The bushing bore in the e21 rear trailing arm is 1.057" / 26.85mm dia.
"The water was not fit to drink. To make it palatable, we had to add whisky. By dilligent effort, I learnt to like it." Sir Winston Churchill
was that taken with your starrett accubore digital spc + internal dial bore gauge set or just a run of the mill standard internal dial caliper?
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
14 f800gsa - red headed stepchild!
Thanks Terry.
I started mocking up the rear today.
Taking a few measurement:
Won't be needing that part of the subframe.
Should have some stuff tacked together tomorrow.
lol. I can relate!
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
Damn you guys make me feel like in super young. I'm only 27
Yea we know, younger than our freshman batch of hemorrhoids. You should live so old! Enjoy everyday.
For those waiting on an update, here is what I got to in the last few days.
The new sub mounted to the old, using the old as an adapter. Just tacked together for now as always gusseting will be once everthing is together.
You can see how much wider the e36 trailing arms are than the rocker panels of the e21. (the pivot angles are the same.) So I did this:
Rebuilding the trailing arm. The plan is to rebuild from scratchbuiling it boxed in and x-bracing inside. Also for a rtab bushing the plan is to use the 5/8 shoulder bolt as the pivot and a delrin insert turned on the lathe. All the washers are so I can adjust the toe on the back end. I figured its suppose to be that way since the factory rtab mounts on the e36 the holes are slotted.
Thats what I have so far. Hopefully done by the end of the week.
Also gave myself a real deadline... I want to have the car driving by the middle of July because there is a big pro-am drift event in Detroit in the middle of August. So a month of practice and dialing it in.
Quick little update... Didn't really have the time to get into the trailing arms today so I whipped out this little steering extension block. Since its going to be mostly a racecar I just went solid on it.
Looking good!
If you seem to be very skilled. Would you consider doing an E30 center subframe chop into the e21 subframe for me sometime? I need this done to run the e30 diff. That is after this build....
"..Horsepower is a measure of work done over time, or the rate at which work is done."
http://www.cardomain.com/ride/579694/1
Went to the junkyard today to try to find another set of rear calipers to run a hydro e-brake. Well I'm gonna have to try another yard another day.
Even though I didn't find what I was looking for I did score:
Got these for a song...
Almost done with the passenger side trailing arm. The driver side should go a little quicker.
Looks great....but how much weight are ya putting on her? hehe that's some solid tank sized, gauge steel you got there sir.....wow
My build thread M20 than S50 into 320i: http://forums.bimmerforums.com/forum...0#post23442810
Shouldn't end up much heavier than the stock trailing arm... This is one place strength is going to superceed weight due to the strain its going to have on it. It's 1/4" sides and 1/8" top and bottom and I'll be adding an inch wide strip overlapping the seam cause I dont trust the butt-weld. Don't worry Ski I'll loose the weight back when I do away with the huge upper control arms in the back since I'm going to run a strut in back like the e21 has instead of the divorced setup that the e36 has.
Nice! This thing is gonna be so smooth! And since you're in MI I hope you spray those new pieces at least with por15? Have you ever used that??? Holly crap, whatever you do, don't get it onto your skin! I had a little on my forearm for 3 days! Showers, soap, brush even sand paper wouldn't take that off...and that's on human flexible skin.... Imagine it on the metal?! I personally highly recommend this product and worth the money. If I lived in those snow/salt/wet states I would paint my whole car with this!!!! Hahahaha
Ski I think the plan is just rattle can it until winter then when I put it away pull all this stuff back out to do that stuff.
Oh that's easier said then done. After you're done with all the fab work, assembly, disassembly then assembly again, welding, cutting, fitting, hunting for parts(I know you have parts car 3 feet away but still) after all that..... You'll be too tired brother.
All that is physically and mentally exhausting! Trust me...and I haven't done as much as you have when it comes to fab work...shoot, I got worn out just going thru your couple pages in this thread! Haha
Do yourself a favor man....and you can quote me on this "do it right the first time" and "always do your best to NOT going back to what was already done"
Ive been around a few yrs....speaking from experience cause if you don't do it now, you won't do it later and all this beautiful fab work/art will be destroyed by rust in no time.
That is some damn good advice, Ski.
I can't wait to see how this turns out!! Love the DIY.
How do you plan to adjust toe? Are you going to cut up into the floor to clear that new piece connected to the e36 control arm?
I am just north of you in Bay City. About to start an s50 into an e21.
www.classicdaily.net
1970 m42 swapped 2002
1985 LS1/T56 Swapped e28 (557e)
Follow me on Instagram for constant build updates @classicdaily
I have 3 1/8" thick washers on each side of the trailing arm that I can move from one side to the other to adjust toe (I can always get thinner washers to get finer adjustment.)
Yeah I'll cut through the floor if I have to. I don't know what I have for clearance now.
Thats cool man if you ever need a hand or wanna stop in and see something I've done hit me up. I'm starting to wish I would have just went with a motor swap because I'm pretty much learning as I go with the suspension/subframe swap. I'm in uncharted territory.
Good idea on the washers. Interested to see how it all ends up.
Cool cool...we have a crew going to tedfest near Toronto july 5-7th if you were interested in going. It's a pretty great vintage show and only 4-5 hours from home. So far it will be me in my LS1 e28, buddies with turbo m42 e21, m30 e30, Steve from blunttech with his LSx e12, and maybe a guy from MQT with his e28 M5.
The passenger side trailing arm is done other than a little clean up and paint the driver side should be done tomorrow. Then I'll be on to finishing the subframe adapter.
