It's best to just go ahead and create an account with 4shared.
Didn't used to have to go through all this other bs to download via the "free" download option.
hi all , iam download esys , and nice work with it
but i want to download inpa ,ncs , for windows 7
and how can i use it ????
and i am already downloaded sp eaten , its 40 gb, iso ,, how can i use it , no pdf or document to use it ??
thanks
only INPA will work with Windows 7. Windows 7 dropped support for 16 bit programs
Current:
- 09 335i MSport, FBO.
- 98 Euro M3, Estoril Blue
- 04 M3, Carbon Black, 6 Speed Coupe
- 06 M5, Black on Black, Full Leather.
- 73 3.0CS, Tagia Green, 5 speed M30b35 converted
Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
The files need to be extracted using WinRAR - parts 2 and 3 will auto-extract when you begin extraction of part 1. If you are still experiencing problems, email me.
I can't get INPA to work for Windows 8.1, EDIBAS works, INPA lists a bunch in my apps but nothing seems to open. Anything I should be doing here? Nothing really looks like the actual program either, INPA.IPO, INPA.IPS, and INPA Compiler look the most promising but none are working. I tried setting INPA Compiler to run with XP settings but it still didn't work.
What car is it and what cable are you using? Did you modify window environment?
00 528I and the blue VAG cable
It's not a connection problem, I just can't get the program at all. I'm not sure what you mean by "modify the window environment," but I set whatever INPA programs I could find to XP compatibility mode of that's what you mean but still can't get anything open.
I had installed a different version I found online previously that worked fine and wouldn't connect(probably my fault) but I uninstalled that before trying the three part one on here, the INPA app icon isn't there though with this install except the ones described in the last post, which don't really look right.
Search for INPA(.ipo). Try to open it.
I am going through the same issue right now. INPA will not open for me. EDIABAS seems to be fine but I am only interested in reading DTC's right now so I am focused on getting INPA to work.
I get a prompt that essentially says 32bit INPA will not work on my 64bit windows7.
Lots of things to look for but I am getting more and more confused the deeper I dig.
The problem is with your operating system - it does not support the software. This is a Microsoft thing as earlier operating systems had a WOW64 addin to ensure compatibility with 32 bit software.
David mc,
yes. Your advice on this has been extraordinarily helpful. All the issues are on my end and your continued help is GREATLY appreciated.
Oh good, no XP mode for Windows 8, not officially anyway
I got that all working buuuut, it does exactly the same thing in XP for me.
Here's what I've got(including the ones on the desktop), and it shows the same file list in Windows 8
http://i.imgur.com/ZwhU2Um.png
EDIT: Do I need 3.01 first?
http://linkcrypt.ws/dir/gsik0l05oq3x866
http://linkcrypt.ws/dir/c5p8kq03jwvxo12
Ista Rheingold
http://linkcrypt.ws/dir/u50u4028rq26b70
Newest Version Uploaded & Share-Online
SPdaten v2.53
http://linkcrypt.ws/dir/82tzw4pdc6454xs
http://linkcrypt.ws/dir/olfa8to9mv1rdwu
ok so i'm trying to revive an old thread here. I have just used the links to download the 3 sections on the first page of this post. I have extracted them using WinRAR but now i'm at a loss as to what I do next. When I extracted the files it said they were all the same.
Burn the extracted .nrg file to a disk using Nero, then follow this ENGLISH SETUP.pdf
Thanks David Mc for the info I have done all that but sadly when I try to open INPA (_.IPO) I get the following message.
"The version of this file is not compatible with the version of windows you're running. Check your computers system information to see whether you need an x86 (32-bit) or x64 (64-bit) version of the programme, and then contact the software publisher."
any my idea what I need to do next.
