#4. Operate. Out with the old....
This weekend I wanted to get this swap really rolling. Aka, get some last pictures of the compact with it's "cylinder deficiency". First stop was to go down to AutoCouture in Fair Lawn, NJ to get the car corner weighed. The car only had a driver's side vader in the interior but still had all of the trim.
Verdict: 2599 lbs. Pretty bad weight distribution but I'll figure that out later.
Afterwards, I got the car into the garage to stare at it's transplant.
Then did the levitate mod.
More to continue tomorrow...
Past Builds:
S54 E36 Compact Build|Thread|IG|@_goldfinger|
Current Fleet:
Z4 M Coupe - Black Sapphire Metallic over Black
Garrett you're insane bro.
LOVE this build man, everything's looking great. What's your approach to engine management with this thing?
Past Builds:
Current Fleet:
Wow thats is insane!
Getting there! Ran into a lot of issues with the exhaust. In typical fashion, all of the exhaust bolts and hangers were stripped/rusted out. Makita angle grinder took care of that! Motor, trans, and rear suspension will all be out this week.
I've been spending time selling parts to fund the project but have gotten in a good amount of parts for the build as well. I'll post pictures as I take them since that's more interesting than reading
I'm hoping it'll be a fun ride when it's done!
Past Builds:
Current Fleet:
Moar. Weight Reduction.
So, after borrowing a dremel and cursing at the exhaust bolts, I finally got the anemic M44 out. I've parted out a dozen E36s over the last year and have never had the issues that I did with removing the M44. For some reason they must use lower quality nuts on the headers because they've all seized despite healthy dousings in PB Blaster.
Anyway, here's the filthy engine bay:
And the M44 staring down its replacement. Should be good.
Now the fun begins....
A question for the board though, what do you use to degrease the engine bay without damaging the paint?
Past Builds:
Current Fleet:
Past Builds:
Current Fleet:
Can't wait to see it all buttoned up man!
I used purple power and distilled water 50/50 and pressure washer.
Me either! I just need a solid weekend in it to get everything together. Unfortunately time like that is hard to come by.
Thanks for the recommendations guys. Hopefully the weather clears up a bit so I can roll it outside and wash it down. Maybe I'll just install the new suspension and rear end in the meantime
Past Builds:
Current Fleet:
Are you going to install the header before you drop it in? What headers did you end up going with?
Definitely, doing headers and the CPV valve before I put the motor in. I ended up picking up Euro headers for a great price that I couldn't pass up, especially with OE fitment and quality. Also got this in today:
I somewhat impulse bought the AA Race Exhaust from the resonator back to the rear section. Now I'm faced with a few options:
- Custom front section between S54 headers and resonator
- Buy AA front section and Bimmerworld adapter pipe (which is currently out of stock)
- Adapt rear AA muffler to shorter 318ti bumper
- Build custom rear section with Magnaflow muffler
- Sell the exhaust and just go full custom
- Talk to Stromung who finally returned my calls after a month
Can you tell I'm hung up about the exhaust? Hah.
Past Builds:
Current Fleet:
build full custom 3inch single headers back to that aa mufler
I have eBay headers. And a dual rasp pipe in case it's to loud once I go full 3in
I have a Remus muffler that's whell parked and it quiets the noice down alot..
House OF The swapped Compacts !!!! Mzk2built
98active 318ti s54 cf airbox alpha-n-tune by RK Tunes 325rwhp 257rwtq
98 Cali edition 318ti completely stock daily (FOR SALE)
95 318ti active w/winter package long time drag project awaiting S/C s54 swa
Past Builds:
Current Fleet:
Im so jealous. lol
I'm definitely with you on the exhaust thing. I'm itching to do another custom exhaust again!
I'm a little worried with how loud the AA race is on a street car but we'll see what happens. I've only heard one indoors before when Guten Parts had a built E36 S54 swapped track car in their shop. It was deafening when it revved.
I think I'm going to go in on a Miller Diversion 180 with some friends and go from there. Having a TIG welder would be pretty essential for my next project anyway...
Past Builds:
Current Fleet:
Prep. Clean. Torque. Repeat.
So, some more updates. Started doing some preassembly of parts and cleaning out everything. Started by collecting up some of the new parts:
Rogue trans mounts on new Euro trans crossmember:
New 325i slave and Rogue clutch line:
Old (79k mile) vs. new guibo
Took Compactive's suggestion and got a bottle of Simple Green and an electric toothbrush. Went to town on the engine bay and it came out excellent:
Killed a lot of microfiber towels in the process but I'm really satisfied with how it came out. Only spent an hour or two on it. The electric toothbrush definitely made everything easy and helped to agitate a lot of the grease that built up over the years.
Then Matt came over and showed me how to polish my VANOS. He left me with this and I'll spend the time to get that mirror shine:
Grabbed some more new parts (S54 header gaskets and copper nuts):
and finally got my Euro headers installed:
Also installed the new Euro shifter setup using the original E46 M3 shift lever:
And capped it off with a ZHP shift knob I had laying around from a partout:
Past Builds:
Current Fleet:
I like how this is coming along, keep up the good work!
lookin snassy!! I look forward to this one, keep up the good work!
1996 328i (m52B28US) OBD1 euro ZF 5spd. 3.23LSD conversion / Chem. PnP Head/ DINAN stg.2 CHIP/ VAC race valves/ S52 cams/ A/C delete/ fan delete/ Washer Fluid resv delete/ ARP head studs/ Cometic 140MLS / VAC Solid Engine/trans Mounts/ CAI / 2.5"Borla race exahaust/ NGK R spark plugs, M50 Mani, S50 Oil Res, Riot Racing HFTB, SAMCO Hoses, JBR FW, X-Brace, Mtech Front Bumper, RE RSMs, stoptech SS lines, Bilstein sports, H&R Race Springs, S52 Reinforcement plates, Kosei K1 w/ bridgestone RE960as, Brembo/stoptech slotted rotors, M3 Trailing arms, M3 Calipers, M3 Axles, ACS strut brace, weight reduction.
http://mbuild.blogspot.com/
