Page 3 of 7 FirstFirst 1234567 LastLast
Results 51 to 75 of 175
Thread: M3 O2 sims
  1. #51
    New York City
    1997 328is
    Sent a PM.
  2. #52
    Aug 2001
    southern california
    93 e36, 04 r6
    Does this work for m50?
  3. #53
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by alheim View Post
    Sent a PM.
    Replied, thanks.
    Quote Originally Posted by doreenerzz View Post
    The M50 doesn't have post-cat O2 sensors, so nothing to simulate there.
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  4. #54
    Jun 2010
    Wiggles, NJ
    1998 BMW M3
    Will these work in the O2's on the headers of the S52, both are bad and I rather spend 110 than 300. Thanks
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  5. #55
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by Kasanova View Post
    No, pre-cat O2 sensors are required.
  6. #56
    Maryland
    '98 M3
    $300? Look here:
    http://www.amazon.com/gp/aw/d/B001PN...sr=8-1&pi=SL75
  7. #57
    Jan 2012
    Annapolis, MD
    1998 323is Track Car
    Quote Originally Posted by gpeterson View Post
    bump, more available
    What about a the M52 323is? There is only 1 post cat o2 sensor I need to simulate. Is it cheaper since there is only one wire not 2?
    www.ErvickMotorsports.com
    24hrs of Lemons Racer - Summit Point, NJMP, - Team Victors of War
    2007 E60 550i - RIP thanks to a deer @ 90mph
    1998 E36 323is Track/Lemons Car
    1998 GSXR 600
    1998 Honda Z50
  8. #58
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by VT550i View Post
    Replied to PM, thanks.
  9. #59
    Dec 2005
    Canada
    99 E36 M3 VF V3
    Very nice build quality on these connectors!
    Quick question.. Where did you guys mount this? I reused the existing mount for the wire sensor wire harness. Is there a 1-3 and 4-6 bank wire or are they basically interchangeable? Just asking because my CEL came back. I'll try swapping them over tonight.
  10. #60
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by stefan15 View Post
    Sorry I didn't reply sooner, I'm on vacation. It should mount using the M3 threaded hole in the body like this:
    Swapping connectors won't make a difference on the O2 sim. Can you please PM me with info on which code(s) you are getting so that we can figure it out? Thanks.
  11. #61
    Dec 2005
    Canada
    99 E36 M3 VF V3
    Nice, didn't notice the hole there. I'll move it over and PM you the codes! I haven't checked this morning, but last time it was ox sensor heaters on 1-3 and 4-6. No problem on the delay, thanks for the reply. I'm not in a rush!
    edit: CEL that popped up turned out to be a 00 DME undefined. I found it coincidental on the timing.. either way, I blame BMW gremlins. All good now.
  12. #62
    Northern CA
    1998 M3/4/5
    bump
  13. #63
    Northern CA
    1998 M3/4/5
    bump
  14. #64
    Northern CA
    1998 M3/4/5
    bump
  15. #65
    Mar 2013
    Cleveland Ohio
    2008 M3 Coupe
    They work great!
    Sent from my SGH-T999 using Tapatalk 2
  16. #66
    Nov 2013
    United States
    2006 Ford F-350 Diesel
    Just joined up in hopes that you are still offering these?
    An old-timer BMW motorcycle mechanic who works around the corner from my shop has a 97 M3 that he put a race exhaust on (no cats). Keeps throwing CEL for post-cat O2's, tried running de-foulers with no luck, so time for some O2 sims, if I can find some...
  17. #67
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by greesemunkey View Post
    Just joined up in hopes that you are still offering these? An old-timer BMW motorcycle mechanic who works around the corner from my shop has a 97 M3 that he put a race exhaust on (no cats). Keeps throwing CEL for post-cat O2's, tried running de-foulers with no luck, so time for some O2 sims, if I can find some...
    Yes, I have some in stock and ready to ship. The best way to order is at e36-electronic.com.
  18. #68
    Northern CA
    1998 M3/4/5
    bump
  19. #69
    Northern CA
    1998 M3/4/5
    bump
  20. #70
    Northern CA
    1998 M3/4/5
    bump
  21. #71
    Northern CA
    1998 M3/4/5
    bump
  22. #72
    Calgary, Alberta, Canada!
    '98 328is
    If I still have cats, is there any advantage to buying these O2 Sims vs. Spark Plug Non-Foulers?
    My car just reached the 100,000 mile mark, so I ordered some OEM pre-cat O2 Sensors and am unsure the best route to go for the post-cat. Either OEM sensors, o2 sims or spark non-foulers. If the o2 sims are built in such a way that I would never have to worry about the post-cat sensors again, perhaps it is a worthwhile option.
  23. #73
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by Quickstrike View Post
    Are you getting a CEL due to your cats and/or post-cat sensors? If not, I wouldn't do anything about them.
  24. #74
    Jan 2014
    FL
    1996 BMW M3 Coupe
    im ready to place a order but i just want to get this clear first, both the postcat 02 sensors are deleted and the sims hooks up to the 02 connectors right?
  25. #75
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by AsianThunder View Post
    Yes, that is correct.
