Results 1 to 11 of 11
Thread: Where to order Parts for outside door handle
    Sep 2012
    Fate, TX
    1998 BMW 323IC
    Besides dealership-Anyone know where I can order the part for the outside door handle a seal washer under the lock cylinder nut? Wasn't on eBay.
    South Carolina
    2004 330 vert 2004 X5
    If you mean the plastic trim and rubber gasket under it that covers the whole handle I would get those from the dealer. I have bought several from ebay and they fit but they seem to be a lot thicker than the stock ones. In any case my door handle always seems to snag on the cover. Those parts aren't expensive.
    Mar 2010
    Vancouver, BC
    98 Z3, 97 328i vert
    Heck I have been looking now for hour and can't even find this seal in Real OEM. I have found some seals on Amazon that have crap reviews, and a few threads here but none have a link to anything I can buy.
    This thread was interesting but old and no luck. https://www.bimmerforums.com/forum/s...+handle+rubber
    I'm going to hit up Google.de and find a forum there. The Germans must have these.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    you mean the outer door handle cover seals? These I have, not the dealer, http://www.abload.de/img/tr_vorne2a0kyr.jpg
    See in E34 classifieds my offer, fits E36, Z3, E34, E32
    Mar 2010
    Vancouver, BC
    98 Z3, 97 328i vert
    Yes that is what I want but is there a difference between 2 door coupes/convertibles and the 4 dr models? Also out of curiosity, what is the p/n, I still do not see it on the realoem site. These things are on 4 cars I own but I can't see it on that site. Hilarious.
    Jan 2005
    Japan
    There are no part numbers, because BMW only sells the covering front L+R and rear with the gasket. I sell the single gaskets only. Differences: Front right and left have one larger hole (each on different side, as you can see from the pic), rear gaskets have 2 smaller holes. My front door handle cover gaskets fit E36 l sedan, cabrio, Coupe, compact. Even in case of compacts where there is only one lock, you need the wider opening of the front door gasket. Rear door gaskets are same for both doors.
    Front door gaskets fit E36 sedan, cabrio, Coupe, compact, Z3, rear door gaskets fit E36, E34, E32. I sell them as 2-door kits or 4-door kits.
    https://www.bimmerforums.com/forum/s...E32-E34-E36-Z3
    For your Z3 see here my offer https://www.bimmerforums.com/forum/s...handle-gaskets
    Oct 2016
    Edmonton, AB
    2013 Subaru Impreza
    Hi Shogun
    Sent you a PM but not sure if it went through? If not can you please send me a PM as I'm looking to buy some door handle gaskets for a Z3.
    Tim
    Jan 2005
    Japan
    no problem, have stock for Z3; E36 sedan, Cabrio, Coupe; E34, E32, PM sent.
    Edit: already shipped out to you today
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Quote Originally Posted by FridayFire View Post
    https://www.fcpeuro.com/products/bmw-gasket-51211928380
    Jan 2005
    Japan
    that 51211928380 is the lock cylinder gasket aka as lock cylinder clip https://www.ecstuning.com/b-genuine-...h/51211928380/
    Aug 2011
    Pittsford, New York
    90/535m,92/535m,94/530a
    I’m replacing the handle surrounds (including gasket) with these part numbers:
    51-21-1-938-285 front left
    51-21-1-938-285 front right
    51-22-1-938-280 rear left & right
    The part number for the seal around the key tumblr is 51-21-1-928-380.
    Everything’s available from FCPEuro and other channels.
