Wheels are DForce Empower lightweights.
Not much of an update, been driving it.
This month completed
bumper
S50 cams
Dual stage boost controller
Line lock
Next will be a adjustable fuel pressure regulator.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Did you ever go to the track? Maybe in a few weeks I'll be able to go on a Friday.
1996 332IS
Built 3.2
Gots me a spare engine for when (if ever) I blow up my current 2.8
Most think im on borrowed time, so let's begin a journey of building up a low compression, bullet proof 2.8. Im not sure at this moment in time if I will go with an S52 crank and custom pistons (3.05), or stay with a 2.8 L displacement and install pistons, rods etc. Not overly in a rush to get this done due to the fact that the
287,000 mile original block is still holding strong
tipping the 500 RWHP marker. But the engine is on a stand and getting broken down.
BTW, I know nothing about this engine. I was told it was running but never has been confirmed. If anyone needs sensors or OBD2 manifolds let me know. Most of this engine will be up for sale for short change.
1996 332IS
Built 3.2
Very nice !
1997 Cosmos E36 M3/4/5 Boost Logic GT40/94r .85 Technique Tuning
Stock motor
1998 Estoril E36 M3/4/c4 Steed Speed2 Gt40/94r 1.06 Technique Tuning,
Built motor, Best ET ( 9.63 @ 142.61 mph MS100+meth ) 10/08/21
Best mph ( 10.08 @ 144.66mph MS100+meth ) 9/18/19
build thread:
http://www.bimmerforums.com/forum/showthread.php?2269817-Habbit-continued-Turbo-build-V
Chris I tried to PM you, but your inbox is full....
What do you want for the cover that goes over the mani's? I'm missing mine, and like one to be complete.
Sorry about the PM box.
I have 3 or 4 of them. You can have one. ; )
1996 332IS
Built 3.2
Good thinking Butters.
Hi 5
― George Orwell
The engine will be a slow build. But I did pull off a cool repair today. I replaced the rear U-Joint on the driveshaft. Many say it can't be done but........ you know.
Original shaft and joint
Burnt out the U Joint
New U Joint installed
Needed to tack weld the caps in place
For future reference, the part # on a staked U-Joint is 430-11
It was a little more involved than normal Joints but it can be done.
Car was driven with no vibrations from shaft. ; )
1996 332IS
Built 3.2
Once repaired I will sand down 600 grit, prime and paint.
engine is slowly getting stripped down. Vanos is out and rebuild kit has been ordered. Im going to rebuild this Vanos unit, pop it in the current engine, then rebuild that one later in life for a spare.
As far as this engine goes, my plan is to build it up low compression S52 spec.
1996 332IS
Built 3.2
Awesome, cant go wrong with a spare engine Btw I will take the little blue secondary air line off it lol
360+rwhp
1996 332IS
Built 3.2
Nice job on the U Joint. Where did you source the new one from? I have 2 shafts I could sell easy if they had new U joints and shipping on those is super cheap. You can sell it to anyone in the country.
I'm in for the engine rebuild. Of course you realize that as long as you have that spare sitting there your current one wil go 1,000,000,000 miles.
1996 332IS
Built 3.2
1991 BMW 325i(Current Daily) (S52)
I have carburetors, and I'm not afraid to use them!
There are always other fish (engines) in the sea (Craigslist)
Life is about enjoying the engine you are sitting behind.
I design U-joints in my spare time. They are made with materials directly from Pluto.
1996 332IS
Built 3.2
Time to Bump my winter project thread.
Car was put away last night and I'm starting to pick away @ the upgrades. A quick run down on "mods" first.
Engine
2.8 orignal 292,000 miles
MLS .140 head gasket
ARP head studs
S50 cams
Fuel
Walbro 255 pump
Aeromotive adjustable regulator
60# injectors
M50 manifold
Drivetrain
ZF trans "freshened up"
Clutchmasters FX725 twin disc clutch
UUC evo 3 shifter
TCI line lock
3.23 LSD
Suspension
Koni yellow adjustabe shocks/struts
H&R OE sport springs
UUC rear lower control arms
UUC front and rear adjustable sway bars
UUC RTABs
Forced Induction
SPA manifold
Garrett GT35R turbo
Synapse BOV
Tial 38mm wast gate
Turbosmart dual stage MBC
Technica Motorsports DME tuning
Pics of car as of now
1996 332IS
Built 3.2
Nice! What's in store for the winter?
I'm starting in the rear of the car and working to the front.
Basically I'm going to set this thing up to handle 1,000 bhp. I'm tired of "I better not launch too hard or I will break an axle"
I'm not saying this car will ever have 1,000bhp , but it will be able to handle it if it did.
I have a full rear section I have started to prep.
Here are some pic of the subframe
Blasted and ready for POR15
Coated with POR15
1996 332IS
Built 3.2
Next will be engine if time and $ permit.
That said , if anyone needs stock axles or any other parts let me know. I have quite the bin going on. I have 3 engines torn down and 4 axles , I can rebuild a vanos real quick (3 ready for rebuild) if anyone needs.
1996 332IS
Built 3.2
If you need any welding help or advice, let me know! I'm a welder by trade tig/stick/mig. All positions and processes.
Thanks, I've been welding for years as well. I have a couple migs, and a plasma cutter. But if you have access to a tig, I might be able to use you for a couple things. A buddy of mine is going to let me borrow a tig to fab up some pipes, but not sure when its available.
1996 332IS
Built 3.2
