Results 1 to 25 of 25
Thread: No sound from Driver side speakers
    Dec 2012
    Beloit, Wi.
    1995 BMW 530i
    So i have no sound at all from the driver side of the car. passanger side works great but i dont get any sound from the driver side. Also when i adjust the fade and balance right/back keeps passanger side speakers working. if i go back/left they dont work. Would this be a radio problem or the factory amp in the car?
    Dec 2012
    Beloit, Wi.
    1995 BMW 530i
    Also where is the factory amp if there is one?
    Jul 2010
    Vallejo, CA
    '95 540iA
    Amp is behind the left carpeted panel in the trunk for sedans.
    Quote Originally Posted by 1990525i View Post
    the bees knees
    Dec 2012
    Beloit, Wi.
    1995 BMW 530i
    I looked back there, was not behind that.
    Kansas City MO
    Too Many
    It should be there... In my past travels, its usually been the head unit, or even a loose connection. I'd check all the radio and amp connections first, then try the head unit.
    Dec 2012
    Beloit, Wi.
    1995 BMW 530i
    Guess ill have to pull the whole panel off and not try to pull it out to look behind. But im pretty sure i had it out far enough and there was no amp behind there.
    Kansas City MO
    Too Many
    Quote Originally Posted by bcitymodz View Post
    Just ran out to my shop and took a pic for you...
    Dec 2012
    Beloit, Wi.
    1995 BMW 530i
    Yea i wasnt even looking there, i was looking more in the back. Thank you, ill go check that all now.
    Kansas City MO
    Too Many
    Jul 2010
    Vallejo, CA
    '95 540iA
    Yup. amp is big. Can't miss it. Keep diggin.
    the bees knees
    Dec 2012
    Beloit, Wi.
    1995 BMW 530i
    Yea I found it. That metal plate was hiding it from me. I'm gonna pull it in the garage tmro and check the connections and see if that's it. I have a new radio to put in just waiting for the adapter so I can put it in. Hopefully that fixes the no sound on the driver side.
    Denver, CO
    Quote Originally Posted by HE53 View Post
    +1 when I bought my e34 the driver corner never worked and all other speaker levels were pretty messed up. I thought it was the hack job on the harness, but when I replaced the HU with CD43 all was fixed.
    Oct 2012
    Fairfax, VA
    09/1991 BMW M5
    Keep me posted as I have the exact same problem, I swapped amps (thanks TGreene) didnt solve the problem.
    Still no sound from the Drivers side speakers, pass side work fine front/rear.
    Best of luck, I ended up not caring after two weekend of tracing wires/hunting fuses and just listen to the engine again (less commercials that way too ..)
    [09/1991 ///M5 BK06359]
    Kansas City MO
    Too Many
    Quote Originally Posted by peterjk4 View Post
    Did you try a different head unit?
    Oct 2012
    Fairfax, VA
    09/1991 BMW M5
    errrr umm..no not yet..
    I was hoping someone else could confirm that being the fix
    Denver, CO
    Well, you have at lease two people in the thread whos problems were fixed with a new HU...
    Know anybody in the area that would allow you to swap HU's to confirm?
    Tustin, CA
    2002 BMW Streetcarver,
    I have the same problem. Mine cut in and out from time to time. I have swapped amps with a spare i have and the problem is still there. The old BMW head units always seem to have funky ways of going out.
    Dec 2012
    Mcallen, Tx
    89 BMW 535i/5-speed
    Hey, I started out with the same problem and found that it is in fact the head unit. I found the fix by wiggling the volume button like a joystick while raising the volume at the same time and then the sound came back.
    Dec 2012
    Beloit, Wi.
    1995 BMW 530i
    Ill let you know if it works when i get the connector plug to hook up the new radio.
    Oct 2012
    Fairfax, VA
    09/1991 BMW M5
    Appreciate it, now thats its out in the open that the HU's go bad I may tackle it this weekend.
    TIA
    Mar 2008
    USA
    F80 M3, 95 325is
    Your speaker might be blown. Have you tried swapping speakers from left to right?
    Lazy Saturday drive in my E34: https://www.youtube.com/watch?v=TnzvZgPnOos
    Oct 2012
    Fairfax, VA
    09/1991 BMW M5
    Quote Originally Posted by SpeedsterBek View Post
    Tried that with the dash and kickpanel speakers, none were blown.
    Dec 2012
    Beloit, Wi.
    1995 BMW 530i
    I can confirm that changing the headunit did fix my problem. I have sound from all speakers now and they sound great.
    Mar 2012
    Houston, TX
    1994 BMW 525IT Slick top
    Ok so my problem is that the sound would be really crappy and then kick in all of a sudden, where now, the sound only comes from the right and is very weak. I assumed the amp but now thinking the Aftermarket head unit but its not more than 3 years old.
    Feb 2013
    ft irwin, ca
    1990 bmw 525i
    I had that issue. It turned out to be the equalizer module that plugs into the side of the amp. There are two cards inside it. One had an open resistor and the other was good so I plunged it in the side closest to the metal plate and now it sounds amazing
