I have a 1994 750il and the Asc+T hydro unit is leaking, is there a rebuild kit or anyone on here who has one for cheap? The BMW number is 34511163086 an the Bosch number is 0265202100 an here is a link of a picture in case anyone is confused: http://thumbs1.ebaystatic.com/m/mIwD...8NBqeQ/140.jpg
try here for remanufactured ones
http://www.bba-reman.com/US/index.aspx
http://www.modulemaster.com/en/index.php
http://abs.ecu-rc.com/
nah none of those were really any help but i do appreciate your help, i think a used one is the best solution at this point so if anyone has one let me know asap please.
There is an o-ring between the hydrounit itself and pressure sensor-plunger, that's need to be changed. The reason it's became dry and doesn't seal the sensor-plunger no more. No need to buy a new one hydrounit.
now it is becoming interesting. Do you or anyone have pictures or drawings / dimensions of the single parts?Especially the O-ring size.
Sorry no pictures, i've got a problem with my ASC+T system thats stopped working suddenly. This bloody system works from double power steering pump. After a couple of months of tortures with this system i found the problem. It was a double steering pumps that was not providing a proper pressure to the ASC+T hydrounit.
When i found the price in 1thousand bucks! for this pump i decided to get rid of this hydroulic system. I found a donor on a junky yard with ASC5 and just retrofitted the system. Unfortunately no way for M70.
But there is no any difficulties. To change the o-ring it needed to remove the hydrounit from the car. After you need to unscrew several torx and devide pressure sensor plunger from the unit. Then you will see the small 0-ring that's need to be changed.
Where do I get the o-ring? And the unit still works it just leaks slowly...honestly id be happy with just a used one then trying to rebuild the old one so if anyone has one please post here ASAP thanks.
Still in need of one ASAP so If anyone has info about a rebuild kit or has a used one please inbox me or reply here, thanks
check with this guy:
http://www.mye28.com/viewtopic.php?t=103958
Mike
93 M5 3.8 Sterling Silver/Black (euro)
94 M5 Touring Madeiraschwarz/Black
80 745i (project)
83 735i / 5 speed (euro)
86 745i
I have a used one for sale on eBay. From 1993 740iL
eBay #360589624429 Item number:
I have the same problem on my 1994 bmw 740i can anyone tell me how to replace this O ring can it be done on the car my unit works fine just leaks I know this is an old thread but I've contacted at least 45 salvage yards through out the us and either they dont have it or have no idea what im talking about even with part numbers so it looks like im going to have no choice but to repair the one i have
try to contact one of the module repair shops, I did some google search, here one example https://modulemaster.com/rebuilds/
Shogun I found a used unit for 125 bucks I’m rolling the dice on a used one but it’s all I got in the budget at the moment. In the e34 section I’ve seen talk of replacement of the O ring behind the plate but since it’s a special type o ring the fixes didn’t last . I got the Bentley and the instructions you posted I’m going to do my best to try this job I have reserved myself to the fact that the car may have to be moth balled till spring if I run into snags what’s another couple of months the car already sat for 8 years I’ll take my time and snap a lot of photos along the way for myself for reinstalling and posting when I’m done maybe I can help the next person when it’s all finally done
the alternate is to see if the unit can be "disabled" or removed from the system. Out in the west the 740 did not come with the traction control... snow... ice... is really unknown here, unless you go over to the sierras in winter. I drove once in the snow... no chains, it was in the local parking lot off the highway, the 740 handled it very nicely... skidding w very healthy behavior
gonna pull my unit this weekend see if i can get the jb weld off and try to replace the O-ring thats causing it to leak the used unit wasnt even the right part they sent me the sent me a power steering pump and i cant find one and no one will rebuild it I've tried all the links shogun has provided so im on my own
