Hi guys, quick question regarding a diff swap. Would a BMW E46 M3 3.2 Differential 3.62 Ratio LSD Diff fit an E31 840?
Granted I would need to swap the cover bit what I'm really asking is if this is the big case diff.
Thanks guys.
swap the internals in and you'll have a nice M-vario LSD as well!
2.8 Z3 coupe + 6 speed || 200kW electric 1970 Jaguar XJ6
Would you elaborate, are you sugesting the all the internal parts of an M3 E46 LSD are interchangable with an 840 E31 open dif?
As long as it has a 210mm case.
I would but your in the states, and I'm in Germany!
How's about one from a e23 745i turbo?
Those were large case as well but I believe the housing would not be a bolt-in to the e31 chassis............
Someone correct me if I'm wrong???
housing differs...
Why not m5 differential?
You will find the 3.73 in the euro M635 from '84-'86. These were "grey market" cars imported before the US got the e24 M6 in '87. The US M6 cars ('87-'89) came with a 3.91 to compensate for the extra weight they carried (5 MPH bumpers, side door beams, and rear AC unit) ... and smog equipment that robbed them of 30 HP.
These are 210mm (large case) differentials .... used only in the e24 "M" cars .... not the same as used in the standard e24 cars. It is my understanding that
the rear cover needs to be exchanged with yours ..... but otherwise is a drop in replacement, as the gear case is the same.
Someone please correct me if I am wrong.
1985 M635 (gone but not forgotten)
1994 850CSi (also gone but not forgotten)
1985 M635 (current obsession)
I went the other way, from a 3.45 to a stock euro 3.15lsd from an e32 750i, swapped the back cover and bolt on.
-Egil (my name)
2012 ///M550xd touring
1990 850Ia Hartge Supercharged.
2004 M3 (sold)
Was the 3.45 an LSD, if so do you want to sell it?
Steve
No it was not LSD, and it failed spectacularly beyond salvage.
I got the 3.15 LSD before I knew it was bad (the failure came as a huge surprise) to get lower revs at cruise and to lower fuel consumption.
Fuel consumption is not the main concern when buying a V12, but with fuel prices having passed $2.50 a liter, a mixed consumption around 10mpg is getting a tad high, and when driving on long trips with fellow 8'ers the extra 10l I have to put in at every fuel stop started to get to me.
The fact that my car is supercharged also mean I don't need the gearing ratio, I have plenty of power anyway.
-Egil (my name)
2004 M3 (sold)
Interesting this type of diff is a lot more easy to get a hold of here in the UK compared to anything else I have been looking at.
So would this work then ?
http://www.ebay.co.uk/itm/BMW-e46-M3...item4d07d33e42
So I need to swap the insides into my case, how involved is this and is it something that I could DIY , special tools required etc?
NB I also noted a service bulletin for them SI 330102 (850) seems like just needs a fluid change and run in process.
Chadderz
I have 3.64 LSD from an E32 750Li on my 840. It only needed the back plate swapped. The 3.64 LSD was an option for the 750Li.
when stick with the 3.45 my computer was pretty steady at 18l/100km, with consumption in mind I could get it to about 16l/100km
my best highway was 11l/100km, but the norm was 13l/100km.
And a trip to Germany with autobahn driving put me around 16l/100km, but that was speeds of ~180kph and some bursts above 250kph.
Expect a 3.64 to be slightly higher.
Edit: my car is an 850, so not directly comparable
-Egil (my name)
2004 M3 (sold)
-Egil (my name)
2004 M3 (sold)
