Page 77 of 80 FirstFirst ... 27526768697071727374757677787980 LastLast
Results 1,901 to 1,925 of 1976
Thread: Forced Induction Section Fabrication Thread
  1. #1901
    Manchester, N.H.
    96 332IS 6466 turbo
    Had a free hour last night, looked around and found a piece of Vibrant 3" aluminium and an aluminium weld fill cap and boss. So, made this. Could be a travel mug, could be some type of liquid holder. Dunno. Just another pos to add to the dumb stuff I make when I have time to play.
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  2. #1902
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Cool, but kind of an expensive POS to add to the pile, with the cost of that Vibrant cap and all..
  3. #1903
    A house
    '86 325e, '14 VW EPA
    Project boost control continues
  4. #1904
    Mar 2012
    Renton, Wa
    98 m3
    If that doesnt work.....
    Are you adding a divider or something for the twinscroll?
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  5. #1905
    Manchester, N.H.
    96 332IS 6466 turbo
    I have heard that you really need it to be divided all the way to the gate, or the turbulence will hinder the twin pulse design/theory.
    1996 332IS
    Built 3.2
  6. #1906
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by tptrsn View Post
    Not if I fill it with hookers and cocaine. Bam cash money.
    1996 332IS
    Built 3.2
  7. #1907
    A house
    Quote Originally Posted by vollosso View Post
    I will if I ever build a twinscroll manifold.
  8. #1908
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by TheJuggernaut View Post
    No shit? So twinscroll housing open manifold?
    1989 535i - sold
  9. #1909
    A house
    No shit.
  10. #1910
    Manchester, N.H.
    96 332IS 6466 turbo
    Close off the manifold. Tired of all this open this split that. Seal the dam thing and be done with it.
    Back to important things, where is Flavor Flav nowadays ?
    Is Charlie Manson dead ? Who raped the Corey's ?
    Who here knew Spacey was bi ?
    How many pits in a peach ?
    Tree falls in the road, over the palace state parkway, how many men are dispatched to get that tree off the parkway ?
    1996 332IS
    Built 3.2
  11. #1911
    DeWitt, Michigan
    You're very philosophical today, or is it just curious?
    Trudat
  12. #1912
    Finland
    e91, e38, c4, b4
    What's the problem with twinscroll housing and open manifold?
    BMW 320d Touring e91 -06 ----- BMW 740iA "ALPINA" e38 -00
    Audi UrS4 Avant 2.2T Twincharged @624hp/737Nm -93 ----- Audi 80q B4 2.2T @500hp/620Nm -92
  13. #1913
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by Thuppu View Post
    Nothing really. Its more like having a twin scroll manifold and utilizing it to its potential. You need to divide it all the way to the gate.
    1996 332IS
    Built 3.2
  14. #1914
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Does it matter much for a race car that is always above 4000 rpm? I figured twinscroll was best for street cars to bring in the boost sooner so it is accessible in the rpm range in which most people spend most of their street driving time.
  15. #1915
    Manchester, N.H.
    96 332IS 6466 turbo
    Screwed on a ceramic #12 Furick cup today. What a massive difference with stainless. Gas coverage is perfect. 1/16 408 filler
    1996 332IS
    Built 3.2
  16. #1916
    Apr 2006
    Minnesota eh?
    86 325es
    Were you using a gas lens before?
  17. #1917
    Manchester, N.H.
    96 332IS 6466 turbo
    Yeah, but usually a #7-#8.
    1996 332IS
    Built 3.2
  18. #1918
    DeWitt, Michigan
    My Furick Pyrex #12 didn't work worth shit for me. I don't really understand it. Every other el cheapo gas lens I have works significantly better.
  19. #1919
    Manchester, N.H.
    96 332IS 6466 turbo
    Personally I hate the clear cups. This ceramic screws on and doesn't mess with stupid orings.
    1996 332IS
    Built 3.2
  20. #1920
    A house
    Jack the gas flow. They require a min of 35 CFH to work well. I have a CK Gas Saver large Dia, that motherfucker takes 45 because it's a 1-1/8" cup. The name is ironic, I think they mean the gas saves the material cause it don't save any gas. But man do they ever make stainless and titanium happy.
  21. #1921
    Apr 2006
    Minnesota eh?
    86 325es
    I use an 8 gas lens for everything. That's what I found works for me anyway
  22. #1922
    Manchester, N.H.
    96 332IS 6466 turbo
    That's where I was as well. Well at least till this furick cup for stainless. Ran 20cfh and I got only gold color running around those pieces.
    1996 332IS
    Built 3.2
  23. #1923
    A house
    Try a 6 or even 5 for aluminum. The smooth flow keeps the puddle clean but the small orifice drastically reduces the etching zone
  24. #1924
    DeWitt, Michigan
    Agreed!
    I guess I will keep that in mind if I ever really NEED to make some super pretty stainless or Ti welds, but until then they're staying in the drawer. My limit is about 20cfh for an actual job, because I hate knowing I'm going through argon like there's no tomorrow.
    Me too. Usually on a $12 WP9 torch from Amazon, too, lol.
    That right there is VEEEERY interesting!!!
  25. #1925
    Manchester, N.H.
    96 332IS 6466 turbo
    I REALLY REALLY HATE TAPATALK !!!!
    Seems like it takes 10 F'N min to make a dam post. I'm prepping myself to quit this forum as since the BFC app broke, it has sucked since.
    Anyway. I'm reinforcing a trans mount
    1996 332IS
    Built 3.2
