hallo, my problem is that the dme "ms41" from my 1995 e36 328i is broken.
so i bought a used dme from a 328i.i went to bmw to ews dme sync.but
the repairman says he canīt sync a used dme.i must buy a new one for ~750,- *no way*. i called another bmw-seller says it would 300,- .costs
to make a simple - ews dme sync.
so now i have bmw standart-tools( ediabas,inpa,ncs-exp,winkfp. ect)
can anyone please tell me :can i make the ews -dme sync. self with inpa ?
when yes,how to?or simply say whether it is possible with inpa?
excuse me bad english
greeting
You should look into Dis 44 and it will do what you need...Hard part is getting the software to work and properly configured to laptop..
hi,thats a problem. ther is not even a rudimentary detailed instructions in german to install and get it to run with ads/obd interface.
is there no possibility to do it with inpa?
greeting
INPA will not do what your looking to do to align DME-EWS, DIS 44 or Progman is your best choices and the instructions are pretty straight forward...You should contact IcemanBHE for his setup that he is offering which is setup for ADS and fully working condition...The links to softwares you find on this site as well as others all have been taken down due to federal regulations.
*CODING BMWs in N.Y Area 917-939-4980*Call or Text for INFO
hi i found that from user:alfrietos
""INPA can easily syncronize the DDE/DME with the EWS. First get the ISN from the DDE/DME from the coding section of the control board by pressing F3 (atleast by my program). write off the ISN then go to the 'activate' part of the EWS. Press F1 (Writing ISN) and simply type the characters you read off the DDE/DME. Press OK and voila!! the EWS and the DDE/DME are synced""
greetings
Old thread, but can any one confirm this?
I am about to align my old ews (e36 328 1995/10) with "new" dme from wreck yard (e39 528i 1997). Old dme cold`t be flashed because it had the old chip type,"new" dme has the newer chip, but ews is problem.
INPA does it, but so does this easily
https://www.bimmerforums.com/forum/s...0-vagcom-cable
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
If your car has a production date prior to December 1995 your car should not have EWS2 and it should not require ews alignment.
