Results 1 to 2 of 2
Thread: CVV Valve needs to be replaced - Indy mechanic on the North Shore(Wakefield) area?
    Wakefield, MA
    2004 330xi
    Good Indy mechanic in North Shore(Wakefield) area?
    My CVV valve has all the signs it needs to be replaced(2004 330xi w/81K miles). I just got quoted $1,400 from the dealer(BMW Peabody) to replace the CVV and hoses attached to it. They also said a tech may recommend to replace other parts like the valve cover gasket, oil filter housing gasket, and disa valve. All of these items were quoted as $2,060 to replace by the dealer.
    It's a pretty steep repair bill and I'm not mechanically inclined to DIY(I've seen videos on replacing the cvv) for risk of messing up my car.
    Does anybody have a recommendation for a good indy mechanic around Wakefield, MA to check with?
    Thanks,
    Mike
    Oct 2008
    ca
    holy crap 1400 for the ccv. an indy would probably be around 500 id think. maybe a little more.
    even if you arent mechanically inclined the valve cover gasket is easy to do. disa valve is easy too. ofhg is a little more involved.
    this link will help you figure out whats leaking and if it needs to be replaced.
    http://forum.e46fanatics.com/showthread.php?t=882732
