Where do you work? And are you gonna wrap the hood? Yes?
That is the best looking wrap I have seen. The finish looks like factory clear. Does it really look that good in person?
I work at a dealership off rosemont. I was going to wrap the hood and leave the vents carbon but the hood contrasts really well with the red and i dont have enough wrap left lol.
It looks great in person unless you get right up on it. it sorta looks like a decent paintjob but with orangepeel. There are some flaws like dirt under it and the front bumper didnt turn out as well as I hoped but the red is so bright it hides most of it. After springfest this saturday i will have a proper shoot done.
I vote for wrap the hood, leave the vents carbon
Wheel specs??
instagram: @narvinbeans
Nice, I ran 10.5s in the rear with et0, are you sure your front is going to clear the strut without the spacer?
I took some pictures yesterday from a local carmeet we have every year. #Springfest I finished the wrap the night before and on the way home the car died. Turned out to be the fuel pump wiring which was easily fixed.
went -18 with 9.5s in the front at about the same height as yours in the front 215/40. widest is my set right now, running 18x10.5s with -3 camber 245/35/18 with et -8, 10s will fit fine. are you just changing the lip or the inner barrel as well? How wide is your inner barrel?
2003 ///M5. ~ Jet Black/ Le Mans Blue
RK Supercharged @ 501wheel horsepower/ 419lbs torque
Supersprint Headers
CNS Lightweight dm flywheel/ Spec clutch
ST coilovers
Eibach Rear Sway bar/Beast Power Brackets
Drilled slotted Rotors/Akebono Euro pads
Magnaflow 14816 Mufflers
Michelin Pilot supersports
I think it would look pretty good. It seems that there's a little too much black.
How much does that hood weigh? How didit feel compared to the oem
Supersprint Headers
ST coilovers
Was that show in Va Beach?
I will. My best friend was there at the dressupbolts/classicjdm/Jspec booth with his black 2jz Lexus GS. He imports classic JDM cars too. They had their R31 skyline at the booth as well.
