Results 1 to 13 of 13
Thread: e30 325i 88' oil leak help
    May 2012
    Ottawa, Ont
    1988 325i convertible
    1988 325i cov. This car has a great engine rebuilt by the previous owner. everything seems fine. no leaks. however, one night i went out and did some stupid runs and revved the car for a good 20-25 mins during the run (5000-6000) rpm. which is pretty high for a car at this age. the next day, i realize theres a small "puddle of oil" on the ground below the engine bay. the puddle is around the passenger side towards the front of the car. (just to give you a picture of leaking position). I'm trying to figure which part might be leaking. i cannot locate the exact leak source. can someone please suggest where it could most possibly be leaking after such scenario? i try to assume its the oil pan gasket, but there seems to be oil above the pan gasket on the passenger side of the engine. any constructive comments would help. thanks.
    which part leaks after revving?
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    Two things come to mind. One is the oil pressure switch. That's located at the base of the block on the passenger side. The other likely place is the oil filter housing. Besides the filter gasket and cooler o-rings, there is another part that can fail and start leaking. I can't remember the name but it's #7 in this diagram. http://www.realoem.com/bmw/showparts...29&hg=11&fg=30
    "Howdy, Folks!"
    Jun 2012
    Dahlonega, GA
    1988 325, 1969 2002
    clean and degrease the engine, let it dry, and then let the car idle while you look for a leak.
    1988 325 "super ETA" - Hilde - M52B28 swapped...
    1969 2002 - Griselda - 20VT AWP swap and full resto in progress...
    project blog - http://www.cynicalmotorsport.blogspot.com/
    Dec 2012
    Virginia Piedmont
    1987 BMW 325e sedan
    It's the oil pressure switch
    I had the exact same issue with my 1987 325e; once it was up on the rack it was obvious the oil pressure switch was the culprit. A $15 fix, no big deal.
    Billings, MT
    2013 328i xDrive
    Dye works really good too if you have a black light.
    I wouldn't worry about putting the engine at it's limits, as long as you do it responsibly. I drive my e30 pretty hard and the engine often sees speeds in excess of 5k rpm. It's not an issue if you properly care for the engine.
    Even my e23 sees engine speeds around 5k, but not as often as my e30. It's more of a cruiser than sporty
    -Chris
    My e30 build thread/color change here
    May 2012
    Ottawa, Ont
    Thanks for the input guys, I have also noticed that i have oil stain on the block (Right below Where head gasket should be). BUt i have noticed that since i got the car and the car didn't leak oil before. I have also seen other e30 M20b25's with similar stain on the corner of the block. is that common as well?
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Oh. That leak. Does it look like it's coming from the headgasket right by one of the ridges in the casting? If so, plan on doing the headgasket.
    "Howdy, Folks!"
    Shreveport LA
    '03 530i 5 sp
    Quote Originally Posted by richardodn View Post
    +1. Had the same leak on mine. No other symptoms of a bad head gasket (no overheating, no coolant in oil, etc). Replaced it with OEM part from the dealer last year and no issues since.
    2003 530i -- DD; 1984 Porsche 911 Carrera coupe -- fun car; 1990 325i convertible -- sold; 1974 Porsche 914 2.0 -- sold; 1989 325i sedan -- sold; 1983 633CSi -- sold; 1982 323i -- sold
    Dec 2012
    Walnut creek ca usa
    1989 325i
    Head gasket is same as valve cover gasket?
    Shreveport LA
    '03 530i 5 sp
    Quote Originally Posted by redbeemr View Post
    Unfortunately no.
    Billings, MT
    2013 328i xDrive
    No, the valve cover gasket goes between the valve cover and the head. The head gasket goes between the head and the block.
    -Chris
    Oct 2015
    Maseru Lesotho
    1989 BMW E30 325I
    oil pressure switch e30 325
    [QUOTE=VARick;25698000]I had the exact same issue with my 1987 325e; once it was up on the rack it was obvious the oil pressure
    Jan 2016
    Long beach
    87 bmw 325i vert
    Hey on my 87 325i vert under the whole engine is a dark layer or idk what with dirt im worried its oil that dirt just stuck too, its on the steering rod i think its called too
