This is just the stuff dreams are made of!
~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
very cool. Glad to see progress is still happening on this.
Awesome work and a LOT of it. You should sell a kit, recover some of that time you put in.
Certainly interesting project.
Thank god there was finally a proper rear diffuser at the rear end. I was horrified until that showed.
But why not carbon fiber? You have molds and it would really only make sense. EDIT: I found out why.
Z3 & E36 RamAir systems, send private message for more information.
Just looking in on his thread. Very very cool stuff. A lot of patience and skill gone into this project.
If you don't mind a question,,, who did the fabrication on your rear trailing arms and subframe (conversion to rod ends).
I have that project sitting on a bench about ready to start (its been ready to start for about 2 years at least).
If you are willing to share the info I'd appreciate any details of the process you used and / or who did the mods if you farmed it out, or any more detailed photos.
Thanks in advance.
jimmy p.
jimmy p.
88 E30 M3 Zinnoberot - street
88 E30 M3 Lachsilber - SCCA SPU
87 E30 M3 Prodrive British Touring Car 2.0 Litre
04 Ford F350 - V10
06 Audi A3 Brilliant Red / 2.0 / DSG
'99 M Coupe Supercharged autox/track toy* available for purchase, 2016 MX5 Miata daily driven, '11 Mazdaspeed 3 - dog hauler
*///Monster Coupe: FH/Race USA custom widebody front, 18 X 10.5 et 27 Apex EC-7 wheels 285/30/18
Active Autowerks Super Charger C30-94- 300 whp, SnowPerf Water Alcohol injection, AA Track Pipe, Supertrapp Exhaust, Ground Control double adj struts, Adj RD sway bars front and rear, Quaife 3.64 Torque Biasing LSD, Recaro Pole Position seats, HMS Harness Bar & Schroth 5pt & 4 pt Harness
I like the unicorns.
'99 Z3 Coupe - Jet Black/Black (1-of-114)
'99 M Coupe - Estoril Blue/Black (1-of-82)
'03 540iT - Sterling Gray/Black (1-of-24)
'16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
Can someone point me in a direction to find more info about that a-arm modification?
I am VERY interested in this.
a closer look at the photo it seems he is still utilizing the IE engineering toe & camber system. I was hoping that the use of the spherical bearing along with some other mechanism would negate the need of the camber/toe plates and eccentric bolts.
It can be eliminated it you implement the 1st gen E30M3 Gruppe A rear subframe modifications, but that takes it to another level of fabrication.
Retaining the more common eccentric bolt / slotted hole adjustments at the subframe makes the project very much easier.
Not sure how familiar you are with E30 M3 Gruppe A rear subframes and trailing arms but its pretty well documented on the various E30 M3 sites.
jimmy p.
04 Ford F350 - V10
Thank you Jimmy! This is only the second time someone has mentioned that to me. I need to go research that out.
I am not happy with this eccentric bolt system on this subframe. It works, but it is a PIA to access to adjust or even just ensure it is tight. After having one of the nuts back off I lack confidence in tracking the car.
correction. this is the second time I've heard about this from YOU!
I just realized who you are ;-)
dear god
Is there a possibility to have any of these body pieces made for a price? I'm building a M coupe for the track that had a front end accident and I need to replace these pieces. You have done a great job and I love to get my hands on these. I sent you a PM as well. ThanksOriginally Posted by Cory M
bump
bump
Cool! I hope one of you guys can get in touch with the owner and get some updates. Thanks!
This is Nick's helmet painting business page. His contact info is on there as well.
https://www.facebook.com/NRVSG/
Don't bug Nick. He's got my helmet right now and I need it back in two weeks :-)
