I was poking around under the hood of my new 850i tonight and found something that I don't think is quite right. The acoustic engine cover is only being held on by gravity. I looked all over under the screws that appear to hold it on but there is nothing there for these fasteners to fasten to. Are there some kind of removable receptacles that they latch into that are apparently missing from my engine? Does anyone have a picture where I could see them?
BTW as far as sound goes what is making so much noise that this cover is needed? the ticking of the injectors?
I'd say this is about all it covers sound wise.
And it keeps the heat nicely around the fuel rails.
I removed it on my M70 and will do so as well on the M73 which is going to be installed soon.
My M70 (removed meanwhile)
A customer's 850 after swapping the original M70 against an M73
I always wondered about that thing trapping heat and warming the intake air. Looks pretty dang cool without too. I think I might just remove it. I wasn't looking forward to refurbishing the rubber seal anyway. Thanks for the info.
Hmmm. Could it be the other way around? That it stops heat from the exhaust pipes from coming close to the fuel rails and the cables?
If you have a close look at Wokke's second picture, you will notice that there is a part missing under the intake manifold. This part (# 5 in cartoonz's picture) is usually attached to the underside with three small screws in the u-formed recesses.
It could very well be that the acoustic cover together with those parts actually insulates the fuel rails and cable harness from excess heat. It does get hot under the hood. The air being sucked into the intake manifolds might be able to keep that area somewhat cooler....
Love the \\\Wokke badges I bet some people have asked you why you put ///M badges on the wrong way
1994 E31 840CI "Sport" 4.4 - Hellrot Red - Black Nappa Leather - Every Option available - OEM 65M Wheels, EDC delete/Bilstein, M60-M62 engine transplant, updated software, CSI Steering box & AHK, Full AC Schnitzer kit, Wood Trim, Front Plate Delete, Xenons + LEDs, Tints, Black Ind. headliner, BREMBO BBK, Hamann Exhaust, Custom aluminium throttle bushings, KAW springs, Strong Strut, Greg K GenII sway bars, Camber Plates, Stut tower reinforcements, X-Brace, Wokke chips, Wokke Sphericals, PM Steer Plates, H&R Spacers, Pioneer AVIC-F60DAB + more.
1994 E34 530i - Calypsorot + Many mods
2008 E66 760LI V12 - Every Option Available + Full Individual Composition
2015 F02 750LI Xdrive - Every Option Available + Full Individual Composition
2013 E70 40d TT - Full BMW Performance Kit
2016 F06 M6 Gran Coupe Individual
It was just a thought - you are right about the water pipes.... But why would a car manufacturer install useless equipment....?
Surprisingly no one has asked that so far. As a matter of fact the Motorsport GmbH is using MY badge the wrong way around
I wouldn't call it useless. initially this car was designed to be a luxury V12 GT and I guess even the sound of clicking injectors is not tolerable.
But guys like me who also think that the OEM exhaust system is way to noiseless can live perfectly with this clicking sound.
Wolf - here is a photo of the heat shield on my Alpina after taking the intakes off. From what I understand from others, this did not come from BMW this way.
Interesting photo Roger, thanks for postig that. I didn't even think to look at that on my E32 B12 5.0 when I did the intake manifold gaskets on it.
Why would Alpina put the NACA duct in on the B12 5.7, with a corresponding hole in the acoustic cover then? Isn't that to cool the fuel rails down?
The kids:
Alpinas: 91 E34 B10 Biturbo; 91 E32 B12 5.0; 91 E34 B10 3.0 Allrad (mom's car); '91 B10 3.5
Bimmers: 91 E31 850; 93 E34 525i w/ aftermarket turbo; '01 X5 4.4; 93 E31 850i Dinan TT; 89 E32 750il Dinan TT; 92 750il w/ S70 engine and transmission
Mercedes: 92 600sel; 93 S600 Lorinser
VW: 04 Jetta GLS TDI
It is to cool the injectors and rails.
Quick question: I see timing chain - thought the 5.0 was M70 based and belt?
Current Cars:
1994 BMW 850 CiA (2017 km). My black on black Wokke'd 5.4l V12 autobahnmuncher
1992 Donkervoort S8AT (105k km). The mad dutch "Super 7." 300hp/ton of turbo power!
2013 VW Caravelle 4Motion (57k km). A dark wine red 180PS/400Nm 2.0 BiTDI rocketvan
2007 SMC F-Kart 50. 88cc of street legal go-kart hilarity, and a 1968 Cadillac Coupé DeVille Convertible 472.
"The best way to go broke-by-german-car is to buy an 8 series bmw with a v12" - Perc
"Torque is like pron. You can't really define it, but you will recognize it." - ElToro
I guess eventually heat will soak into the manifold from the head but it may help with hot start problems. Some data using an infra red thermometer for one with and without a cover would be interesting.
Some alternative thoughts:
1- It's possible that the engine cover, oil drip catcher, and rubber gasket against the hood are meant to channel an accelerated air flow from the fan directly across the top of the engine and down the bell housing.
2- Water in the cooling system is considered cool to engine designers. Liquid-to-air turbo intercoolers work on this principle.
3- Alpina doesn't bat 1000. The NACA duct and the coolant pipe cover could be mistakes; how would you know? Anybody ever put temp sensors in there to test it? FWIW
How come the middle half of any project always takes the most time?
Alpina have confirmed that the NACA duct is due to overheating of the injectors. I can't find the source of it atm, but it does work.
Current Cars:
Subscribed. Wokke...Still working on those pics of wheels.
I don't doubt that this is the stated reason or that Alpina believes that the solution they devised works. I speak to them occasionally and they're unfailingly obliging and informative, and I have no reason to doubt their engineering prowess. Maybe the idea is to enhance the (theoretical) existing flow under the sound cover with the venturi effect of the Naca duct? AFAIK they never did this again on any other car, such as the 6L M73 sedans.Originally Posted by 4drian
Thanks for this info Roger.
Without knowing this I actually thought about such a solution and the fact that ALPINA did it shows I'm on the right track.
Agreed. But even engineers consider 80°C or whatever you have in there on a hot summer day a bit high for fuel. As a matter of fact the 850i I recently had in my shop for the M73 conversion had an alloy insulation wrapped around the fuel rails. And it definitely looked OEM and not self made. But it's not listed anywhere as a spare - or I at least can't find it.
you mean the gold OZ I have test fitted?
luckily.
I knew I had taken a picture of the alloy wrap around the fuel rails.
Here it is:
Does anyone have any pics of the said 5.7 NACA duct + hole in the acoustic cover?
Has anyone ever thought about stuffing some (fiberglass??) insulation in the valley which the coolant pipes travel through, in the M70?
I'm thinking about doing so when I do my Schrick swap.
[QUOTE=wokke;25337761]I'd say this is about all it covers sound wise.
What sort of results have you observed with the adjustable fuel regulators? And how did you plumb them in?
If I had a penny for everytime someone commented on my poor fuel economy, I'd have enough to get it to the petrol station.
They do look cool!
Current Cars:
