Page 79 of 80 FirstFirst ... 2954697071727374757677787980 LastLast
Results 1,951 to 1,975 of 1976
Thread: Forced Induction Section Fabrication Thread
  1. #1951
    DeWitt, Michigan
    '97 540i/6, '97 328i
    I hear you on the glides for circle track stuff, but those are usually set up in some way without a torque converter, aren't they? I have been under the impression that most people who run autos in autoX usually run 3-speeds like TH400s or TH350s, but I really didn't know.. What torque converter characteristics do you have in mind for your setup?
  2. #1952
    St. Anthony, IN
    1992 3000GT VR4
    It’s not a competitive autocross car. Obviously these mods put it into some crazy unlimited class. It’s just for fun.
    And depending on circle track classing, they are actually required to run a converter. My buddies used to get “creative” with the rules and only ran a converter shell but was direct drive until they got smart and started using IR to check heat on “converter”.
    I have a 10:1 5.3l on e85, driving only a single 80mm turbo. Smallish crossover diameter to keep up velocity. Plan is to have enough off Boost and low boost tq, to flash the converter to the engine’s happy zone quickly. Should be a nice 5k-7kish setup that has minimal “lag” and still make 1000whp when needed. I also have a dry shot of nitrous in the car from 4g63 days, that I will plumb pre turbo for cooling the whole charge. Can be used for spool if needed too but I doubt it will be. That worked great for 2.0 and 69mm turbo on the autocross though.
    9.5” converter. Steel stator. 1.80 straight cut 1st gear. 1:1 2nd/drive gear. 3.31 rear end (also have a 3.56 on shelf.) 26.5” street tires. Will have 28x10.5 for drag. 1st gear should have plenty of usable speed range for autocross with the magic of converter.
    1992 3000GT VR4. 4g63 Swap. DSM 2g Auto Trans. 10:1, E85, AEM, FP Super 99 turbo. Best ET 9.98...Best MPH 137.8
  3. #1953
    DeWitt, Michigan
    That sounds excellent! So is that 9.5" converter a PTC ~$1,000 one? I'm not up on glides, but I'm guessing that straight cut first gear must be aftermarket? What does it cost to put together a decently strong glide? I just built a TH400, and that was fun.
  4. #1954
    St. Anthony, IN
    1992 3000GT VR4
    Yes $1k for converter. Free restall in first 30 days.
    Yes aftermarket straight cut 1st 1.80 (many other ratio options.) 10 clutch pack and other internal upgrades. SFI rated aftermarket case. Rated to approx 1800HP. $3500.
    You can build a glide fairly inexpensively on your own, the case is weak point though if you send a bunch of power to them. Aftermarket case is $800-1000. No scattershield needed if drag racing as case if SFI rated for containment. So at that point, I was better off just buying a prebuilt trans by any number of big shops. PTC has great reviews on converters from turbo guys so that swayed my decision. (And cost. Little bit cheaper than BTE, Trans Specialties, etc).
  5. #1955
    A house
    '87 325e, '05 4Runner V8
    Been messing with titanium. It's a fun metal to weld once you figure out a few quirks it has, in addition to being an argon whore. Not sure if I am going to trim down the exit pipe or just run it Bosozoku style
  6. #1956
    DeWitt, Michigan
  7. #1957
    A house
    Quote Originally Posted by tptrsn View Post
    Nice work Juggs! Are you building a drift car, or SLR for road racing setup?
    Thank you sir. For teh road racing. Makes the car feel so much better, especially the steering speed. BMW steering is painfully slow on track.
  8. #1958
    St. Anthony, IN
    1992 3000GT VR4
    hot pipe. Need to add BOV and iat bung. And weld a little lip on TB side so coupler doesn’t blow off. (Won’t be using this crank pulley. Have a shorter one.)
  9. #1959
    air, dirt, fire, water
    95M3 92525iT 78810 95525
  10. #1960
    A house
    Stainless cover for the 210 diff with oil cooler provision. Huge thanks to someguy2800 for the flange!!!
  11. #1961
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by TheJuggernaut View Post
    Very nice.
    1989 535i - sold
    1999 Tiag/Dove M3 - sold
    1998 Turbo Arctic/black - current
    2004 TiAg/Black - Current
    PTE6870 | 1.15 ar | Hp Cover, Custom Divided T4 bottom-mount, 3.5" SS exhaust, Dual Turbosmart Compgates, Turbosmart Raceport BOV, 3.5" Treadstone Intercooler, 3.5" Vibrant resonator and muffler, Arp 2k Headstuds | Arp 2k Main studs | 87mm Je pistons | Eagle rods | 9.2:1 static compression, Ces 87mm cutring, Custom solid rear subframe bushings, Akg 85d diff bushings, 4 clutch 3.15 diff, , Poly engine mounts, UUC trans mounts W/ enforcers, 22RPD OBD2 Stock ECU id1700 E85 tune, 22RPD Big power Transmission swap w/ GS6-53
  12. #1962
    Vancouver, B.C., Canada
    '97 M3
    VSS not needed?
  13. #1963
    A house
    Quote Originally Posted by chikinhed View Post
    VSS not needed?
    No, I ditched the trigger ring to clear the M3 cover and use a wheel sensor. But I was actually going to put it back with this cover, waited weeks for the ring to come in from Germany and after all that, spent over an hour trying to press the ring back on the carrier and gave up.
  14. #1964
    Vancouver, BC Ca
    1993 325is
    I ended up tack welding the ring (salad chopper ring, right?) onto the LSD. The fit wasn't quite right after I had to cut down the "tongs" of a 6 cyl ring to fit in a 4 cyl housing. Kept popping off. 4 little tack welds and it's been good for a really long time.
  15. #1965
    A house
    Quote Originally Posted by jakermac View Post
    I'm sure I would have figured it out eventually, with enough heat and hammering. But I ran out of fucks to give. Plus fine metal shavings were coming off of it during each attempt, I was worried about getting them in the bearing or bashing the bearing by accident. Whatever, the wheel sensor signal works fine, I'd just prefer to pick up from the diff if I can.
  16. #1966
    Norristown PA
    330tti/e46m3t/01M5/Mcoup
    Your diff cover has nipples Juggy.
    www.prussianmotors.com '95 PT6262 330ti / '03 Maximum PSI M3t on e85 / '00 540 6spd / '01 M5 / '01 M Coupe
  17. #1967
    A house
    Quote Originally Posted by bubela View Post
    Like in Total Recall
  18. #1968
    Jan 2017
    Keokuk, Ia
    m50 turbo w123, 4g63 e30
    Roll cage progress on my z3
    Sent from my Pixel 2 XL using Tapatalk
  19. #1969
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by Boostedhoopty View Post
    whats the plans for that car?
    86 325es, 2.8L m50, S472sxe, MS3pro Ultimate, e85, solid rear axle, 4 link, spool, TH400 trans, Protorque converter, 28x10.5w slicks, zip ties
    Best = 9.43 @ 149.15 mph, 1.30 60 foot 28 psi boost
  20. #1970
    Jul 2005
    PEI, Canada
    2001 330i
    No kidding!!!
    Side exit exhaust.
    Drag seat.
    I'm assuming the backstays are going from the main hoop corners to the plates on the rear frame rails?
  21. #1971
    Jan 2017
    Keokuk, Ia
    Quote Originally Posted by PEI330Ci View Post
    No kidding!!!
    Side exit exhaust.
    Drag seat.
    Correct. It's going to be setup for drag racing primarily. The plan is to max out the 6266 or the stock pistons, whatever happens first haha. Still has a 5 speed zf and 188mm diff
  22. #1972
    SW Florida
    99-01 M Cpe & Rdts, X5M
    I have stacks of those rings. Stacks!
    I'd have sent you one for postage (they used to be less than $5 each, now a little more than double that).
    Trick to getting them on, I've found, is a roll of duct tape, a piece of a 4x4x6-8" wood, and a BFH. Position the ring as squarely as you can, with the (preferably full) roll of duct tape on top of it; place the block of wood across the roll, and ONE BIG WALLOP! I then go around it with a blunted chisel to make sure its fully seated. pass a magnet around it to gather any shavings, and straighten__if needed__any blades that were misaligned in the process.
    I did one a couple days ago, and drove it fully home with one (1) hit! Remember, I'm all the time putting E-36 covers on M Rdstrs & Coupes, so swapping to a smaller diameter wheel is routine stuff.
    (note that I have since substituted the BMW hub-flange tool seen to the left of the differential for the roll of duct tape, but same procedure involved)
  23. #1973
    A house
    Bye everybody, I fucking quit.
  24. #1974
    Manchester, N.H.
    96 332IS 6466 turbo
    Your word is all we have. You a lady of your word ?
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  25. #1975
    A house
    No, changed my mind already.
