I'm having a no start issue and I have narrowed it to a starter or a starter relay as I can bump start the car.
Can someone tell me where the relay is located at!?
You may not have one, pretty sure the starter relays were eliminated in the 540's with the tu engines.
They use to be behind the glove box.
If you don't have one the EWS provides 12 volts directly to the starter solenoid.
It's behind the glove box(unless it's a 6spd---6spd's dont have relay), within the enclosure where GM is, and is pain in the a** to get to, lol,
http://wds.spaghetticoder.org/en/zinfo/E39_EK6324A.htm
Auto
http://wds.spaghetticoder.org/en/svg...50.svg?m=e3902
manual
http://wds.spaghetticoder.org/en/svg...22.svg?m=e3902
WTF are you talking about? You got me confused with someone else? I dont know who I'm speaking to?????????????????????????????????? Should I know who I'm speaking to? and tremble in my boots or something, lol.
Ohh wait a minute, are you going to sick on me one of those keyboard warriors from the forums? cause I told the truth?, lol. How typical for the American sheeple to sick police, govt., etc, etc, on your own neighbors.
Originally Posted by supra94tt
I see that you've never done this job(removing relay for testing and checking signals). Better to remain silent and be thought a fool than to speak and to remove all doubt .
I've done it many times and do know what I'm talking about otherwise I wouldn't have questioned your rude comment.
Maybe I'm just not use to your style of writing, for example:
There was a much better one about a month ago, I'm sure you know the one I'm talking about.
So, zrider91r, how did you make out with the starter problem?
I know this is an old thread but I am doing a manual swap on my 98 540i and need to know how to access that relay. I have removed the plastic 10mm nut on the white carriage that everything is attached to but I cant see what else needs to be done to remove this.
