Page 5 of 15 FirstFirst 1234567891011121314 ... LastLast
Results 101 to 125 of 364
Thread: The HasenGoeringpfeffer hobo turbo pocket pen med/thread for PHASE III 俳句
  1. #101
    Dallas, TX
    98' M3/4/6T
    Quote Originally Posted by milKt View Post
    KORRECKT.
    What is the "FINAL" result?
    Let's takes a looks ats it, shalls we's?
    Is it when the sound of your car scares a large dog on the side of the road into "filling it's pants"?
    Is it when your whp reaches 600 on a "virtual" vJynodet?
    Is it after....
    I guess by final I mean running and on the dyno. I agree that the "end" is just an imaginary word used to ease those overwhelmed by the current.
    Didn't know dogs wear pants
  2. #102
    Austin, TX
    S13, Turbo M3
    Got this killer idea straight from MikeE36 (Mike Von lastname) out of his slider build thread. M16x1.5 to -6AN for turbo coolant feed from the BLOCK drain, as seen above.)
    The block drain is actually M14x1.5 to looks like -6 AN pictured. I used -4 AN water lines. -6 is big!
    The other side, the coolant ports are M12x1.5 and M14x1.5. Depending on OBD1 or OBD2 head / coolant temp sensor will determine what you do for the feed. (OBD1 uses 1 for DME, 1 for gauge. I used the port for the gauge since I have an aftermarket dash and don't need it)
    Thanks for the credit! Looks good.
    -Mike
    IG: @mikevanshellenbeck
  3. #103
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Quote Originally Posted by MikeE36 View Post
    Thanks for the correction.
    I edited as such.
    Do you remember which OD Rad hose coolant temp sender you used?
    It's either 36mm or 38mm for the OEM rad hose. Who knows "off hand" or has this info memorized?
    I'm switching from the smaller 3/8" heater hose type beneath the manny to the rad adapter type...and do MOST users throw it on the COOLER feed side of the cooling system (coming into the head/eng) or on the outgoing hose?
  4. #104
    Vancouver, B.C., Canada
    '97 M3
    You will want to measure the water temp coming out of the head or better yet the temp in the head like the factory sensor.
    Depending what size your temp sensor threads are and if you have an extra spot in your head you may be able to put the sensor right in the head. My temp sensor is 3/8 NPT which will thread into the metric straight threads in the head. I used an aluminum crush gasket under the head of the fitting and torqued it up tight and have had no issues with leakage since the engine went in. (I do understand that the thread pitch if slightly off and i understand how pipe thread works etc.) I don't have a picture but could take one if you want one.
    Sent from my GTX3582R
  5. #105
    My head does NOT have another open port.
    I wish I had had DON (dcvee) tap my head at that EXTRA spot for this purpose alone.
    I do know I'd prefer to read the coolant at it's "hotter" temps to gauge the danger better. I suppose I'll be slipping the rad hose adapter on the high/driver's side. Sound correct?
    Quote Originally Posted by 1SLWM3 View Post
    Oh yeah. We pronounce them, "pamps".
  6. #106
    San Antonio
    Z3M Coupe & Roadster
    Sounds right to me.
    Excited to see this finished!
  7. #107
    '97 M3
    If your intake is still off then it wouldn't be hard to drill and tap a hole in the head. That's easy peasy stuff.
    I think the top hose is the return from the rad.
  8. #108
    Bellingham, WA
    e30
    The lower hose is the feed (cool) to the pump.
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  9. #109
    Louisville, KY
    turbo m3
    I edited as such.
    I'm switching from the smaller -8AN type beaneath the manny to the rad adapter type...and do MOST users throw it on the COOLER feed side of the cooling system (coming into the head/eng) or on the outgoing hose?
    I like that black piece. Where did you find that?
    This is my signature....
  10. #110
    Quote Originally Posted by Tanks95 View Post
    send sound and video as soon as she is up and running!
    -William
    Oh yeah,
    I am excited about the outer space, rocket sounds,
    the faster spool,
    precise control,
    handsome looks,
    friendly positioning,
    etc
    This ^ and don't forget to put the hip hop in the hippity hip hip hop and don't stop to you bang bang boogie to the rhythm of the boogiety beat.
    Quote Originally Posted by chikinhed View Post
    Intake is ON.
    Quote Originally Posted by wazzu70 View Post
    The heated, less dense, water rises,
    pushing the cooler water down.
    Quote Originally Posted by jajou318 View Post
    Sounds right to me.
    AS am I excited to see your MINTY MOTHER running a turbo "KIT".
    You've got my favorite M Coupe around.
    Quote Originally Posted by BadBoostedBmwM3 View Post
  11. #111
    Jul 2012
    NJ
    E36 M3
    The OD of the water temp sender radiator hose adapter depends on the upper radiator hose. Some upper radiator hoses have the same OD straight threw which youd use a 38mm radiator hose adapter and some hoses are smaller in the mid section so you'll need a 36mm adapter.
    Id also suggest having it place on the upper radiator hose/hot, the water temp sensor itself place at the bottom/facing up of the hose. That way the sensor will be submerged in the coolant.
    If you decide to place the sensor in the head TRM makes an adapter to add a 1/8” NPT sensor just for this purpose. It goes to the right of the two factory temp sensors.
    Its interesting to see how corrosive some Non BMW coolant can be on aluminum cylinder heads.
  12. #112
    Suffolk, Virginia
    35D X5, 335d
    Quote Originally Posted by FISEVEN View Post
    What?
    I have my sensor in the upper hose, if the system is bled and filled properly, the sensor will always be submerged.
    OLD
    E30
    636whp
    1/4 mile: 10.91@144.38
    http://www.youtube.com/watch?v=L_f7fUVqblI
    NEW BUILD
    335d
    520whp
    635wtq
    120.51mph trap speed
  13. #113
    Jul 2012
    NJ
    E36 M3
    Quote Originally Posted by futureroadracer View Post
    What?
    The senor is there to monitor water temp and most importantly needed if your cooling system fails, right? Ok so in that case if your system does have air (or another issue) wouldn't it be best (well second best other than attached to the head) to have the sensor at the bottom of the upper hose facing up submerged in what coolant is there (to get a better reading)? Id think so.
  14. #114
    Suffolk, Virginia
    35D X5, 335d
    The senor is there to monitor water temp and most importantly needed if your cooling system fails, right? Ok so in that case if your system does have air wouldn't it be best (well second best other than attached to the head) to have the sensor at the bottom of the upper hose facing up submerged in what coolant is there (to get a better reading)? Id think so.
    FISEVEN-Good luck with your car.
    OP- I've run a temp sensor for a while. Mine's in a steel pipe that I use in place of the upper house. My upper radiator hose is always full of water too. That said, you'll likely have a challenge trying to fit the sensor from the bottom as the accessory belt will likely interfere. I know with my set up, there's little to no room. I do run a mechanical sensor though.
    OLD
    E30
    636whp
    NEW BUILD
    335d
    520whp
    635wtq
  15. #115
    Jul 2012
    NJ
    E36 M3
    OP- I've run a temp sensor for a while. Mine's in a steel pipe that I use in place of the upper house. My upper radiator hose is always full of water. You'll likely have a challenge trying to fit the sensor from the bottom as the accessory belt will likely interfere.
    If you place the adapter in the middle upper hose you wont be over the idler pulley. Even over the pulling you'll be clear of the belt (the belt runs under) but id place in the middle just before the bend to the radiator would be best.
  16. #116
    lol
    Not too worried about my temp sensor swimming guys...though crow IS delicious when served right
    and to a prepared, willing party.
    I'll be doing a full system VACUUM bleed w/ the infamous,
    the insidious.... UVIEW Airlift II
    Some hippy turned me onto one of them.
  17. #117
    Suffolk, Virginia
    35D X5, 335d
    You just gotta "eat a little crow" and turn the adapter a little to the bottom. You'll be ok.
    Can you please post a pic of your upper radiator hose?
    OLD
    E30
    636whp
    NEW BUILD
    335d
    520whp
    635wtq
  18. #118
    Jul 2012
    NJ
    E36 M3
    lol
    Nice. I was gonna delete my heater core and gut my dash. Was wondering what might be a good why to fully bleed my system.
    Sorry for the skid marks on your thread. Let clean that up as taste my own bird in the name of the thread. Ive done research in your older thread (good stuff) and its great to see you don't stay stagnant.
  19. #119
    I have the OEM upper hose with the narrower mid-section BTW. Thanks for the heads up on the 36mm size.
    Just ordered.
    $18 delivered (in black, the new pink.)
    BTW,
    what about DRILLING holes in the thermostat to minimize damage from the possibility of a stuck thermostat.
    Has anyone ever actually run into a stuck Tstat situation?
    I've seen pictures of ONE shop on the forum here do this ...seemingly, religiously.
  20. #120
    Suffolk, Virginia
    35D X5, 335d
    Just ordered.
    BTW,
    What gauge and sensor are you going to run?
    OLD
    E30
    636whp
    NEW BUILD
    335d
    520whp
    635wtq
  21. #121
    I'm running the cheap PROSPORT gauge/sensor kits.
    They work fairly well.
  22. #122
    Suffolk, Virginia
    35D X5, 335d
    Gotcha. They are priced right.
    OLD
    E30
    636whp
    NEW BUILD
    335d
    520whp
    635wtq
  23. #123
    Manchester, N.H.
    96 332IS 6466 turbo
    Late in the game, but I has one of these.
    Works mint.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  24. #124
    Tanks95's Avatar
    Tanks95 is offline M3s Only Have Two Doors BMW CCA Member
    Nov 2002
    North Carolina
    I6 & V8 ///M
    ^^^What is it? What does it do?
    If your M3 doesnt have 3 pedals and 2 doors, I would really consider contacting BMW to confirm the authenticity of your incorrectly badged mid-sized family sedan.
  25. #125
