Here is my latest POS acquisition - 05/85
It has roughly 400,000 miles per the Carfax. It had 270k in 1997! Drive seat is destroyed. It has the large screen rear Becker radio remote. Rear trailing arm bushings wasted along with subframe bushings. Strut bearings shot. PPO swapped on a non 'TURBO' cyl head...it has a popped gasket currently. Highest compression number is 125psi, lowest is 70psi. Awesome! Milkshake in the oil pan
https://www.youtube.com/watch?v=pGL2rytTraA
Plugged up 733i cat, rusted and leaking 745i resonator and muffler. Came with a dead chipped Jarmo ECU and old Team745i wastegate. I redid most of the bottom end with the kid before the HG failed...chains, gaskets, etc. It has a Joe G reman trans. Heater core bypassed, radiator leaks.
I traded the 735i for this, not sure why. It does have the nifty tow hitch.
Type
ValueVIN WBAFJ91090875xxxx Type code 6991 Type 745 I (EUR) E series E23 () Series 7 Type LIM Steering LL Doors 4 Engine M30 Displacement 3.50 Power 0 Drive HECK Transmission AUT Colour SCHWARZ (086) Upholstery (0180) Prod.date 1985-05-02
Code Description (interface) Description (EPC)S209A SPERRDIFFERENTIAL 25% Differential lock 25% S301A DIEBSTAHLWARNANLAGE MIT ZV Alarm systems S350A WAERMESCHUTZGLAS GRUEN, RUNDUM Therm. insulat. glass green S403A GLASDACH, ELEKTRISCH Glass roof, electrical S421 FEUERLOESCHER 2 KG HALON Fire extinguisher S427 WARNDREIECK MIT HALTERUNG Warning triangle S440A NICHTRAUCHERPAKET non-smoker package S459A SITZVERSTELLUNG, ELEKTR.MIT MEMORY Seat adjuster, electric, with memory S460A KOMFORTSITZE IM FOND, ELEKTRISCH ELECTR.REAR SEAT ADJUSTMENT S494A SITZHEIZUNG FUER FAHRER/BEIFAHRER Seat heating driver/passenger S496A SITZHEIZUNG FUER FONDSITZE Seat heating, rear S500A SCHEINW.WASCHANL./INTENSIVREINIGUNG Headlight wipe/wash/Intensive cleaning S534A KLIMAAUTOMATIK Automatic air conditioning S540A GESCHWINDIGKEITSREGELUNG Cruise control S915A nur Boden konserviert Dummy-SALAPA
I make E23 parts.
10/1984 745i
11/1984 745i
11/1984 735i (10:1-265/6)
That would make a great parts car for someone else around here who might want the diff and the wastegate....who shall not be named...
Steve H.
--Jay3->Sic gorgiamus allos subjectatos nunc
84 €735i manual, 88 528e/i
Motronic 1 and 1.3 wiring
Transmission & Diff gearing sheet
please don't mind the missing door handle
1982 BMW 745i e23 086 schwarz 1991 BMW e36 325i 252 Calypsorot-metallic
What is all done to the suspension?
http://s1113.photobucket.com/user/Hu.../86%20Mudslide
Still cant figure out how to upload just the pictures, so here ya go!
Your car is awesome... id be interested in that suspension setup walk through. What parts you used for the whole thing.
His build thread is over on stancenation.com
I made a thread on the build.
http://www.stanceworks.com/forums/sh...ad.php?t=23100
My 11/84 I scored in May I guess. It was being parted out by a local guy, he had to move it NOW so only sold the manifold, wastegate, and ECUs before I just took the entire vehicle. The rest that is missing are parts I pulled when it was in 'part out' stage by him. HA. K27 still good, good stock exhaust system, catalyst was scrapped by me. Yep, I even have the 'TURBO' cylinder head.
Motor covered in surface rust, was sitting inside a hanger for a decade. Still turns over by hand! Soaked it with Kroil then covered it with bearing grease, will need a hone to be reused...not a big deal. Miles seem accurate due to title. I am the third owner, PO owned it from 1991 until 2014. One key, chrome TRXs (hot shit!), gross DOT lamps, and factory wheel locks. Very straight body and paint looks decent.
Oddly optioned, only came with front speakers! Go figure.
Data for vehicle identification number: WBAFJ91060875xxxx Model description: 745 I Market: Europa Type: 6991 E-Code: E23 Chassis: Limousine Steering: links Doors: 4 Engine: M30 - 3,50l (0kW) Drive: Heckantrieb Transmission: automatisch Body Color: Cosmosblau Metallic (185) Upholstery: (0204) Production date: 02.11.1984
Code Sonderausstattung Optional Equipment S209A Sperrdifferenzial Differential lock 25% S219A Sport-Lederlenkrad 380 mm Sport leather steering wheel, 380 mm S290A BMW LM Rad Sternspeiche 44 BMW light-alloy wheel star spokes 44 S314A Aussenspiegel / Fahrerschloss beheizt Door mirror / driver's lock, heated S350A Wärmeschutzglas grün Therm. insulat. glass green S365A Heckscheibe Verbundglas Rear window, laminated glass S403A Glasdach elektrisch Glass roof, electrical S411A Fensterheber elektrisch vorne/hinten Window lifts,electric,front/rear S427 Warndreieck mit Halterung Warning triangle with bracket S458A Sitzverstellung vorne elektrisch Electr. front seat adjustment S460A Komfortsitz im Fond elektr.verstellbar Comfort seat, rear, electr. adjustable S472A Armlehne vorne Fahrer/Beifahrer Armrest, front, driver/passenger S534A Klimaautomatik Automatic air conditioning S540A Geschwindigkeitsregelung Cruise control S915A Entfall Aussenhautkonservierung Delete clear coat S979 Velours-Fussmatten vorn und hinten Floor mats, front and rear
I make E23 parts.
10/1984 745i
11/1984 745i
There are some sweet looking rides on here!
Oh and yay! post #10 for me. Time to post some pics...
I see projects, everywhere!
My 735-83 summer 2005
2012 year
-86 728iA
Full M60B40 + 5HP30 conversion, buffalo interior, BBS RC 8" ET10 & 9" ET19
AWESOME BMW M60 swap!
I make E23 parts.
10/1984 745i
11/1984 745i
That M60 swapped car needs its own thread with more pics/info.
2000 BMW M5 Evolve Alpha-N Tune, Evolve Carbon Fiber CAI's, UUC Short Throw Shifter, Dinan Front STB, Dinan Rear Sway Bar
2001 BMW 330i Dynavin N7 Pro
1985 BMW 745i 18" Style 37's, Team745i Chip, Getrag 265/6, Clutchmasters FX-300, UUC Short Throw Shifter, Strut Tower Bar, Bilstein HD's ("Build" Thread")(SOLD)
1986 BMW 735i Getrag 265/6 Swap, Strut Tower Bar, Bilstein HD's, Euro F/R Conversion, 3.46 L/S Diff (Scrapped)
2016 Ford Mustang GT Performance Pack Stock
2004 Mercury Marauder Eaton M112, 3.4 Billetflow upper, Accufab SBTB + Plenum, 4.10's, Stainless Works LT's, 2.5" Exhaust, Borla Stingers, FX-R projectors, Addco F/R swaybars
2003 Mercury Marauder JLT CAI, SCT Xcal4, Stainless Works LT's, SW 2.5" Catback
1996 Ford Bronco 4" lift, 35" BFG A/T's, MH1 projectors
That M60 sounds badass!!
06/86 735i Delphin Metallic
11/11 X5 35i Alpineweiss ii
Thanks for the nice comments! I believe that this is only E23 M60 swap currently on the streets. At least one drifting car has been done and one guy from Norway did some sort of swap but car wasn't finished.
This is actually second M60 engine in this car. I tested the concept with M60B30 and drived around year before putting M60B40 in. I can make little story about this car on its own thread later this week or next.
This is gallery with random project pictures
Dinan chip, lowered on B&G S2 springs
what website can i get a good detailed vin reading from?
https://shop.bmw-classic.de/is-bin/I...e=SA_GRAPHICAL
Cars from 01/83 on I think have access to the ASAP information. My 12/82 Ljet does not come up, but someone's 03/83 Ljet 745i does.
I make E23 parts.
10/1984 745i
11/1984 745i
