Some good work being done here
A sleeper for sure.
Ive run 3.25, 3.45, 3.46, 4.10, and 4.44 with my tis and never really had an issue with traction. I choose to run 4.10 with my m50 and the ls6. The car is very tame around town and running it hard doesnt really overrun the tires unless youre really trying to roast them. I ran BFG kdw2 with 245 and 285 out back. The 245, when dropped from 3k with the v8/6 speed barely broke loose, just pulled really hard. The 285s on the other hand, gripped without mercy once heated up. I was able to out launch a supercharged foxbody and pull about 3 cars lengths by 100. The other, most impressive race, was against one of the local snobs in his gt3 turbo. We only ran to ~80ish, but i kept ahead by a half of a car lenth with the fully assembled ls1/6/4.10/285 setup.
This is how it looked that day...Pardon the lack of a hood, i was in a rush and didnt have time to put it back on before work.
2001 E53 X5 - 5.3 Procharged, 4L80E RWD, Brembo, 20" alloy, EBC race, Forge, A2W intercooled, Alcantara interior, 3.62 LSD and more!
2005 E53 X5 - 6.0TT, 4L80E RWD, 20" alloy, EBC race, Forge, A2W intercooled, Alcantara interior, 3.62 LSD and more!
1996 E36 335ti - N54b30, A2W intercooled, ZF 6speed rwd, 4.10Lsd, Speedline magnesium rims, Brembo, S55 exhaust, 245/40/17-295/30/18, idrive, Forge, logic 7
1999 E36 360ti - 6.0, ls6 springs, ls6 cam, hardened pushrods, trunion, racing baffle, t56, ls7 clutch, m3 brakes, 4.10lsd
This should be very interesting. Sub'd.
Damn!
2015 M235i 6MT
great transformation journey there ..hope someday i could get an s54 heart for my e36 too
Z3 non-M rack is quicker then the Z3M rack.
Awesome build.
Thanks for all the support guys! And nice kills Tony!
So right now I'm looking into headers and exhaust options for the motor. I want to get that all done before it goes in the car so it doesn't turn into a pain in the ass down the road. I refuse to put garbage on the car, so I've been looking towards some Fabspeed headers. It's pretty nice since VAC and Fabspeed are both pretty local to me. From what I've read, fitment seems spot-on. I could go all out with Supersprint V1 Stepped headers, but the juice isn't worth the squeeze to me. I could put that extra $1000+ towards something else.
This build might take a little while, but I'm planning on having it done in the next 3 months. I'm not in too much of a rush since I can't enjoy this car or the M3 much when it's so cold out.
Past Builds:
S54 E36 Compact Build|Thread|IG|@_goldfinger|
Current Fleet:
Z4 M Coupe - Black Sapphire Metallic over Black
Reinforcements.
Z3M Rear Finally Dropped.
So, today I trudged out of the foot of snow we got and went up to my garage. One of the last set of parts that I haven't removed from the Z3M was the rear axle/exhaust. Compared to a typical E36, it was a hell of a lot easier. I decided to just drop the entire rear suspension with the diff attached. I'm sure I'll have to learn to drop the diff by itself sometime, and it looks like it sucks with those two top-mount bolts.
The first thing I really noticed was that the rear exhaust sections were unexpectedly heavy. Since I have a nice shipping scale in the garage, I decided to put it to use.
Z3M - Left Muffler Section: 34.60 lbs
Z3M - Right Muffler Section: 35.25 lbs
Thaaaaaaat is a lot of weight for a catback (~70 lbs). I was planning on using the dual cans from the Z3M on the 318ti at first to save some cash on fabrication. Now that's a no-go. Maybe some Z3M guys can use those weights to compare to aftermarket exhausts.
I guess I went a little OCD with it too and started weighing some of the stuff that came out of my 318ti. I'll probably keep a log of weight info in this thread too in the spirit of sharing info and paying a lot of attention to weight reduction.
318ti: REAR SEAT DELETE (not including seatbelts) - 54.1 lbs
318ti: Rear backrests - 33.5 lbs
318ti: Rear bench - 11.8 lbs
318ti: Rear bolsters - 3.6 lbs/pair:
318ti: Rear door panels - 5.2 lbs/pair
Anyway, the goal of the day is complete. The Z3M rear axle all cleaned up. I'll be doing a bushing refresh and a diff swap while the dropout is down. Trying to go for something way more aggressive since I've got the 6 speed box. Right now I'm thinking of a tire-roasting 3.91 or 4.10 out back.
Past Builds:
Current Fleet:
Interested to see how a 3.91 or 4.10 works for you with the six speed!
Dang, so that's what the Z3 parts were for. I like where this is going.
So am I! A decent amount of E46 guys go with those setups, but this car is a LOT lighter and has less weight in the rear so traction will be an ongoing concern for me as I set up this car.
Yep! I had a ton of people asking to buy that rear dropout but I knew I needed it for the 318ti. It's interesting to note that BMW didn't upgrade the brakes when the Z3 went from the S52 to the S54. Not sure if this was an engineering or a financial decision, though.
Past Builds:
Current Fleet:
Just a minor update, stopped by Rogue Engineering over my lunch break (5 miles from where I work, very nice) and picked up this batch:
- Stainless clutch line
- Transmission mounts
- Clutch pedal bushings (god damn squeaking)
They'll do my brake lines too when I get them together. They actually build these on site, which is cool for custom work.
Past Builds:
Current Fleet:
why cant this be any faster??
Can't wait to see the finished product! Will be insane
Definitely bought my e36 M3 rear bumper from you last spring. Saw the car then and loved it. This is an awesome build. Glad to see more swapped ti's on the road.
Granted the ti is lightweight, shorter overall than the other e36s, but there is still a lot of weight in the rear. The rear hatch, for example, is all HEAVY glass, the diff itself adds ~30lbs over the small case, axles are heavier, brakes are MUCH heavier, cali-top is heavy, and they were either 51 or 52 percent heavy from the factory with the 4 cylinder fully equipped. I assume youre removing the spare tire? If not, theres a bit more weight.
From my own experiences, the car handles a bit differently with just the rear diff and axle changeover, not only because of LSD but the weight shifting as well. Its very easy to put the power down, in a straight line, but around a corner, its a bit more difficult but what car isnt.
Dont forget to check your diff sheetmetal hanger tabs for cracks and tears, a good idea to reinforce them if youre using poly for the diff ear and subframe as they stress the body at the particular point.
My solution
Thanks for the insight man.
The whole Z3M dropout will definitely add weight and I'll be putting everything on a scale just to see how much that is. I do believe it's rather necessary, however, seeing the 318ti rear was not designed to see real power. I admit the trailing arms and subframe are more of a nice-ety than a necessity, but they work well with the larger brakes and diff/axles. I'm guessing the weight difference on the diff/axles is somewhere around 30 lbs like you said, and maybe another 15 lbs on calipers/rotors. The cali top actually isn't very heavy, I've pulled it several times. The conventional sunroof assembly is easily double the weight.
I've been looking into diff options and have been talking to my friends with M Coupes. What did you use for sheet metal on it? Something custom or did you just buy the OEM diff mount and weld it in (#4 below)?
My goal is to get the car down to the 26XX lb range once swapped without a driver. Should be interesting. What's your V8 weighing in at right now Tony?
Thanks man! You were probably there when I was swapping my M3, right?
Past Builds:
Current Fleet:
OP is a fool...I like that and I support this
Just to be sure, I had to google the definition of epic. The results were:
Adj. -
heroic; majestic; impressively great: 'the epic events of the war.'
of unusually great size or extent: 'a crime wave of epic proportions.'
I'll say this qualifies.
Carry on OP, carry on
Number 4 is the basic weld in reinforcement, but i went in through the actual body and welded in the new supports for the dual ear solution. Most people just double up on the single ear and are fine running it that way.
The LM7 weighed in at 2980, the ls was only 2840, which is nearly dead on stock weight, but i also had subs, two extra batteries, and no a/c installed at the same time. As it sits now, it should only weigh around 2600 since i deleted the sunroof for a carbon fiber roof, removed the rear wiper assembly, moved the battery to the rear and used a 51R battery, removed the ebrake system for an electric ebrake and installed larger, ligther brakes, and a few other pieces.
