Hey guys, before you shoot me down for it not being a true blood M3, it is the engine that really matters - to me anyway.
The car started off as a 325i but I quickly upgraded and modified some things to make it better. The goal with the car is to have a nice high HP and torque NA engine. It will be 11.5:1 compression which is perfectly safe for pump gas and it will feature some of our cams that Paul Burke manufactures for us. I am hoping to hit 300 - 320 WHP under 7500 and about 265 - 275 Wheel Torque.
Here is the car as it sat when I bought it for 1300 bucks!!!
I did some cosmetic upgrades to make it look much better than a 325 and some would say it looks better than a stock M3...
The Wheel well was cut out so that A custom rear diffuser can be fitted...
I have a ton more pictures that you can see on the cars blog, www.e36warmachine.com if you want to see the blabbering about all the details.
As for the engine, I finally got that back together last week...
Specs:
S50B30 US Spec
Miller 87mm 11.5:1 Compression Pistons
Miller/Burke custom cams - 235.7@.050 430L intake / 228.5@.050 451L exhaust
Miller WAR Chip
Eagle Rods
ARP Hardware
Elring w/Oring setup
Electric water pump with secondary block entry
Eventual 75 - 100 shot of N2O
Stock ports, just valve job...
Degree'ing the cams to get a 117.5 Center line for the intake and 108.5 center line for the exhaust. This will give me a nice frumputy idle around 850 but if I raise the idle to 1100 it will smooth out. I want it rough though :P
The oil pan is coated with a nice thermal dispersant so that it sheds heat easier. Makes a nice difference in temps on intake tubes etc so I am eager to see how well it works for the oil pan.
I chopped the impeller off the water pump since I am going with an electric Davies Craig unit. I don't have time to make a nice block off plate so for now, this had to do.
Got the Fidanza fly wheel on,
Followed by the ever trusty clutchmaster FX400 6 puck...
Ready to drop in all as one...
Special TCM knob installed that matches the interior better... I am holding the "stock" switch knob our WAR Chip comes with.
Last edited by Brody @ Miller; 04-18-2013 at 06:47 PM. Reason: More pictures added
OP delete the double posts
thats one hell of a car, in for videos
In for this, looks promising so far!
-Jesse
2003 Imola Red 330i ZHP
Future plans: LED tails, LED interior light upgrade, LED side markers and fender lights, New headlight lenses, Projector Fog light housings
Mods: 6000K HID Fogs, 10" Sub and 400 watt amp
Subscribed!
Looks good man. Want to see the diffuser finished.
2001 330i.
Looking great brody, do you plan to use solid lifters, i will be amazed and very happy for you if you get those numbers, good luck, prove alot of people wrong!
Dream big, work hard, and let what you love, be what you do.
Best in Arizona, Certified Master Technitions, Founded in 1992 and family owned since.
http://ultimateautoworks.com/
Damn...that thing is bold. Would love to see it around town.
+1 for local car.
Killer build! Did you go with their titanium retainers as well?
Who's going to tune the car,,,,,,
I kid.
Actually, I was not aware that the WAR chip was capable of switching between four different pre-stored tunes until I was reading up on it on your web page. How did I miss this before? In for results!
WOT
I'm digging' it. The "war paint" looks awesome.
Solid build! What brand is that headgasket?
Mods: obd1 s52, SS replica headers, SS race mid-section, SS exhaust, euro intake, 3.5" hfm, turner tune, 24lb injectors, uuc flywheel, m5 clutch.
Wow, I can't wait to see the end result of the rear diffuser and exhaust!
1999.2 Titanium Silver Metallic ///M3
Car & Driver's "Best Handling Car At Any Price."
Looks awesome!!!! I'm a M Coupe S52 guy, but i'd swap you any day
Without headwork and large duration/lift cams, I don't know if your powergoals are realistic. GL anyhow.
Wow...I have not logged into BFC in a long time. I come back and see this as one of the first post upon coming back...NICE!
GL
----Dave----
