“Wait a minute. What did you just say? You're predicting $4-a-gallon gas? ... That's interesting. I hadn't heard that.”
― George W. Bush
1991 318is Diamantschwarz Metallic
1989 325i Alpine White
I'm on my second set of Pirelli p4's I have no complaints.
get some 16s ffs
BMW E34 Touring 92/8 525/5 Electrical black sports leather, 3.73 LSD. Black on black
BMW E30 Touring 89/3 325/5 Manual black sports leather, 3.91 LSD. Diamond Black on black
- From sweden yah b0rk b0rk b0rk -
I'm thinking about getting these!
http://www.pepboys.com/tires/details...25LSOHC/00847/
"Howdy, Folks!"
I run 195/65x15 on my 15x7 basketweaves..
On stock ride height but i would not recomend it.. Rubs up front and it handles like a Crown Vic
Lower profile for the proper feeling.. 55 or less
did not mean to bring back an older thread my apologies but still wanted to know if anybody tried a lower sidewall version example
FREE SHIPPING(467)
|Reviews (426)
Tire Rack Tested
this is a 185 x 55 x 14
my car is lowered on bilstein front and rear I feel like lower profile and thinner width would be better with the lowered heigth
any thoughts thanks very much!!!!
Remove
VREDESTEIN
QUATRAC 5Grand Touring All-Season
[QUICKIMGhttp://img32.imageshack.us/img32/3607/5lkb.jpg][/QUICKIMG]
Not a 185/55. I prefer the lower sidewall but also like a wider contact pattern so I can't help on the 185 version
No e30s again.
I'm assuming you're running on the 14x6 bottlecaps which had an original factory size of 195/65/14. You had an original rolling diameter of 23.98". Going with a shorter sidewall without changing the wheel size is going to affect that diameter which in turn affects the speedometer readings. The question is how much can you get away with.
185/55/14 - this cuts the sidewall height from 5" to 4". However that cuts the rolling diameter to 22" which has a major impact on your speedo. When travelling about 60 your speedo will read about 67. Add in the typical BMW under-reporting of speed and it will read about 70. This is not recommended.
Really the only way to cut the sidewall height is to run larger diameter wheels.
"Howdy, Folks!"
Alright thanks for the measurement conversion I was totally guessing at that. My speedo is already running overclocked because I changed over the rear gear to an LSD 4.1 first and second gear feel very similar 😎 I ended up about 2 and 3/4 lower in the front on the new suspension and about 2 and 1/4 lower in the rear but when the kids get in the back in levels out just about right . I dont drive high speeds in this E30 it's all about zero to 60 for me so around 80 mph is the limit of my rpm's with that gear.
your speedo runs off the gear in the diff so its still reading ok. that's what good about e30s, no transmission gears to change when you change diff ratios.
https://tiresize.com/calculator/
you can put your info in the box on the left. just hit tire comparison instead of calculator and input the numbers. it will shows a pic and give you the numbers to see the differences
No e30s again.
Alright great thank you for the info hopefully I will have them on there soon next is a new gas tank or fuel cell maybe trunk location not sure yet but the original 1986 tank is getting mucky
