So yesterday when is started my car and proceeded to back out of my parking spot i noticed that my steering took way more effort to turn. I then proceeded to turn off the car to check the power steering fluid level i added somw chf-11S because my car has the SLS suspension then restarted the car and turned the steeringwheel from far left to right to get the fluid going but it was still stiff. Also when i first start the car for the first 15 seconds the steering is normal then gets really heavy. My question is do you think that the "servotronic" has to be replaced? Or is my power steering pump failing? Thanks
Alpina Lip/Muffler Delete/ Shadowline Trim/ Shadowline Grill/CF Roundels /CF Door Pillars/18' TSWs Staggered/Smoked LED Tails/Corners/Side Markers/ 8000K Lows/Fogs/ LED Dual Color Switch Back Turn Signals
Led Reverse Bulbs/LED Interior/Cargo Area/ Puddle Lights
48 SMD LED License Plate Housings
Mine was doing the same thing, pump was leaking after topping off with pentosin. Had to have the power steering assay replaced. Is it leaking?
Check the hoses, if not leaking then it could be the pump...I'll wait on the others to chime later.
If the hardware all check out, ask someone with INPA/DIS laptop to clear codes in your GM.
After thirty low voltage errors it shuts down Servotronic and these errors are easy to accumulate if the battery is low when you start up.
I have PASoft 1.4.0 and am unsure if it can clear this (I'll have to test on mine) but I'd be glad to help. However I'm in the East Bay by Walnut Creek.
Let's get together guys. Steve has PASoft which I might be able to use to re-program an AGS into my E39 and I have the IceBox which has DIS on it.
We should be able to figure this out together. I am having the same issue with my E38 and can't seem to clear the issue. Might be the steering angle sensor.
I replaced the servotronic valve , Pump & hoses and after two weeks, my steering started to get stiff again when I first started the car and then got better as I drove it. really strange and no one really has any idea as to what it might be. The Body Module would either work or not, the battery is new so I have no idea what it could be. Good luck with yours. I to have an angle sensor code. but again, it wouldn't get better after it got warmer and I am pretty sure it would only effect the traction control not the servotronic steering feel.
Pretty sure that LWS Steering angle sensors will goof up the Servotronic if not corrected.
Fault like 50x times...
Great Iceman,
Could you please confirm the part number of such LWS steering angle sensor?
Are we talking about part #9?
http://www.realoem.com/bmw/showparts...g=30&lang=enUS
Regards
P.
Sweet Car of Mine, You make me so happy...
'09 E90, just clean
'98 E38, Oxford Green, new 18" wheels, new tires, new front & rear suspension, new rear struts
New tail lights, new headlights, 6000°K xenon lamps
New Zimmermann rotors, Akebono pads, new valve cover gaskets.
New spark plugs, new MAF, new Lambda sensors, new ICV, new camshaft sensors
New Radiator Hoses & Coolant Fluid, new steering hoses, new OSV valve, new TPS, new ASR sensor.
Icebox Owner&User, Leather seats treatment & restoration
This is definitively a endless list.
Yes sir.
updated 5/14 sports contour seats, e65 headrests, picnic tables, elec rear seats, two tone interior, leather footrests, wood ashtrays/maplight/handles/porn/armrest/b pillars, chromeline doorsills, chromeline speakers, acs pedals, alum gauges, 1,200 amp/1000 sub/dsp, telephone, 2 rear bmw umbrellas, clear tails, clear corners, led sides, led angel eyes, 6k fogs, 8k lows, limiter removed, tran reset, wnds up/dwn, shadowline, style 95's
the servotronic valve is often the raeson for problems. you can try to clean it.
I have 2001 e38 heavy steering problem very similar to that described in this thread. Being on front end if problem I did the 9 volt test, bought diagnostic computer and ran inpa error tests but am now not sure I'm any closer to knowing which way to go.
Got two static errors under ZKE3_GM1 : 31 error occurences of Cable Tacho A (speedometer) or IKE missing and 31 occurences of Open circuit servo valve or cable and proceeded to clear all errors but heavy steering persists. Next step would be to purchase and replace new servo valve but unsure if that will solve problem from what I see on this thread
Whats up Stan?
Before you buy a new valve, even though that's probably what it is, check wiring integrity and resistance from the module to the valve and make sure its less than .4ohms, preferably .1 or .2ohms. Also check resistance to ground to make sure it's not shorted. It's a small and simple check that may save you replacing the valve or module. Also check the valve itself and see if you have any continuity and resistance through it.
2001 BMW 750iL Black on Black fully loaded
1997 BMW M3/4/6 - Awaiting turbo
2001 Audi S4 - VR6 turbo swap in progress
2016 ZX14R
1993 R32 GTR V-Spec
The computer system and the ultra-professional support from Icemanbhe has paid for itself times over as the heavy steering problem is now solved without going through the agony of replacing a number of expensive and difficult to replace parts
Steps to success in summary:
>9 volt test - no luck
> Secured Icemanbhe diagnostic computer - read up on how to use it - ended up using INPA
> Ran error memory tests and found that error 128 and 130 repeated 31 times exactly
> Printed report of all codes and sent to Icemanbhe
> Cleared all codes and re-ran error reoport immediately then drive car
>Drove car immediatly but did NOT see improvement in heavy steering - needless to say fear set in
>Contacted Icemanbhe who suggested running car through a number of cycles before taking next steps
> Ran car again after it had sat off for a while and to pleasant surprise steering as light as a feather
> Very thankful I invested in the diagnostic computer - with 2 - 2001 740's this has already paid for itself by clearing all nusance codes and solving steering problem and now in position to accurately troubleshoot going forward
Almost as icing on the cake, now after replacing AUC sensor full errr memory test diagnostics returned ZERO errors
total success - hope it lasts
more power to icemanbhe and his system and follow up extensive technical support
reviving an old thread. My father's 95 740il is having the heavy steering and I wonder if anyone in the Sacramento area has the computer software to pull and clear any errors. They are considering selling it and I said let me see if I can get this fixed before making any moves!
I have this problem with my 97 e38 and talked about on another tread, they said about the servotronic, I check my car but my car don't have one, I replace the steering pump but nothing, still have a hard steering but is drive able
Maybe you need one? This is what I found to try to narrow down the problem for those that don't have the DIS/ INPA
http://www.bimmerboard.com/forums/posts/859479
