Results 1 to 3 of 3
Thread: 1999 Z3 2.5 to 3.2 conversion
    Dec 2012
    howell, ni
    1999 BMW Z3
    I want to swap out my 2.5 to a 3.2.
    Can the 2.5 be bored out to he larger 3.2? then just change the crank and rods or is there more to that?
    Vancouver, BC Ca
    1993 325is
    Your 2.5 is an M54B25, isn't it? Is the block aluminum (I think it is). You could put the M54B30 crank, rods and pistons into your 2.5 block to get a 3.0, but you cannot bore your block much more than about 1mm, which would put you at about 3,050cc.
    Dec 2012
    howell, ni
    1999 BMW Z3
    3.2 swap
    Has anyone swapped in a 3.2 into their Z3 that had a 2.5? Any problems or computer issues?
    thanks for the help.
