Hey guys,
I changed the cooling system yesterday. These parts were changed:
RADIATOR
Radiator Hose upper
Radiator Hose lower
Expansion Tank Cap
Coolant Expansion Tank
COOLANT TEMPERATURE SENSOR (the one that goes to DME)
Thermostat with Housing and O-Ring
Water pump was recently done as well
System was bled correctly. I drove the car around yesteday all evening, blew hot air, everything was great. Started the car in the morning and received the message CHECK COOLANT LEVEL. What could the causes be?
Check coolant level every few days and top off as needed. The coolant has circulated through the system.
If your new expansion tank didn't come with a level sensor I'd suggest replacing that.
It is also possible that if the tank came with a sensor it may be bad.
The PO of my car replaced the level sensor before I bought the car and it wasn't 3 months later that I was getting level check warnings that required a new sensor to resolve.
You did transfer over your coolant level sensor to the new expansion tank, right?
These cars are tough to bleed, so it might take a week or 2 of driving and topping off before it levels off.
4-5hrs is not enough for the coolant to unexpand(contract) and be at the lowest level. When I;ve had to top off I do it first thing in the morning after sitting overnight.
If you should notice your temp gauge swinging up to hot then back to normal or no heat coming from the heater at times a bleed is in order. But an otherwise healthy and properly bled system shouldn't need any significant topping.
I believe I overfilled the expansion tank today. I was pouring coolant in to in the morning and it was a bit dark, I wanted to pour to the side of the float level but I was pouring on it. When I stopped pouring it to the top and was fully up. When the cooling system is completely cold the top of the float level should be level the bottle neck of the expansion tank, correct? The float is fully up... how do I remove some coolant?
Open the expansion tank cap and squeeze upper and lower rad hose at the same time?
Do you have a turkey baster in the kitchen? Just suck a bulb or 2 worth out. It won't take much to get it back to the correct level.
Ok now I am confused. When I opened the expansion tank today at lunch the float came to the top but I looked and couldn't see any coolant in there. Float level came to top... where would I insert the turkey baster to suck out some coolant? I also squeezed the upper & lower rad hose, I felt coolant in there because they were a hard tough to squeeze (resistance) but no coolant came out of the expansion tank.
Link to photo of expansion tank: http://i.imgur.com/ewQwI.jpg
EDIT: Just a note, I did what I described above after the car has been sitting for 5 hours... when I touched the expansion tank it EVER so slightly warm, just a tad bit.
