Do the 95 m3 tophats delete castor or add castor???
I believe they decrease camber but not sure about caster
How about when compared to centered tophats?
Here is the problem.
I have non m3 control arms, with 95 m3 offset lcabs, 93 m3 spindles and m3 brakes and centered top hats. I have nice castor, but just purchased coilovers. I am worried that when I lower the car, the front wheels are going to rub the fenders near the indicators and fender liners because of the extra castor i have... Car is on koni's right now, very mild drop, and no rubbing. I have et20 wheels and when i install my other set which is also et20 but with 235s i rub in the front in those exact spots at my current ride height... in terms of camber, everything is perfect, agressive but not over the top. So now i don t know what tophats to get?
The real problem is the wheels. It's the 20 offset.
The regular E36 control arms are the same geomety as the 95 M3, You have offset lcab's (like a 95 M3), and centered mounts, (like a 95) you should have the 95 geometry...
What's a 93 M3 spindle? Was that a typo?
