Page 75 of 80 FirstFirst ... 255065666768697071727374757677787980 LastLast
Results 1,851 to 1,875 of 1976
Thread: Forced Induction Section Fabrication Thread
  1. #1851
    A house
    '86 325e, '14 VW EPA
    Quote Originally Posted by tptrsn View Post
    What I really want to know is whether that sharpener works well on carbide tipped blades for 14" dry-cut saws? My last blade lasted through about one cut of 4" 416 stainless tube before it was dull... I certainly won't be using that blade on stainless again, but I'd like to sharpen it back up for aluminum.
    The trick with stainless is you must use absolutely zero pressure. Otherwise it melts very easily and deposits on the blade.
    It does work for sharpening the blades but the trick I found was not to sharpen the teeth the way most people including the instructions show you. In my case and in your case, it's not the front of the teeth that needs attention but the top. I was able to successfully revive my blade with the sharpener once I realized this - sharpening the faces of the teeth did nothing.
  2. #1852
    DeWitt, Michigan
    '97 540i/6, '97 328i
    So that sharpener can be brought around to do a nice job on the tops? I guess I'll have to pick one up. Especially if it's also good for tungstens.
  3. #1853
    A house
    So much so that I bought two of them. I have one I stripped down to only the stand motor and blade for the tungsten, and one fully dressed for blade sharpening.
    Sorry to actually answer your question, yeah you're actually supposed to do that but the online DIYs and the manual focus on sharpening the front of the tooth. This made no difference for my blade so I was ready to give up on it and just use it for tungsten but I found a guy who said exactly what I'm saying that the real benefit is from cleaning up the tops. But you can and should do both and the sharpener will support it. It's basically just an arbitrarily adjustable arm with a centering spring loaded cone for the blade, and you can line up one tooth exactly how you want, adjust the blade stop (if you want, I'm not sure what the point is, it's not that easy to overgrind a tooth, and big deal if one is a tiny bit more ground than another) and go.
  4. #1854
    DeWitt, Michigan
  5. #1855
    Manchester, N.H.
    96 332IS 6466 turbo
    Dimes
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  6. #1856
    St. Anthony, IN
    1992 3000GT VR4
    Very nice!
    1992 3000GT VR4. 4g63 Swap. DSM 2g Auto Trans. 10:1, E85, AEM, FP Super 99 turbo. Best ET 9.98...Best MPH 137.8
  7. #1857
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by familyMAN View Post
    Very nice!
    I've been playing around w/ different tungsten. For stainless, I'm not a fan of what I used on that aluminium. That was E3 rare earth. I have a bunch of it as it was given to me. But seems OK for aluminium. I've kinda been only using 2% thoriated for steel and 2% lanthanated for aluminium. But, I guess this e3 isn't so bad.
    1996 332IS
    Built 3.2
  8. #1858
    St. Anthony, IN
    1992 3000GT VR4
    I have a bit different approach...does it hold 50+ psi Boost?...yes....okay it's a good weld.
  9. #1859
    Manchester, N.H.
    96 332IS 6466 turbo
    You known pretty dimes is more important than functional.
    1996 332IS
    Built 3.2
  10. #1860
    Apr 2006
    Minnesota eh?
    86 325es
    I second that emotion
  11. #1861
    DeWitt, Michigan
    It is hard to argue with that logic, but I have to say making pretty welds is a bit of an addiction. Once it starts happening, you want more and more.
    On that point, what I've recently found for making nice shiny dimes is that I get better appearance when I don't drop the amps between dabs. Steady pedal and just rather aggressive dab and move makes some pretty stuff happen.
  12. #1862
    A house
    I wouldn't say it's hard to argue with that logic, it's pretty easy in fact. Many visual weld attributes that are aesthetically appealing also indicate weld quality. Sometimes it's the opposite like the rainbow colors for stainless and titanium but an ugly grey steel weld, a chalky or black speckled aluminum weld are compromised. Beads with good penetration and consistent size will look appealingly uniform. A weld may be good enough but that doesn't mean it's good. I personally strive for the best quality I can even if I don't need to. Like they say, don't train until you can do it right, train until you can't do it wrong. Ok I get a kick out of it too.
  13. #1863
    Manchester, N.H.
    96 332IS 6466 turbo
    The general ignorant public thinks the better it looks the better it is. Pretty sells.
    Also, there is no reason why you can't make it look good. Especially with aluminium. You have infinite chances to make it look nice.
    1996 332IS
    Built 3.2
  14. #1864
    DeWitt, Michigan
  15. #1865
    Manchester, N.H.
    96 332IS 6466 turbo
    You been watching some 6061.com there Butters?
    I get bored, tired of looking at car stuff. Unfortunately I deal with cars ALL DAM DAY.
    1996 332IS
    Built 3.2
  16. #1866
    Jul 2005
    California
    Bima
    you need to take some close ups of these dimes butters
    on the dimes thing, in my opinion, if the guy can make perfect immaculate dimes on his work
    he knows exactly what he's doing; Therefore, a good welder.
    here's mine after figuring out how to make them on my practice plate.
    Practice beads by jet jones, on Flickr
  17. #1867
    St. Anthony, IN
    1992 3000GT VR4
    My original comment was a joke guys. But since we are talking about it, I've seen beautiful "dimes" that were barely past surface deep; wouldn't survive on my car with vibration and pressure. I think my Powdercoating was probably stronger, but they "looked" pretty.
  18. #1868
    Apr 2006
    Minnesota eh?
    86 325es
    I weld more or less a steady motion so I get more ripples than dimes. I'm way more concerned with penetration, adequate amount of filler, and trying to keep good gas coverage and the amount of crap floating around in the weld than I am about the look of the bead
  19. #1869
    Sep 2009
    Syracuse, NY
    95 M3 Turbo, 08 535xiT
    what is the tungsten of choice for aluminum in your guys opinions? I am thinking I need to delve out into other tungsten and see if my welds get any better looking.
  20. #1870
    A house
    Quote Originally Posted by vr6dubny View Post
    I use 2% lanthanated for everything. But the difference is very nominal. You can make them all work. If you're having issues with your weld appearance, it's almost definitely something else.
  21. #1871
    Manchester, N.H.
    96 332IS 6466 turbo
    I don't know, my phone doesn't take very good pics, so probably really blurry. But, this was messing around with that e3 tungsten stuff.
    1996 332IS
    Built 3.2
  22. #1872
    Sep 2009
    Syracuse, NY
    Those look good to my untrained eyes. My issue is most definitely lack of practice and knowledge.
  23. #1873
    Apr 2006
    Minnesota eh?
    86 325es
    Needs more heat or to slow down at the start. The penetration is good at the end when the part was heat soaked. I use a fixed amperage and just change my speed to control penetration
  24. #1874
    Mar 2012
    Renton, Wa
    98 m3
    Id guess slow down and smaller faster dabs.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  25. #1875
    Apr 2012
    Peoria , AZ
    2002 325i
    Has anyone here welded a DBW throttle body? I was talking to my fabricator about welding an elbow along with a vangen clamp onto it but he’s worried about the DBW electronics of the E46 throttle body.
