bump
bump
bump
Hey gary, trying to figure out some gremlins after installing these; I can't seem to get rid of the CEL with codes P 0140 and P 0160, which is bank 1 sensor 2 and bank 2 sensor 2 respectively. It is saying heater circut not working, any help would be greatly appreciated! the car is a 1998 328i so m52. thanks again
S54 swap DME flashing - $100
S54 swap CAN interface board (for proper A/C & check engine light) - $275
e36 SAP sim/secondary air pump simulator: $75 - standard or $170 - plug & play
e36 post-cat O2 sims: $115 shipped, plug & play
Hey, do you make these for the E39? These worked flawlessly on my E36 and I'd like some for my E39.
///M Power / 99 M3/2/5, VF V3
Still have o2 sims in stock?
Any luck on getting rid of the heater circuit problem for 98 328i??
bump
Used this with a AA track pipe install. Perfect!! Thank you for a great product!!
Can you tell me what the answer was to the 323is questions? Will these work with a wire harness that only has 1 rear o2 sensor? Also I am using the 323is harness with only 1 rear 02 but I am using an M3 DME which is tuned for my turbo setup. I have been having many issues trying to get the post cat emissions readiness monitors to show as ready. Car has not been registed in 2 years because of this.
She's built like a steakhouse but handles like a bistro
The sim will work with my ecu yes but I only have one rear 02. Can I plug this in and leave the other unplugged?
bump
bump
bump
bump, have more ready to ship
I need a simulator for the air pump and the post cat O2 sensors.
