Science/learning. I get it. You and smallsnails have been an asset to this forum.
I retract my previous statement. Thank you for your testing and analysis guys.
95 turbo 330ti. 01 maxpsi m3 e85. 01 m5. 01 m coupe. 03 AIM 996t e85. 06 x3 w/Meyers plow and winter daily. Prussian Motors is hiring!! prussianmotors.com/jobs
Current e39t LS Turbo swap: https://www.bimmerforums.com/forum/s...LS-e39-Touring
That's pretty funny...and it looks like the feed line is -6? You should see what happens with -8 feed line flow rates....
Speaking of torque: The primary reason why I'm so focused on pulsing solenoids is to control torque so that total engine output is linear. If you look at the mass-flow required for say 100 hp boost at 3500 RPM, you'll find you need just over 200% of that flow rate at 7000 RPM. (Doubling the RPM halves mass flow per combustion event + RPM losses) So to add 100hp linear across the RPM band of operation will take lets say 225hp of flow.
But....something most people miss when adding a lot of nitrous to a turbo application is that you need to have the flow capability to bypass extra exhaust flow. Not just a big wastegate, but proper exhaust manifold design...otherwise you'll have a really hard time controlling the turbo when nitrous comes in. If your ECU lets you run a feed-forward type of waste gate control strategy...you will need 2 maps: 1 for no nitrous use, and 1 for when using nitrous.
Sorry to clutter up the thread with my nitrous ramblings....
Yeah that's what I was thinking - the "HP shot" is not linear across the board, its linear across the flow out of the solenoid. So really you'd need a much higher flow ability to do 100 hp across the rev range.
What I mean about flatter torque is that I will bring the turbo up to speed sooner, relying mostly on the turbo vs nitrous.
No worries - I like discussion!
Been keeping up with your build for a couple years now 5mall5nail, and I just wanted to come in and thank you guys for putting your almost unbelievable amount of knowledge out there for regular people like me to see and hopefully take a little bit away from.
"If it's worth doing, it's worth overdoing."
"You may all go to Hell, and I will go to Texas."
Davy Crockett
www.Angry-Ass.com
My Build Thread Part 1, Part 2
DIY E31 X-Brace Mod and Install
DIY Rear Seat Backrest Modification for E32 Armrest
Thanks man - we're all regular people lol. Glad you enjoyed!
It looks a whole lot better in black with a light texture! Pics to follow. Been dealing with real estate crap today and working on a set of calipers for a guy - calipers are kicking my butt.
| 1997 Estoril M3 - TURBO - || GT35R | 8.5:1 forged internals | ARP stuffs | SS Oring Block w/ elring | Fully balanced & blueprinted 3.3L S52 | Nick G Tuning || 46mm Precision gate| 62# injectors | Dual Walbro's |Goal: 600+ whp pump gas reliable 10 second car.
-2007 335i Sport Package
Dude, nitrous isn't cheap at ANY point. When you look at what a nitrous kit is you realize it isn't cheap. All the guys who say nitrous is a cheat way to get to bigger hp are crazy - its a serious investment. Some of the v8 guys are running dual bottles because of how much their systems flow. Dual 10 or 15 lb bottles because a single bottle falls out on one pass. That's 10-15 lb in < 7 secs. $10 - 15 a lb... $70-80 a pass. Wee!
Subscribed this is going to be awesome.
Question on the Mil Connectors. Any special crimp tool needed? Is there a max gauge wire for them? Keep up the good work!
There's tons of pin options. I have some solder pins some crimp, some connectors hold 20A some hold 3A. It all depends. Literally there are like... maybe 5,000 combinations of pins and connectors.
Worked on some brake stuff and coated my bottle bracket:
Coated Bottle Bracket by Jon Kensy, on Flickr
Integral heater
Re-tapped all holes. Lookin good to me! Moved my car back inside about 5 mins ahead of snow!
Brackets look dope, and convienent.
Nice work as usual!
[ 1990 325is Turbo ]
"..a true hotrodder wouldn't be content until he had created a car so violent, so totally sick
that the act of dropping the hammer would result in instant death. Anything less results in the need to go faster."
-Tony DeFeo
The bracket looks so much better coated black. If the manufacturer doesn't offer that option, they should.
My manifolds powering 8sec and over 1000rwp cars
Home of the highest HP stock M30 in the world 550rwhp/622rwtq
1/4 mile---> 9.81 @138 C4 Auto
10.08 in car vid --->https://youtu.be/OiinFhUomjg
Dyno vid... http://www.youtube.com/watch?v=C7aM7..._order&list=UL
OLD
E30
636whp
1/4 mile: 10.91@144.38
http://www.youtube.com/watch?v=L_f7fUVqblI
NEW BUILD
335d
520whp
635wtq
120.51mph trap speed
Bottle holder came out great. Was going to do some purple in there for good measure but I've kept the purple out of the cockpit so it'd look out of place if I started now.
I have it somewhat modeled in SW but I will likely just "make it happen". I want to build a jig from the existing manifold to keep turbo placement, but I want to revise the wastegate placement.
Sounds good. I'm really interested in building a manifold. Obviously nothing crazy. Basically, I'd like to just fit and practice welding and see if I could pull it off. Ya know, a fun way to pass the time this winter.
Where did you get that flange? How about the material?
OLD
E30
636whp
NEW BUILD
335d
520whp
635wtq
