Results 1 to 25 of 50
Thread: Water on the back floor of the car v8.0
    New York
    2003 525i
    Captain's stardate 2009.916
    While driving to Dunkin Donuts for coffee and their new all-world toffee donut, I reached behind my driver's seat to grab a cd from my case. It's time to listen to some U2 as they are coming to NJ to rock out.
    I grab my case and WTF, it's soaking wet. The driver's side floor has 1/2" water on it. How can this be? I already sealed the door with some 3M goop years ago and it's been fine. We've had massive rain the past few days...WTF?
    Stopping off at Casa Sector III, while in the rain, I proceed to grab the necessary elements to take apart my door and seal it up for the second time. However, something...some force, a hunch, made me pause and meditate. So I did.
    Then I, for some strange reason, as if following the command of my former Jedi Master long gone, my index finger began to palpate the weather stripping...to see if it was clogged. WOW!!! On that driver's side door, my fingers could feel little lumps within the weather stripping, all on the bottom side. I ran to the passenger side and checked...no such feeling at all. WTF? Were aliens in my driver's side weather stripping? Was it filled with amoebas, parameciums? Something, many little somethings were in it and so I grabbed my Captain America action figure, coat hanger and camera.
    Using the coat hanger to push these aliens all the way to the bottom, the middle/lowest drain within the weather stripping, I then used my index fingers to massage these unidentified objects to an opening and get them the **** outta my weather stripping as they were clogging it up!
    It helped to have the weather stripping moist, if it were dry the job would've been very difficult or impossible. This is an FYI.
    The rest is clear to see.
    I suggest anyone who has water on the floors, investigate this. I suggest all of you do at some point. Why? It would seem that whomever made these rubber gaskets for BMW...their cutting machine which punches holes into the gasket (holes which are used to let water fall into from the top and then drain out the bottom) didn't have their vacuum turned, 'ON'; it seems the punched-out-rubber-holes fell into the gasket when it was manufactured...and over time with gravity and water...they fall downward and clog up your drain holes.
    I was able to force all these rubber pieces out of my weather stripping/gasket and the total count was 25 pieces. I then used an anti-bacterial spray to wipe down my carpeting after vacuuming it and toweling it dry.
    I believe...believe my problem should be solved. We'll see.
    "I'd smash that (Jennifer Connelly) like a failed coup in sub-Saharan Africa."
    ~Macktheknife in my epic Jennifer Connelly OT Thread
    New York
    2003 525i
    Continued...
    Interesting. I will check this...
    PRICE CUT on ALL FABRICS
    New York
    2003 525i
    Continued...
    Sep 2001
    Coral Springs, FL
    E21,E38,E39,F10 M5
    WOW am i glad i found this post... ive been fighting random water puddles behind my driver seat for a while now... i thought it was the sun roof gutters until i tested them and they drained fine.... now i know what to check... THANKS!!!
    Stancing is for drivers trapped in an abusive relationship of their own lives.
    New York
    2003 525i
    Quote Originally Posted by ///Manny View Post
    Odds are you will need to do v1.0, which is remove interior trim, remove screw under the inner door handle, loosen screws under door trim, remove inner door panel and use the proper weather stripping adhesive to RE-SEAL the inner VAPOR BARRIER.
    My v8.0 is for:
    1). Check this first
    2). Certainly check it if you've done the v1.0 repair and still get leaks.
    May the force be with you.
    Middle of a corn field
    E39 hamster/ruberbandPWR
    Quote Originally Posted by bimmerfiver View Post
    Continued...
    Caption America and BimmerFiver for the win!
    LOL!
    Moderators- request to please place this thread in the DIY section...
    Dec 2007
    NJ
    02 540i 6MT
    u2 ftw - going the 24th, i'll post pics.
    it is all gumbi's fault anyhow..
    New York
    2003 525i
    Quote Originally Posted by kerryb View Post
    Greetings exalted one, kerryb.
    http://www.entertonement.com/clips/c...Luke-Skywalker-
    I do not have tickets. I am sad. I am broke. I saw U2 on Monday, September 14th, 1987 at the Meadowlands, Joshua Tree Tour. I had floor seats, stood 15' from the stage. It was cosmic. May the fire be with you:
    [ame]http://www.youtube.com/watch?v=rylOfO_j9Nc[/ame]
    [ame]http://www.youtube.com/watch?v=sJ4kE-KsLC4[/ame]
    Dec 2007
    NJ
    02 540i 6MT
    i have heard that GA tics for the 23rd have been dropping on ticketbastard today, 55 clams plus their stupid charges.
    if i see tics dropped for thursday's show, i will pick you up one. my treat for the work you've done on my car. you just have to take the H1V1NJ flu shot before you cross the state line.
    New York
    2003 525i
    Thanks.
    I will give you my War album. Vinyl. That album along with this theme changed my life:
    http://www.entertonement.com/clips/f...nk-to-the-Past-
    Dec 2007
    NJ
    02 540i 6MT
    i've got more u2 that you can shake a stick at. i have bootlegs better than their cd releases.
    Teaneck, NJ
    2007 530i 6
    My drains are free and clear, and I too, will be at the good-ol Giants Stadium Sept 24th watching the Best Rock band of All-Time--U2
    Been to the following tours: POP MART Tour(1997), Elevation Tour(2001), Vertigo Tour(2005)
    2007 E60 530i - Current
    2002 E39 530i - RIP
    BMW CCA MEMBER 397411
    I saw U2 in 2001 at Milwaukee, Wisconsin.
    Marvelous place BTW....
    U2's new stuff sucks IMO...
    http://www.bobistheoilguy.com/index....d=50&Itemid=56
    http://www.ceramizer.com/component/o...page/Itemid,1/
    New York
    2003 525i
    Quote Originally Posted by razzy530 View Post
    Unforgettable Fire Tour - once
    Joshua Tree Tour
    Zoo Tv - twice
    Popmart - twice
    Elevation Tour - twice (incredible dynamic as it was just after 9/11/01 and 12K people were crying in MSG).
    Vertigo Tour - once
    I have 'New Year's Day' enscribed on my bike. Custom bike and paint job. I 'died' on December 27th, 1987 during a knee surgery that took a hard lefthand turn and woke up on New Year's Day feeling dead. Lost 20lbs. and was 1/4th vegetable. That song became my anthem, "I will begin again..." as I listened to it non-stop on my Sony walkman (which had auto-reverse a fancy item in 1987).
    Bike and song:
    [ame]http://www.youtube.com/watch?v=b7Gbb2bTWAc[/ame]
    Ohio
    540i/6, 02 Excursion Pow
    Holy crap! Good find!
    "If everything seems under control, you're not going fast enough. - Mario Andretti"
    Oct 2008
    bensalem pa
    99 540i/6speed
    well the first half of this thread is very helpful. I have water on my rear passenger floor as well.
    Teaneck, NJ
    2007 530i 6
    Joshua Tree Tour
    Zoo Tv - twice
    Popmart - twice
    Vertigo Tour - once
    Bike and song:
    That was LIVE at Slane Castle, Ireland.
    Good story, great taste in music and watches
    PS. PopMart Tour was seen in Chicago June 28, 1997 and October 31st (Larry Mullen's B-Day) in Detroit
    2002 E39 530i - RIP
    NW Indiana
    00' 528i, 11' Legacy
    Only thru the wisdom and bravery of Captain America were you able to accomplish this.
    Good job men!
    UNDER CONSTRUCTION
    - 2000 528i Sport
    Got any questions about my car? Feel free to PM me!
    East Coast
    Pull n Release
    Gumbi has teh force in teh pants and is never at fault! BTW U2 -ONE is FTW!
    Another FP5241 Creation
    Parting out M54 Engine. Intake and all. Cats avail as well. PM ME!
    NW Indiana
    .. and teh Force is STRRRRRRRRRRRRROOOOOOOOOOOOOOOOOOOOOOOOONNNNNNNNGG GGGGG in you lol
    UNDER CONSTRUCTION
    - 2000 528i Sport
    Sep 2009
    USA
    any time, any place
    absolutely fascinating. I will be checking my door seals for tumors.
    Nov 2009
    Campbell, CA, United States
    2002 BMW M5
    bimmerfiver,
    Thanks for the info & I will have to check mine now...
    West Michigan
    98 540iA (Prd 11/97)
    Keith,
    Nice detective work.
    Sorry it took so long to tow this into the DIY section, but I just stumbled on it today while looking looking for your comprehensive door realignment thread/post.
    Cheers
    Nov 2007
    OHIO
    98 528i
    I have a similar problem.... But no puddling inside the car.
    I didn't notice it when I bought the car.
    My passanger side side skirt has some surface rust on it in the middle.
    If my car sits outside- usually when I'm working, and it happens to rain, when I open the drivers side door or rear door I get a bunch of water coming out at the bottom. Hence the rust on the passanger side skirt.
    I'm assuming I need to replace the seals around the tops of the doors, But I don't know.... Can't find any DIY's on that!
    Any info would be appreciated! Thanks!
  1. Please someone help Water on my back floor
    By 530I84 in forum 1996 - 2003 (E39)
    Last Post: 10-01-2013, 08:16 PM
  2. water leaking inside the car driver side back floor
    By Byrondonis26 in forum 1996 - 2003 (E39)
    Last Post: 04-26-2013, 11:38 AM
  3. Water in the back floor board
    By lt4you2 in forum 1995 - 2001 (E38)
    Last Post: 03-01-2012, 02:20 AM
  4. Water on the back floor of the car v8.0
    By bimmerfiver in forum 1996 - 2003 (E39)
    Last Post: 05-25-2010, 04:26 AM
  5. Water in the back floor
    By Jbduffy1 in forum 1996 - 2003 (E39)
    Last Post: 09-27-2007, 01:47 AM
