Hey guys, I know a bunch of you have been interested in the lines in this video so I decided to put this thread up. If you don't know about these lines check out the video. A question I often get is:
If I take my ABS unit out, don't I need a proportioning valve of some sort? The answer is no, your master cylinder is a proportioning valve, everything you need is in this kit.
Here's a couple reason you'd need to do this:
Your brakes never seem to be as dialed as you want
Your ABS module is bad
Your doing a bunch of tracking or autocrossing(and your preference is no ABS)
Whether you know it or not, your ABS unit is probably not working to the standard it was 20 years ago...
It would be nice to have a kit that deletes all those extra lines
bump
I'm I wrong in thinking it will be a massive pain bleeding that air out of those lines? Especially to the passenger side front?
