Results 1 to 25 of 72
Thread: BoldUlysses' '95 525i/5 Log & Thread o'Questions
    Apr 2009
    Chattanooga, TN
    '94 MX-6
    It's time. Here she is:
    I'm the 2nd owner; bought it in April of 2010 with 143K. Currently 171K.
    One of the most dependable cars I've owned. It just keeps on going.
    Current issues:
    - Clearcoat giving up the ghost on the roof
    - Front passenger and rear driver side windows inop.
    - Passenger power headrest does not go up or down.
    - Lifter tick while warm.
    Anyway now that I've got it back in the garage I'm trying to take care of the outstanding issues, and I figured it was time to start a log rather than keeping posting questions in the E34 OT thread.
    Recent progress:
    - Fixed steering wheel squeak
    - Fixed door stay pop/crack
    - Replaced all door handle gaskets
    - Replaced thrust arms (Meyle HD), sway bar end links (Meyle HD), lower control arms (steel, TRW), tie rods and dog bones (Meyle)
    - New roundel
    - New tires
    - Alignment
    Current focus: Eliminating lifter tick.
    Stay tuned!
    Current: '94 MX-6 V6/5 • '72 240Z • '10 Mazda5
    Past: '02 330i/5 • '85 RX-7 GSL-SE • '95 540i/6'95 525i/5'86 635CSi/5 • '88 JZA70 • '86 4K quattro • '85 RX-7 S
    Wish list: Type 44 • Manta • Pre-'85 CGT • 405 Mi16 • SVX • W123 Coupe
    Jul 2012
    MA
    ///M5
    Great looking car! I've really become fond of green on tan. The wood grain on the shift surround is gorgeous!
    Current
    2005 E55 AMG
    1998 Silverado K1500
    1964 Impala
    ​1964 Chevelle 496ci
    Past
    2000 Avus M5
    1988 Suburban K1500
    1987 Suburban K2500
    2007 Suburban
    1999 K2500 Suburban
    2000 MGM
    1999 K2500 Suburban
    2001 Stratus 740i Msport
    1990 750iL
    1995 540i/6
    1996 MGM
    Jun 2012
    Monterey
    91 E34 525i
    Oxfordgrun right?
    Looks nice indeed.
    Apr 2009
    Chattanooga, TN
    '94 MX-6
    Quote Originally Posted by Leonator134 View Post
    Thanks Leo.
    Quote Originally Posted by Ley3198 View Post
    Oxfordgrun right?
    Looks nice indeed.
    Yes, Oxford unfortunately. My wife likes the color so I guess I can't complain too much.
    Oct 2008
    From Maryland to New York
    E46 M3
    Wow thats clean!
    About time you did this thread..... These threads are great for you and its future owner. Besides, we all love to read them.
    Apr 2009
    Chattanooga, TN
    '94 MX-6
    Thanks Pat. It's not as clean as it looks it the pics, haha. But I appreciate it.
    I have a build log for the Z on my blog, but I don't really want to talk about the E34 over there, seeing as how it's my DD. Maybe it I really start modding it I will, but otherwise nah.
    Okay so first questions. Help me fix the shimmy. As mentioned, the UCAs, LCAs and sway bar end links are all new, good quality parts installed properly. Tires are pretty worn, but I don't think it's them, seeing as how if they were out of balance I'd get a shimmy at any speed, but this only manifests itself above 60 mph or so. Is my line of reasoning on the tires correct?
    I've had strut/shock mounts recommended, along with idler arm and potentially rear dog bones. Can someone point me in the direction of a part # for the strut/shock mounts? I've never installed such parts before (I have a set of spring compressors, though) so I'm having trouble finding them on the RealOEM diagrams. Thanks!
    Oct 2008
    E46 M3
    New tires make a world of difference. If the front stuff has been replaced, I'd start with some tires for the front.
    Also the rear pitman arms make a huge difference.
    I'm sure you installed your UCABS and LCABS to spec?
    Jun 2010
    95470, CA
    '94 540i/5
    I had the shimmy real bad. I replaced everything. I mean everything. And it was gone, untill I got my 18" style 65's... and it came back.
    I found the solution to be in the 'thrust arms' (UCAs). You HAVE to go poly-u. It was my answer and I swear by it. I run the powerflex purples and have never looked back.
    Apr 2009
    Chattanooga, TN
    '94 MX-6
    Quote Originally Posted by ShapeShifter View Post
    I did. Torque values as per the Bentley, all done with car properly loaded sitting on all four wheels.
    I have a set of dog bones to install. The guy from BMA said a shimmy that those would fix would be felt more in the seat than through the steering, and while I don't feel it primarily through the steering wheel, it definitely seems to be coming from the front end. We'll see.
    Plan to rotate the tires front to back, same side, next and see if that makes any difference, good or bad. Basically one thing at a time.
    Jun 2006
    Raleigh, NC
    E34, E368
    My suggestion is tires as well because swapping front to back is easy to do.
    Dec 2007
    South of Boston
    Scrap
    Was all of the steering linkage done as well?
    Sep 2008
    Chesapeake, VA
    '12 Golf, '95 540iA sold
    I would believe it could be the tires as well for two reasons. One, when I got my E34 and before I got rid of the tires it came with I got a shimmy occasionally. Second, and this only applies to people in the north really, when we get deep snow, you end up with snow on the inside of the alloys throwing them out of balance and the vibration only shows up at higher speeds, so your wheels could be only slightly out of balance and it only shows up at highway speed.
    Car looked good when I saw it last year. Did someone steal your hood roundel? Sorry to hear about the clearcoat.
    Oh, what causes the steering wheel squeak? Mine had that and I never even tried to fix it.
    Apr 2009
    Chattanooga, TN
    '94 MX-6
    Quote Originally Posted by Steve547i View Post
    No. Steering feels tight and although the wheel does shake a bit, I feel it more around the footwell area. Hence the reason it wasn't 1st on my list of stuff to replace. I should check it, thoug.
    Quote Originally Posted by jbondbmw View Post
    Good tips. I'll swap the wheels around and report back.
    Nah it just flaked off one day. The metal "base" disc is still there but the top element is gone. I'll replace it soon enough; all available money's been going toward need-to-fix stuff first, though.
    Based on a forum search it seems to vary but the most common culprit is the slip ring behind the wheel. Lubed it up with white lithium grease and all was well.
    Sep 2008
    Chesapeake, VA
    Quote Originally Posted by BoldUlysses View Post
    Bummer, that happened to my trunk emblem in a car wash the first winter I had it. What was funny is that I had a spare in the back seat so I swapped it after the wash.
    What is also a bummer is I had a spare roundel I gave to my buddy to stick on his 1990 Ford Econoline as a joke and to piss of his buddy in CA (since he has several BMW bikes). Had I known, I would have sent it to you as in your case it is needed.
    That makes sense. I had the SRS light and it was most likely due to a failed slip ring.
    Denver, CO, USA
    93 M5 88 M3 14 i3
    Beautiful car and I love the clean engine bay!
    Apr 2009
    Chattanooga, TN
    '94 MX-6
    What is also a bummer is I had a spare roundel I have to my buddy to stick on his 1990 Ford Econoline as a joke and to piss of his buddy in CA (since he has several BMW bikes). Had I known, I would have sent it to you as in your case it is needed.
    That is a bummer! It's only $30 or so on Pelican. I'll get it soon. Ain't hurtin' nothin'. It's a workhorse.
    Quote Originally Posted by 93FIM5 View Post
    Thank you sir! I'm very grateful to the original owner for her care of it; she can take credit for that.
    Jul 2006
    Hanover MA
    '11 Golf TDI+Porsche 996
    Trade you my 540i/6.
    I own mostly junk. Except the Porsche, that's kind of cool.
    All the motorcycles are trash which you can read about at
    http://oneguytwowheels.blogspot.com/
    I'll update it eventually
    Thansk
    Apr 2009
    Chattanooga, TN
    '94 MX-6
    Quote Originally Posted by GarrettSR5 View Post
    Haha I thought we covered that already?
    Jun 2006
    Raleigh, NC
    E34, E368
    I'll give you a set of throwing stars with fresh rubber in exchange for a year of moderator powers starting from the date of delivery.
    Norlina
    Fives
    Oh goody.
    Quote Originally Posted by Layne View Post
    I can't speculate on what would cause the POOP alarm, but I would recommend pulling over immediately.
    Specialization is for insects
    Apr 2009
    Chattanooga, TN
    '94 MX-6
    Quote Originally Posted by clevertd View Post
    Would that that power were mine to dispense.
    Apr 2009
    Chattanooga, TN
    '94 MX-6
    Got the wheels swapped front to back. We'll see if that makes any difference tomorrow during the commute.
    Got a chance to check out the dog bones; they're completely shot. I wonder if that could be contributing to my problems? I have a spare set to install, and I almost did—they were just hanging out there, tantalizingly close, but:
    1. I had a sinking feeling they would take much longer to replace than they looked like, and
    2. I wanna do this as "scientifically" as I can, changing one thing at a time so I can figure out what the problem is once and for all.
    Examined the steering linkages as well—they're all completely fine; no torn boots or play anywhere.
    Stay tuned.
    Jun 2006
    Charlotte, NC
    e30 e34
    Dog bones are pretty easy to do, shouldn't take long at all, hardest part is having to jack up the control arm just right to remove/install bolts. They won't contribute to your shimmy though, you can run the car without them altogether. Bad dog bones will usually give you a nice clunk in the rear.
    Gotta hate tracking down the shimmy, I'm about to start that on my car right now. It's never easy and it always seems to be something different
    '88 s54 e30, '00 m5
    Apr 2009
    Chattanooga, TN
    '94 MX-6
    Thanks for the input. No clunk from the rear at all, and yet the dog bone boots are all ripped to shreds, dried and flaking off. Hmm.
    May tackle them tomorrow just 'cause I have the parts.
    Oct 2008
    E46 M3
    I found that bad rear pitman arms led to a rear steer sensation and tramlining.
    I also noted some rear end movement mid turn while driving aggressively.
