Hi everyone. Here is a quick how-to thread on removing the door lock mechanism. It isn't especially hard. All that's needed are a few basic tools and a little patience. My door handle stopped working when the door was in the lock position (couldn't unlock it, couldn't pull the handles). Here's how I removed mine:
Step 1: Remove the door panel. Pop out the little screw covers on the door handle, window handle, etc with a small flat screwdriver and unscrew the hardware holding on the handles. Then work the panel off by gently inserting a flat screw driver between the panel and the door. I started at the lock side of the door near the bottom. You might break a few clips. These can be replaced if needed.
When it's done, it will look something like this:
Step 2: Remove the bolt for the window track. It's 10mm and located near the mechanism on a piece of metal holding the window track bracket in place.
Here's a picture of where the bolt goes (I have it all removed):
Step 3: Remove the track and the black box attached to it (which prevents access to the door lock mechanism). Start by removing the rubber strip the window uses and peel it off the metal track starting at the bottom and working your way up. With that completed, pull the outside handle up as if you are opening the door, and shimmy the track a little at the same time to remove it.
Here is what the rubber strip looks like:
Here is the removed metal track:
I went ahead and stuffed the rubber liner up in the door a bit so it wasn't in the way (without damaging it):
Step 4: Now you can begin removing the mechanism. First unscrew the 3 Phillips-head screws and 2 allen bolts. Here's where they are located:
Step 5: Now that the mechanism is loose, there are two rods to disconnect. Remove the connecting rod from the key tumbler to the mechanism first (labeled 1st in picture). Just pull straight back from the circlip on the mechanism and it will come free. You'll probably need a new circlip, as I did, but they are available here:
http://realoem.com/bmw/showparts.do?...86&hg=41&fg=40 Now, the next part is up to you. I did NOT remove my tumbler and I did NOT bend the connecting rod from the inside door handle to the mechanism. I simply wiggled the left part of the mechanism in the picture free, then flexed the connecting rod to the inside handle and slipped it off the mechanism. From there I could wiggle it past the tumbler. If you can't do this, however, use needle nose pliers to bend the hook on the rod and just remove it that way.
Here are the two locations where rods must be removed:
Voila, the mechanism is removed:
Install in reverse order. The picture below shows the problem with mine. Somehow the third spring at the very top right of the mechanism snapped, and so if you pull the outside handle while the door is locked (say, you forgot you locked the door and tried it), it will jam the mechanism altogether... That's the broken piece sticking out:
And a view from the side:
Still trying to track down that spring... It's odd, and I can't seem to find it on RealOEM. Not a good sign. Might go to the local Pick-A-Part.
And as a bonus, I'm including a picture of my garage below. I know it's kinda weird, but I love seeing other people's garages, and thought maybe I'd share mine, humble though it is. But. . .it has everything needed to do a little fab, engine work, etc. And plenty of room when both cars are out for a single big project. Yes, I do wood working. And yes, that is a poker table from the 50s I'm restoring some weekend when time allows.
