Page 70 of 80 FirstFirst ... 20456061626364656667686970717273747576777879 ... LastLast
Results 1,726 to 1,750 of 1976
Thread: Forced Induction Section Fabrication Thread
  1. #1726
    Dec 2008
    Earth
    none
  2. #1727
    DeWitt, Michigan
    '97 540i/6, '97 328i
  3. #1728
    Dec 2004
    Milford,CT
    95 M3
  4. #1729
    Vancouver, B.C., Canada
    '97 M3
    What car/engine is that?
  5. #1730
    Dec 2004
    Milford,CT
    95 M3
    Quote Originally Posted by chikinhed View Post
    https://www.bimmerforums.com/forum/s...LS-Turbo-build
  6. #1731
    Minneapolis,MN
    2003 M5, 2014 535i
    V8 headers I fabricated recently.
    2003 M5 LSx l 6 Spd Manual l 4.10 LSD
    Build Thread
    The chassis must always be regarded as a means to an end and never as an end itself
  7. #1732
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    ^damn!
  8. #1733
    DeWitt, Michigan
  9. #1734
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by Schitzo View Post
    V8 headers I did recently.
    Are those LS E36 fitment?
  10. #1735
    DeWitt, Michigan
  11. #1736
    Apr 2006
    Minnesota eh?
    86 325es
    Not my most elegant creation but it was effective. I needed to change the valve springs on my 5.9 cummins today but my spring compressor was to small to fit on the head
  12. #1737
    Sep 2008
    Toronto, ON
    6465 328ti
    Reinforced my 6 speed brace kinda copying chikinhed. I've welded better. Priority was getting the car back together lol
  13. #1738
    DeWitt, Michigan
    Fantastic problem solving and overall "rigged-ness"! Thanks for posting that!!
  14. #1739
    A house
    '86 325e, '14 VW EPA
    Since my powersteering is now all AN with a sealed container, the need for cooling is extra important since if it can't ooze out of the bottle, it'll blow out the rack seals. Knocked this guy out last night, pretty cool how comfortable I'm getting with doing this kind of work, only took a few hrs even though I made it fancier than I had to with the hex tanks
  15. #1740
    Apr 2006
    Minnesota eh?
    86 325es
    Its really fun when you don't have to look for something thats actually made to fit your car when you can just buy anything and make it fit or just make stuff completely from scratch. Pretty soon making stuff is the hobby and the car just facilitates that. I could never afford anything made for the car so I had to make everything.
  16. #1741
    A house
    It's fun but it's also just... possible! Learning to fabricate was like waking up out of the Matrix, it took my hobby to an entirely different world, rather than incrementally changing it. Now I'm just limited by my imagination. Before, it would always be a question of whether I could find something to bolt on or if I could afford to pay someone to make it for me. I can get a generic racing part, go see what it'll take to fit, and get on it. Rather than hoping it'll fit, trying, and if it doesn't, give up.
  17. #1742
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Indeed! I cannot imagine my life without a milling machine, lathe (both are small, entry-level import stuff) and a variety of welding machine/processes.
    Regardless of the task at hand, when you encounter an obstacle, usually within 20-30 minutes, you've made the perfect- (ly acceptable/functional...) tool to continue with the job at hand.
    Sometimes I'm more self-satisfied with the tools I've made to complete a job, than with the job itself.
  18. #1743
    DeWitt, Michigan
    I keep feeling like I need a lathe, but I don't know what size to get, and they are kind of damn expensive...
  19. #1744
    A house
    Quote Originally Posted by tptrsn View Post
    Check out bidspotter.com there are always CNC shops and other shops going under and you can get lathes and mills for DIRT cheap (I'm talking a limo sized lathe for 600 bucks). And it's usually really good stuff, cast iron 60s-80s shit that will last FOREVER. Hell I've witnessed large 4 axis HAAS CNCs go for under 10 grand routinely.
    If I had room in my garage and didn't have a friend with a good sized lathe and mill, I would have had both long ago.
  20. #1745
    DeWitt, Michigan
  21. #1746
    Manchester, N.H.
    96 332IS 6466 turbo
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  22. #1747
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    Had to put my turbo build on hold due to lack of motivation/slight depression due to annoyance and assholes. Been working on my Jeep instead. Finally finished my front winch bumper and now I'm doing the rear bumper with tire carrier.
    Some random hardware from ACE to build the hinge for the tire carrier.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
  23. #1748
    A house
    Quote Originally Posted by TheJuggernaut View Post
    Just to wrap this up, the manifold's done other than some finishing touches like pressure reference bungs. Super happy with how it turned out. Due to the size of the throttle body (length) I had to change my plans of keeping the TB at the side like stock and moved it to the front. Still happy with how it looks, so relieved that I managed to pull it off, don't even care if it ends up making less power than stock :P
  24. #1749
    DeWitt, Michigan
  25. #1750
    Apr 2006
    Minnesota eh?
    86 325es
    Showoff!
