Anyone out there do a differential swap on the 540i? Thoughts?
I have an 02 540i/6. Pardon what may be a stupid question, but wouldn't the shorter gearing on the differential just be equivalent to you holding your shifts for longer / revving higher?
Not in 1st or 6th gear of course - but for the gears in between...
Downside: you'll have shorter 1st and higher rpms at 6th (more gas consumed).
Upside: more torque, better acceleration.
----- NervoS aka Nervous -----
if you use an auto 540 i believe certain years had 3.15's
but if you use one from an m5 its not only 11% tighter gearing but also the benefit of limited slip.
~2001 540i/6speed~
Schmiedman M5 headers, SPEC stage2+ kevlar clutch, JBR 11lb lightweight flywheel, ESS Tuning m60 manifold software tune, 3" SS freeflow OBX catback, afe cold air intake, m60 intake manifold, Cdv delete, powerflex urethane sway bar bushings, M5 rear sway bar ,Autozone replacement driver side blinker light bulb, 545 short shifter zhp weighted, "dsc off" sticker, m5 3.15 lsd differential, m5 chassis rods, akebono ceramic pads, G2 caliper epoxy, ecs braided lines, BC-Racing br-plus series w/swift springs 8/6~On the night that I go back in time, you will be shot by terrorists. Please take whatever precautions are necessary to prevent this terrible disaster.
Hit me up if you want a nice 3.15 open diff Came from an iA car, works very good, mileage less than 100k
'99 BMW 540i6 L33 5.3, PRC Heads, E-force supercharged
http://forums.bimmerforums.com/forum....php?t=1674320
and if you have it gold plated you can be a baller like topaz
its purely for corrosion resistance.
~2001 540i/6speed~
what do used open 3.15s run around here? A buddy of mine has a few that I may help him dispose of. i know shipping would prob run 60-80$ at least though.
Check either ebay or the classifieds section on this site for comparisons
~2001 540i/6speed~
That is a beautiful differential Topaz. I read your build thread, nice work.
unfortunately the only person that will ever see it is the guy at the alignment shop
~2001 540i/6speed~
I wouldn't bother going to 3.15 open unless its all you can find and your 2.81 is shot. Adding more mechanical advantage (3.15 vs 2.81) but no additional grip (LSD) isn't the best idea in a vehicle that already breaks traction fairly easily.
2001 330Cic/A in the same color combo is "Her" ride.
Nothing to do with holding shifts longer or revving higher. It will cut the mph of each gear,but get you down the road quicker and usually about a car space or two ahead of where you were with the old rear. You will be at a higher rpm while cruising at like 60 on the highway tho. So if you were at 2300 rpm at 60 with your stock rear ,then going to a 3.15 rear you may be at like 2500 rpms at 60 mph now. You will notice the biggest difference when taking off from a stop. You will be about a car space ahead of where you were before,but you may only be able to hit 25 mph in first gear at the max now. Get it?
what are you talking about "tighter gearing"? a 3:15 ratio is a 3:15 ratio. The m5 is a limited slip version though,giving better traction.
I would love a 3.15 lsd, But $600+ can be better spend on so many things for ME.
^^ By Tighter gearing he just means that its... tighter, Shorter, Not as long as the 2.xx
Not to thread jack, But are there any other options? From say a 7 series, Or anything?
Didn't know if 3.15 is the shortest option.
2300 vs 2500 rpm is nothing for the low end performance you gain.
My friends domestic has a 4.10 rear and in 1st (Auto) is dips the rear end of the car....
These are NOTHING compared to my Japanese Tranny I had shipped over for my Honda, 5,400 RPM at 75mph. :
It's also Nothing compared to the e39. Gah I love our 540I/6's!
By tighter gearing i mean vs stock gearing which is 2.81.
The observed difference will be faster acceleration but each of the individual gears will hit redline at a lower mph than before. Squeeze the gears tighter you get more acceleration with a lower top speed. Open the gears up you get a higher top speed but less acceleration.
Kinda like changing the sprocket size on your bicycle.
~2001 540i/6speed~
Last edited by ElleShooTiger; 01-05-2013 at 05:29 PM. Reason: Automerged Doublepost
540 sport automatics came with 3:15... You can buy mine
2003 ///M5. ~ Jet Black/ Le Mans Blue
RK Supercharged @ 501wheel horsepower/ 419lbs torque
Supersprint Headers
CNS Lightweight dm flywheel/ Spec clutch
ST coilovers
Eibach Rear Sway bar/Beast Power Brackets
Drilled slotted Rotors/Akebono Euro pads
Magnaflow 14816 Mufflers
Michelin Pilot supersports
Supersprint Headers
ST coilovers
I installed a 2.93 from an e38 740 in my 97 540, made a minor difference in acceleration, but did not have an impact on mileage.
If using an e38 diff, you must change the rear cover to the e39 cover for installation, great time to inspect internal components as well.
The 2.93 diff was free, the 3.15 would be a better swap, a 3.15 LSD even better.
Topaz - nice job sir
Regards,
Brian
Cave Creek, AZ
