PRICE CUT on ALL FABRICS
This thread was worthy of a bump. Oh look what I just did.
540i-sold, 325is-sold, Econo boat 2011 Civic-sold
Car ADD
Current death trap: 08 V6 Malibu
Just what I was looking for, thanks!
LSCman (if you're still answering this thread),
My 2002 540i sport package is coming up for a suspension upgrade. I saw your recommendation for Koni's and Eibachs. Trouble is, I'm just a little apprehensive about the Eibachs. Reason being is that I put Bilstein Sports and Eibachs on my 2000 528 and I don't like it because it is now bone-jarringly stiff.
I don't mind something that's a little stiffer than stock, but will I end up with something similar (as I did with my 528-too stiff) with your setup...? Thanks for all your help!
Shawn
Since it's been bumped so many times before...
I see all the posts about the M5 and 540i springs being possibly the same and how both cars came with crappy boge shocks, but I don't think this was answered:
Are M5 and 540i shocks interchangeable? Like say, if one were to buy a set of aftermarket shocks or coilovers for for an M5, would he be able to mount them on to his 540i?
Ive never seen posts saying M5 and 540 springs are the same...
AFAIK its pretty well known that no, M5 springs will not work on a 540 and vice-versa. M5 is more front-heavy. A 540 with M5 suspension will be higher (a LOT higher in the front) than the stock 540 and will handle in a very silly way thanks to differing spring rates.
I have a 2003 540ia without the sport option do you know what differential gear ratio I have. I have a spare LSD M5 rear end, drive shaft and half shafts will it be worth it to install.
They bolt up. The weight difference between an early 540 and later M5 approaches 300lbs, so the M5 setup on a 540i will look like an off road 4wd package. A fully loaded 2003 540i will weigh close to an M5.
Yes, they are. 540s with the M-Sport Suspension II option code came with M5 struts/shocks. I know, as I removed them from my car when I upgraded to the Bilstein B14 PSS kit. BTW, the Bilstein B14 PSS kit is spec'd by Bilstein to work perfectly fine with EITHER the 540 or M5.
There are no aftermarket strut/shocks made specifically for the M5 that I am aware of...but there are several coilover products. And most all of them are specified by the manufacturers to work on both M5 and 540.
2001 540 M-Sport (cdn), ST X (KW) coilovers, H&R 15mm spacers, Eibach anti roll bars (28mm/18mm), Beastpower rear antiroll bar brackets, M5 rear chassis reinforcements (traction rods), Strong Strut front upper strut bar, Dinan Stage 1 software, factory M-Audio subs, Bavsound speaker upgrade, Bluebus bluetooth integration, Stop Tech SS brake lines, ATE coated brake rotors, ATE ceramic brake pads.
I have a 2003 540 sport with the M TECH II package. I want to keep it all factory original despite the negative comments about SACHS. What shocks do I use and where do I get them? This is very confusing since they are supposedly different than the M5 or other 540 sport shocks. thanks a lot!
No. Your shocks should be the same as the M5 because you have the Tech II package. Did you check Realoem? See here This is for the front axle. You have the M-sport II suspension. The part numbers are there. Goto FCPEuro, ECSTuning, EEuroparts or one of the other online places and check out prices.
gmak: The Good, the Bad, and the Ugly. A journey with my new-to-me 2000 540i
"Working on a BMW E39 is the best way to run out of time."
Only the front springs are different between the two. Here are some quick ref numbers for you.
M-Sport II Suspension
Front
-Springs - 31332229070 - Unique to M-Tech II
-Struts - 31312229612 - Same as M5
Rear
-Springs - 33532229176 - Same as M5
-Shocks - 33522229126 - Same as M5
M5 Suspension
Front
-Springs - 31332229071 - M5 only
-Struts - 31312229612 - Same as M-Tech II
Rear
-Springs - 33532229176 - same as M-Tech II
-Shocks - 33522229126 - Same as M-Tech II
2003 540i/6
Thanks a lot waters17. exactly what i needed.
The cheapest I found was from BMW of South Atlanta.For all 4, they were 200$ less than any other. FCP euro priced matched. thanks again.
this is the information I have been looking for. thank you. I was looking for a M5 to swap the subframe and suspension onto my 525it. so if I read this right. as long as I upgrade my brakes , springs & shocks and sway bar the only thing I would need is the rear diff. so I could just pick up a 540i frame and suspension and use that and save me a lot of money instead of buying an M5 set up. then just buy an M5 diff and i would be good.
Just some info on my plan
i have a 525it I'm dropping a 2003 M5 engine into it and wanted to convert it to a full M5 wagon. starting with the suspension. and I will slowly upgrade body and interior and all the other upgrades & options.
