I have searched and found people unplugging the Factory ae connector and coding out the bulb check, I am interested in trying to make the ae come on with the key on and keep the bulb check feature active without having the drl on. My idea is to back feed kl15 switched power+ into the ae but also instal a diode in series between the lcm and the back feed connection. I am also thinking of just running the 12v switched hard wired with a 5 amp fuse but no relay as the led AE are low amperage the relay is overkill. The ae look much cooler if they come on by themselves. Any input? I think the diode will allow bulb check functionality?
