...
  3. #303
    Oct 2013
    south
    cub scout
    Congratulations on the such SOLID dyno numbers (with such high mileage and stock internals and the like). NOW, will that "visible" display of your car's power be enough to appease your psyche? for how long? What PSI? Any hardware issues? It looks like your car is fast enough to beat any other on the road.
  4. #304
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by gemolken View Post
    Its going to have to be enough for now, dyno was @ 18 psi. Controller now set @ 20 psi but I find myself to be getting used to the power. That only leads one way. I really need to invest in the chassis of the car this winter. The neighbors #s are pulling away from me pretty strongly, but in time I will catch up.
    *notice the naked coils*
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  5. #305
    Nov 2007
    MA
    '95 M3, '85 535i
    No reinforced sway bar tabs on the rear subframe?
  6. #306
    Salem MA
    1997 BMW 328i
  7. #307
    Manchester, N.H.
    96 332IS 6466 turbo
    Should have some updates on thread when I get around to snapping some pics. the whole rear of the car is dismantled, in process of upgrades.
    1996 332IS
    Built 3.2
  8. #308
    Jun 2005
    New England
    The Lounge needs a monkey cam.
  9. #309
    Manchester, N.H.
    96 332IS 6466 turbo
    Maybe we will put up some pictures of your new "Butters built Driveshaft" as well. People might like to see how nicely you can twist splines up.
    1996 332IS
    Built 3.2
  10. #310
    Jun 2005
    New England
    Now that you are back at the gym, I figured you could twist the splines straight with your bare hands. I would like them shot peened and cyro treated after you are done.
  11. #311
    Manchester, N.H.
    96 332IS 6466 turbo
    Might be a 1 piece shaft when I'm done.
    1996 332IS
    Built 3.2
  12. #312
    South Carolina
    2004 330 vert 2004 X5
    Absolutely. My eyes bugged out when I saw it.
  13. #313
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by flyfishvt View Post
    Here is Phils (Pbonsalb) twisgted up driveshaft in for surgery. Getting a newly used spline section and a HD ujoint
    1996 332IS
    Built 3.2
  14. #314
    Jun 2005
    New England
    What is happening in the lounge today?
  15. #315
    Manchester, N.H.
    96 332IS 6466 turbo
    We are building up some M3 trailing arms.
    Here is the first coat with por15 silver.
    1996 332IS
    Built 3.2
  16. #316
    NY
    skateboard
    Only I can do such feats.
    ― George Orwell
  17. #317
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by GG///M3 View Post
    with only your mind. ;-)
    1996 332IS
    Built 3.2
  18. #318
    NY
    skateboard
    Correct
    ― George Orwell
  19. #319
    Manchester, N.H.
    96 332IS 6466 turbo
    Here is a pic i snaped before.....
    1996 332IS
    Built 3.2
  20. #320
    Manchester, N.H.
    96 332IS 6466 turbo
    Rear after hardware removed and coated with por15
    1996 332IS
    Built 3.2
  21. #321
    Massachusetts
    1987 BMW 535is
    More awesome requested.
    Stay strong NE Brother!
    Little inspiration?
    http://imgur.com/a/XwyZM
  22. #322
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by konarider98 View Post
    Little inspiration?
    Nicely done.
    1996 332IS
    Built 3.2
  23. #323
    Manchester, N.H.
    96 332IS 6466 turbo
    For those who will be installing rear subframe reinforcement plates. You can center/pin the plate to the body using a wheel bolt.
    1996 332IS
    Built 3.2
  24. #324
    Massachusetts
    1987 BMW 535is
    Whats a latest thing going on butters?
  25. #325
    Jun 2005
    New England
    When I stopped by this morning, the IT Department was at work trying to get the lounge back online as soon as possible.
