Page 8 of 10 FirstFirst 12345678910 LastLast
Results 176 to 200 of 230
Thread: Z3 Wide Body
  1. #176
    Apr 2014
    Europe - Belgium
    1999 BMW Z3 Roadster 2.8
    Unfortunately (until now) no sharing of the details of the build.
    Would have been nice to know the weight of the cloth that has gone in the parts.
    Koen
  2. #177
    Columbia, Worst Carolina
    2000 M-Coupe, 1994 SE-R
    Feed us.
  3. #178
    May 2009
    Blacksburg, VA
    Mini Cooper S, C-Mod Z3
    It's time for an update. I hope you're not disappointed by the progress; I assure you I'm doing the best I can given the circumstances.
    To answer Koen's questions, the glass is 2x2 twill woven fiberglass; 8.5 ounces per square yard. Thickness depends on the part and in fact the location on the part. For the most part, 4 layers does the trick. The door and the hood are both reinforced. The hood uses an 1/8" thick divinycell foam core, while the door has an inner structure built around my NASCAR bars.
    Photos show the bodywork hung on the car. There's lots of trimming, sanding, cleaning, and painting to be done, but the majority of the mounting is done.
    While I was at it I cut out the spare tire well, losing another 10 or so pounds. Speaking of weight, the hood is going to weigh approximately 22 lbs. Not bad for fiberglass.
    I'm going to be listing a few things in the classified's section so do check it out if you're in the market for some lightly used (and well cared for) seats, harnesses, and suspension.
    ______________________________
    Nick Large
  4. #179
    Dec 2004
    Portland, OR
    1992 325i
    Out of curiosity, why didn't you use carbon fiber instead of fiber glass? I did read the entire thread but it's been a while.
    The car looks great. Can't wait to see the final product.
  5. #180
    mcoupemindy's Avatar
    mcoupemindy is offline Senior Member BMW CCA Member
    Supporting Vendor
    Jan 2005
    Haymarket, VA
    '99 M Coupe
    So ... Much ... Awesome!
  6. #181
    Feb 2013
    MD, USA
    2005 M3 Coupe
    Quote Originally Posted by Joshh View Post
    Fiberglass is generally $2-3 per yard, cheap carbon fiber is $25 per yard. I'd speculate it was cost driven. Carbon fiber would be overkill for this application.
  7. #182
    May 2009
    Blacksburg, VA
    Quote Originally Posted by dmw16 View Post
    Bingo. The woven fiberglass I'm using is about $7.50 a yard. VERY cheap carbon (with fiberglass tracers and everything) is $25. The decent stuff is approaching $40 a yard. Being my first time doing large fiberglass parts, I knew I would be creating a lot of waste and possibly screwing up some parts. If (when) I do this again I will use carbon. For now I think I might just pick up a few yards for the smaller parts. I'm interested to know how it is to work with.
    Nick Large
  8. #183
    Feb 2013
    MD, USA
    2005 M3 Coupe
    Quote Originally Posted by Calaway16 View Post
    Nick, if you pick up resin pre-empregnanted (aka prepreg) carbon fiber I think you'll find it easier than fiberglass. Carbon stays together better than fiberglass...especially if the fiberglass doesn't have the resin already in it.
    A few things to note on working with carbon (sorry if you know this already) but carbon fiber has a strong and weak direction and when laying up parts it's best to alternate between 0 degrees and 45 degrees. I'd suggest doing the 45 degree ply as your first one down as it tends to drape better...that is to say take your ply and turn it 45 degrees from "straight across your tool". Then alternate and try to stay balanced...so 45, 0, 45, 0, 45 would be a good layup and more than strong enough. You could probably do 45, 0, 0, 45 and be good to go. The balanced layup prevents the part from "potato chipping" or curling because it keeps the internal stresses balanced.
    You can oven cure most carbons and have plenty of strength. I am not sure if places sell expired material but you could maybe ask around. It may be a little stiffer (use a hair dryer or heatgun to soften it) but it should be cheaper and again, for this application, no impact to the material system capabilities.
    Sorry if you know all of this already, just figured I'd mention it in case it helps you or someone else.
  9. #184
    Atlanta
    2x 84 318i, 02 M3, etc..
    Wow! What a build.
    318i E30
    & other toys
  10. #185
    Mar 2004
    USA
    96 328is 6.0L
    Need moar updates! Awsomess!
  11. #186
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    Bumping this from the dead as I REALLY wanna see the finished product!
  12. #187
    Apr 2014
    Europe - Belgium
    Hello,
    Any pictures of the fixation points?
    How did you fix the panels to the chassis? (rear quarter panels, front panels and bumpers)
    Did you use the standard points?
    What about the doors, bonnet and trunk?
    any pictures about that?
    Thanks for the info,
    Koen
  13. #188
    Bump
  14. #189
    Any progress?
  15. #190
    May 2009
    Blacksburg, VA
    Yes there has been slow progress. I'll put some new photos up when I get around to it this weekend.
    Nick Large
  16. #191
    May 2015
    Providence, RI
    2006 BMW 325i
    Unbelievable! I can't even fathom tackling a project like this. Keep the awesome work coming! subbed!
  17. #192
    Los Angeles, CA
    Bump it up. Any further movement?
  18. #193
    Bergenfield, NJ
    '99 M3 '10 X5 35d '02 M3
    The people (politely) demand updates!
  19. #194
    May 2009
    Blacksburg, VA
    Nick Large
  20. #195
    Vancouver, BC Ca
    1993 325is
    Ho Lee Fok! Nice update!!!
  21. #196
    May 2009
    Blacksburg, VA
    The design has continued to evolve over the past several months.
    The muffler is housed in an isolated and vented chamber; air will be drawn through a duct from beneath the car and will exit through the vent the exhaust tip passes through, cooling the muffler.
    Checking the splitter plug with the bumper and undertray. The plug will be molded and the finished parts will be out of carbon and foam core. The fender liners are in progress. They, too will be molded and built out of carbon and kevlar.
    Nick Large
  22. #197
    Feb 2002
    Houston, Tehas
    99 Mcoupe
    Nice!
    That's really starting to look killer, the rear diffuser is massive.
  23. #198
    Jan 2016
    Harrisburg, NC
    1999 BMW M3
    Holy cow, that rear diffuser!
  24. #199
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    this is tremendous in every possible way.
    instant grams: doktor_b
  25. #200
    Mar 2010
    west
    ModelS;CayenneD;M5;MCx2
    Great work Nick... Keep it up.
    Maybe u can join at Octoberfest/Laguna!!! Dorkfest will be happening at the same time.
    Best,
    Patrick Avakian
    #368 JP
