Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 63
Thread: Best E39 M5 rep front bumper?
  1. #26
    Mar 2008
    Hollywood, CA
    2003 525i
    I, too, cannot vouch any more than I have in threads like these for OEM bumpers. That being said, I recently bought one from Umnitza and the fitment is 95%+ close to perfection--it is exponentially better fitting than the DDM variant I ended up with during that bumper-buying frenzy that took place here three or so years ago. It was cracked and really ill-fitting, so I needed a change. I would have bought OEM this time around, but I have plans on buying the Hamann competition front bumper for e39 M5s in the future, so this will suffice for now.
    There is also this. I stumbled upon it while doing some research on this topic around here. I PM'd him asking for some clarifications, but he has yet to respond:
    http://forums.bimmerforums.com/forum...9&postcount=53
    here's a helpful tip when reinstalling the bumpers. Take off the side clips on the fenders and slide them onto the bumper before putting the bumper back on . Once its on tighten the two bolts that hold the bumper in place and then tighten the plastic clips to the fender. I've done this with two bumpers and fitment is 100% perfect with my rep bumpers. No sag, and everything lines up. I don't even have the 1/2 or 1/4 inch gap between the edge of the fender and bumper. I got my first bumper off a member here who said he got it from DDM, and my newest bumper is from a guy on craigslist selling preprinted ones for $325. Paint is decent, but I have jet black so paint match isn't too much of an issue.
  2. #27
    Sep 2009
    UCF/Oviedo, Florida
    (Prd. 5/96) 528i.
    Do it once and right. Go OEM. I have seen too many friends with replica's in disapointment due to fitment issues.
  3. #28
    Apr 2008
    ARIZONA
    16' 328xiT /04' TSX 6MT
    Quote Originally Posted by d1984 View Post
    it functions fine, it's not like the bumper cover is supposed to withstand an impact. the rubber seal was a long weatherstrip type thing that goes along the top and causes the bumper to hang too low. it's probably not on the OEM bumper
    Yes, it is on the OEM bumper the engineers who designed your car put it there for a reason:
    BMW part # 51118191149
  4. #29
    SF, CA
    BMW M3
    Quote Originally Posted by sean911sc View Post
    Your spending it either way as your not doing basic maintenance tasks yourself. I'd offer to help out if I stil lived in the Bay Area. $700 goes a long way in a DIY garage.
    the valve cover gasket job is a huge PITA and i don't have 8-12 hours i feel like setting away for it. i had them change my spark plugs and fuel filter at the same time too so that's some of the labor cost, forgot to mention it in my previous post
    Quote Originally Posted by BenPRunkle View Post
    $700 for valve cover gaskets?!. . . daaamn
    540i is a big job
    the cost was for spark plugs and fuel filter too
    Quote Originally Posted by hon2bmw View Post
    probably just protects the bumper edge from cracking due to weather and vibration after 10+ years. not too worried about it. none of the M5 style bumpers fit with that piece on there, in fact it's one of the main reasons a lot of people can't get good fitment
  5. #30
    Apr 2008
    ARIZONA
    Actually, its for aerodynamic efficiency, to help keep water and debris from accumulating in the engine space and in minimal capacity, to help ensure proper air flow over the radiator.
    My rep bumper seems to fit quite well with it?
    I'm just trying to get the point across that if you had a "professional" install your bumper, and their solution to get it to fit right was to leave out parts that where put there for a reason, you may want to find another body shop.
  6. #31
    SoCal
    07' 530xi Touring
    51118191149
    Prevents two hard surfaces that flex from rubbing against each other I would gather.
    I spent a week working with a DDM bumper cover looking at all options to get fitment spot on. It wasn't going to happen unless I modified parts or went with another REP bumper that wouldn't have fitted any better.
    The reason(s) one does/doesn't perform their own maintenance will vary.
  7. #32
    SF, CA
    BMW M3
    the bodyshop i used has done a ton of M5 front bumpers. i don't see how it could be for aerodynamics since there isn't even a gap without it and it's not an exterior piece
  8. #33
    Apr 2008
    ARIZONA
    The seal keeps air from flowing through the gap that SHOULD be there. Body panels whether they are metal or plastic are never butted right up against each other for various reasons, the front bumpe is not supposed to be in direct contact with the other body panels for many reasons, mostly because it is supposed to be able to move with the compression of the bumper shocks in a low speed impact. The rubber strip keeps air flowing past the joint between the bumper and rest of the car body instead of through it, while allowing the bumper to move as needed.
    E30 people spend good money buying the EVO hood seals from BMW for their cars for aerodynamic purposes. You probably won't notice the difference and honestly if you cared enough you wouldn't have been okay with them doing what they did.
    But just be aware that BMW didn't add the rubber strip willy nilly because they thought it would be fun to make life more complicated. If anything we should be lucky enough that the bean counters didn't decide it was to expensive to include, let alone flagrantly dismissing its existence.
  9. #34
    SF, CA
    BMW M3
    Interesting. I wonder if I should buy that part and put it back on
  10. #35
    Apr 2008
    ARIZONA
    Like I said, it probably won't make much of difference at this point, very few people, go through all the trouble of buying the correct fender liners, duct work, and aerodynamic pieces that go along with the mtech bumper in the first place. I certainly didn't.
    There's a reason why "doing it right" costs so much, and also a reason why so many of us buy the replicas in the first place.
  11. #36
    Jun 2008
    U.S.
    RWD + TORQUE
    I really hate when you can see the ground through the bumper because people don't run the undertray, looks like a Honda with a bodykit. That's the first thing I always notice about non-M's
    Quote Originally Posted by Aradaiel View Post
    I'm sorry, the m5 and the 528/530 don't feel the same driving them. The m5 is leaps and bounds better. My loud pedal actually does something in the m5, steering is tighter, suspension is tighter and just feels better. The ONLY thing my 525/528/530 does better than my m5 is use less fuel. The whole rack and pinion thing is stupid, they feel the same.
  12. #37
    May 2012
    Chicago, IL, USA
    2001 BMW 540i/6 Sport
    ...very few people, go through all the trouble of buying the correct fender liners, duct work, and aerodynamic pieces that go along with the mtech bumper in the first place. I certainly didn't.
    have you noticed any complications or problems with that being the case?
  13. #38
    Apr 2008
    ARIZONA
    Quote Originally Posted by donbruno View Post
    I'm running my stock 540i underpanel, and trimmed the fender liners, there is a gap where the Mtech "pork chops" go on the bottom, and it I believe I had to trim some plastic in front of the radiator as well.
    I have not noticed any problems, everything fits securely with the exception of the fender liners, which tend to come out of place from time to time, and, after an unfortunate run in with a puddle that required me to purchase another Hella euro healdlight assembly I am not happy with the fit of fender liners nor the opening in the bottom from the missing "pork chops."
    I plan on buying the full OEM setup at some point, including the bumper, simply because I think it looks a little ratty at times especially when looking at it from the rear three quarter view, however it is relatively expensive and will probably cost close to $1k when all the parts are included, luckily I can do the paint myslef and don't mind re-using the replica bump strips, grill and fogs.
  14. #39
    VA
    E63AMG/Z31/Tacoma/F31
    So you currently have the Umnitza reps? I was thinking of getting mine from them in ABS.
  15. #40
    San Diego, CA
    2000 528i Touring 5spd
    I think a lot of the opinions here don't consider the situation for 'upgrading' to M5 bumper.
    OP stated that his current bumper is in bad condition. So he wants to 'fix' it...which is different than someone with a bumper that has no issues, but wants to just upgrade to an M5 bumper.
    If you're purely doing it for looks, it probably means you won't be happy with a bumper that doesn't fit perfect.
    If you're doing it because your bumper is torn, you're doing it more out of necessity.
    In the latter case, you prob don't want to spend 1/4 - 1/6 the value of your car on a front bumper. And you prob wouldn't mind 1/4" off compared to a torn bumper. At least that's why I went with DDM.
    It wasn't a perfect fit, but mine came out less than 1/4" off on the fender and I couldn't be happier with the change from a ripped front bumper to fresh M5 looking bumper.
  16. #41
    Jun 2008
    Newtonburg, WI
    99 528iT, '78 R100RS
    Quote Originally Posted by derekmw View Post
    OK; this is where I am. I am also speculating that as time goes on, every E39 will eventually have an M5 bumper cover. Here's why.
    Those who don't much care or think about their cars still think it's OK to roll right up to a curb or parking block. They then destroy their bumper cover as it snags when they back up - and then spend an inordinate amount of time whining in forums because the car was 'designed wrong'. [Yeah; right. It's not like you could be expected to know how long/wide/low your car is before doing something stupid, could you?] Then, there's a car like mine that needs a cover. Of course, there are no OEM non-M covers because they've all been dragged over curbs. So now we're left in the aftermarket where there's no real compelling reason not to sell M-style bumper covers. After all, they look better to most people and they're far more plentiful at cheap prices. So an M-style cover it must be unless you want to spend cubic yards of cash for new OEM.
    Still, I wouldn't say 'no' to a used stock white OEM bumper cover being replaced by an M-style ...
    C.R. Krieger #53302
  17. #42
    Feb 2001
    East Bay, CA
    M5, E61
    to throw our hat into the ring, though it's already been thrown, we do offer prepaint at $125, but that's going up now to $150 for prepaint. If you want to order, we have many in stock for $129 already and with shipping it's the best deal going
  18. #43
    Jan 2005
    Nashua, NH
    15 328xi
    I'm quite pleased with my PP M5 bumper from Umnitza. Sure it's not perfect, but for 1/5th the price of an OEM M5 bumper, I wasn't expecting it to be.
    Sport | M5 Headlights | M5 Style Front | Intake Resonator delete | H&R/Bilstein | Euro Armrest | M5 Rear Sway | Thule | 3-Pedals | Fully Maintained | 190K Daily Driven
  19. #44
    Apr 2008
    ARIZONA
    Quote Originally Posted by RVAE34 View Post
    I currently have the PP DDM rep, before that was an ABS rep, not sure from whom since it was on the car when I bough it.
  20. #45
    Feb 2010
    San Diego, CA
    2003 525I
    Thumbs up for DDM. Read through and I still see guys commenting to go OEM. Go for it if you got the bucks, but the reps look identical to me.
    I've had mine now for over 2 years with no complaints.
    2003 BMW M3 - Alpine White - 6 speed
    2002 BMW 330i - Gray - 5 speed
  21. #46
    Apr 2006
    Fall City ,Wa
    E36 Turbo, E39 M5
    Quote Originally Posted by umnitza View Post
    For the front bumper does the ABS upgrade for $99 correct the bumper being short on the sides?
    93 325is: obd2 M52, 22rpd tuned, 6266, RSI manifold, 555whp on 18psi
  22. #47
    Nov 2011
    Indianapolis, IN
    02 540I-6, 01 IS300
    Quote Originally Posted by E36 328is View Post
    +1 I would like to know this as well. Is there an actual noticeable difference with this bumper?
  23. #48
    Apr 2012
    Salt Lake City, Utah
    2001 BMW 540i6
    Quote Originally Posted by joel540i View Post
    I'm interested as well. I've read other places that ABS is easier for paint to adhere to so it's easier for a body shop to work with.
    Not entirely clear on that though.
    Is anyone running a ModBargains brand rep bumper?
  24. #49
    VA
    I will be buying the ABS rep bumpers from Umnitza and painting them myself in a few weeks so I hope to update on fit/finish and ease of prep/paint also using PPG base/clear like I did with my trim and pillars.
  25. #50
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    I will be buying the ABS rep bumpers from Umnitza and painting them myself....
    I think this is what I will do too (but will let a pro body shop do the paint-match).
    Frankie
    Texas, USA
    frankies-bmw.com
