Page 3 of 3 FirstFirst 123
Results 51 to 64 of 64
Thread: Z3 Cracked Front Dash by Windshield
  1. #51
    Jun 2014
    NJ, USA
    2000 BMW Z3 Roadster
    Be careful prying out chunks. You don't want to damage the dash piece below it that it screws into. Also, when you install new one it might be advisable to spray it with a UV protectant Clearcoat to avoid future repeat problems.
  2. #52
    Oakdale,CA
    z3 2.3 z3 3.0
    Quote Originally Posted by kojohns View Post
    ECS Tuning has pretty good pictures of the bottom side of the trim part... this will help you see where the 6 screws are so you can limit any damage when removing yours. What's your plan for reattaching the new part if not using the screws? glue?
    http://www.ecstuning.com/Search/Site...0975/ES119220/
    Thanks The car also needs to have the windshield replaced. So I plan on drilling the threads on the plastic part enough
    so it can be pushed down over the screws and a little epoxy on the threads should keep it tight w/o having to remove the dash.
  3. #53
    Aug 2014
    Fountain Hills, AZ
    2001 Z3 3.0
    It sure appears to do it right the dash has to come out. I am tempted because there are a couple of other issues I could address. One is my temp door sticks and the bracket for the left a/c outlet/headlight switch panel screw is gone. I have toyed with idea of some kind of cover. A plate of sort glued over the crack, or some type of material over the entire piece. What though-Leather, vinyl, plastic. There are options, but original and as new means pulling the dash. I suppose many have new parts they have ordered and are waiting until there are enough opportunities to justify pulling the dash.
  4. #54
    Jul 2012
    Asheville, NC
    2001 BMW Z3
    (1) Do you still have a beige spare cover?
    (2) Does it appear that a second cover can be fit over the original (assuming all the bumps and connections are ground away on the bottom side)?
    Thanks.
  5. #55
    Oct 2013
    Tennessee
    2000 M roadster
    Quote Originally Posted by Z3X2 View Post
    actually sounds like a decent idea.... keep us posted on how this goes.
  6. #56
    Feb 2010
    Wasuau, WI, USA
    2002 BMW Z3 3.0L
    cracked dash cover on my 2002 3.0i roadster. i'm also going to replace the windshield very soon. Final word here, is it possible to replace the cracked cover without removing the dash?
    also when i order a windshield will the vin number notchout be there?
    Joseph A. Smith
  7. #57
    Feb 2010
    Wasuau, WI, USA
    2002 BMW Z3 3.0L
    No replies so i just ordered parts and hope for the best. i'll take pics to document my process.
    https://www.ecstuning.com/b-genuine-...h/51458399931/
    https://www.ecstuning.com/b-genuine-...z/51458410975/
    Joseph A. Smith
  8. #58
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    According to this post, the screws come up from under the dash.
    https://www.bimmerforums.com/forum/s...0#post25301500
    BMW MOA 696, BMW CCA 1405
  9. #59
    Apr 2012
    Houston, TX
    2002 M Coupe
    Curious about your progress. I'm in the same boat on my Z3 coupe. Have the part, just too lazy and cheap to pull the dash
    ___________________________________
    Always looking for my next
    ///M Coupé...
  10. #60
    Dexter, MI
    BMW M235iR / SpecE30
    Bump. Has anyone had success in replacing this trim piece 51458410975? https://www.ecstuning.com/b-genuine-...z/51458410975/
    It's odd that the BMW dealership and realoem.com do not show this part as being available on my Z3 3.0i Coupe. It appears that either the extended leather dashes, or all M's, had a 1-piece dash, without this plastic piece. I definitely have it, though, and it's in about 6 pieces.
    The windshield is currently out on my coupe while Safelite tracks down a windshield gasket, and I'd like to replace my cracked dash piece. It sounds like the proper way to replace it is to remove the entire dashboard, though. Is that true? Has it been confirmed that it screws in from the underside of the dash?
    Thanks!
    -Anthony Magagnoli
    #80 BMW M235i Racing - Pirelli World Challenge TC - 2017 Rookie of the Year
    Rooster Hall Racing / FCP Euro
    '87 BMW SpecE30 #007 - 2012 NASA SpecE30 NATIONAL CHAMPION
    '08 BMW "130i" 6MT, '01 Z3 3.0i Coupe 5MT
    '88 Pontiac Fiero GT 5MT (my childhood dream car!)
    Send Your Teens to Street Survival
    Drive Faster Now
  11. #61
    Apr 2012
    Houston, TX
    2002 M Coupe
    I didn’t end up doing it. I still have the part if anyone needs it.
    ///M Coupé...
  12. #62
    Oct 2012
    Louisville, KY
    Quote Originally Posted by Z3SpdDmn View Post
    Bump. Has anyone had success in replacing this trim piece 51458410975?... The windshield is currently out on my coupe while Safelite tracks down a windshield gasket, and I'd like to replace my cracked dash piece. It sounds like the proper way to replace it is to remove the entire dashboard, though. Is that true? Has it been confirmed that it screws in from the underside of the dash?...
    It's not clear from this link. With the windshield out, it sounds like they drilled the cover's screws out from the top to avoid removing them from below with dash removed:
    https://www.bimmerforums.com/forum/s...8#post30039028
  13. #63
    Dexter, MI
    Quote Originally Posted by Vintage42 View Post
    Sounds like that's the case....
    I have the VIN sticker on order. I guess I'll have to consider a dash swap possibly at the same time as replacing this part. Or swap in a dash that doesn't use this part. Sounds like that would either be an M dash or an extended leather dash. I can't quite tell what it's tied to.
    Maybe swap to grey/black? My interior is black with fully blue seats (non-M sport seats) and blue in the door cards. Currently with walnut trim. I plan to eventually go to aluminum trim and custom seat covers that would be some combo of grey/black/blue.
    https://www.ebay.com/itm/BMW-Z3-M-Ro...ZxVAx#viTabs_0
    -Anthony Magagnoli
    Drive Faster Now
  14. #64
    May 2018
    Detroit, MI, USA
    '85 535i, '99 Z3 Coupe
    Quote Originally Posted by sitdownrando View Post
    @sitdownrando - Do you still happen to have this piece??
