Page 69 of 80 FirstFirst ... 1944596061626364656667686970717273747576777879 ... LastLast
Results 1,701 to 1,725 of 1976
Thread: Forced Induction Section Fabrication Thread
  1. #1701
    Mar 2012
    Renton, Wa
    98 m3
    Looking good dude! Youve made quick progress
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  2. #1702
    Sep 2002
    USA
    BMWs
    Not super pretty, and I didn't have any dimensions to go from (and didn't bother with a picture lol), but I made this for my wife this afternoon. It's a mount that's used for a TRX fitness system:
    TRX mount by Jon Kensy, on Flickr
    I made my center hole a little large for the plasma circle cutter, so I got a couple steps in the diameter while cutting, but meh, not critical. Minimal dross. I can't complain for a hand cut circle out of 1/4". 3/8" rod bent free hand. Was going to swap to the small torch and 360 weld the rods but then realized I already overkilled it.
    The manufactured part is $40 - $45 and made of like sheet metal... nah thanks. Next up is some powder coating once she lets me know the color!
  3. #1703
    A house
    '86 325e, '14 VW EPA
    Quote Originally Posted by vollosso View Post
    Thanks man, yeah my retirement plans are progressing well.
    Quote Originally Posted by 5mall5nail5 View Post
    I'm definitely getting a 625 this year. I need a proper compressor first but the thick stainless work has made me miss my plasma cutter. It was just an ebay china one but it got the job done and would have saved me several effed up carbide blades.
  4. #1704
    Sep 2002
    USA
    BMWs
    Quote Originally Posted by TheJuggernaut View Post
    Yeah the 625 is a serious machine for the money. It ripped through this 1/4" 1018 with no issues - well, except for my steadiness. I deliberated for a while gouging or piercing to start the circle and then said screw it and just started the hole attachment with the drag tip - not even a flinch.
  5. #1705
    Mar 2012
    Renton, Wa
    98 m3
    Cool as always jon.
    I could definitely do fabrication as a retirement plan hah.
    1989 535i - sold
  6. #1706
    Bellingham, WA
    e30
    Quote Originally Posted by PEI330Ci View Post
    What design limitation of the OEM spindles did you find?
    Not an argumentative question, just pure curiosity.
    One huge advantage is you can drop the mounting points for the LCA and tie rods 20mm to help correct the poor roll center location and bump steer while lowered.
    Also you could make a spindle out of steel with some nice pocketing and reduce the excess. Lower weight and more strength for threads to bite into and not a brittle material. Aluminum suddenly snaps....steel bends making failures much less severe. Just food for thought!
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  7. #1707
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by wazzu70 View Post
    I like you're thinking. I was of the same mind. But could we not just raise the bearing mount/spindle to take care of the geometry? I am currently using the SLR Speed Roll center correction kit which provides about 28mm of roll center and bump steer correction. It also does a nice job of speeding up the steering a bunch, and I boosted that some more with a Z3 steering rack!!
  8. #1708
    Bellingham, WA
    e30
    Raising the spindle is the same thing assuming the strut tube connection moves up the same amount. If you just move the spindle without the strut mount then i don't think you get the gains in roll center correction. Its been a long time since I did any RC calcs
    -Nick
    91 E30 M42 on VEMS
  9. #1709
    A house
    Started the manifold. Flange done, started measuring the runners
    Also did some more work on the expansion tank. Mounted the catch can. Just need the connecting line, and to add the pneumatic 90's with the clear tube to show if there's anything in the catch
  10. #1710
    Jul 2005
    PEI, Canada
    2001 330i
    Solid work!
    These make me want to buy a TIG (even more...)
    Drooling over tools:
    Drill press with coolant feed
    Plasma
    TIG
  11. #1711
    Vancouver, B.C., Canada
    '97 M3
    Jug, how much was all the manifold bits?
  12. #1712
    A house
    Quote Originally Posted by chikinhed View Post
    The equivalent of 700 US shipped to Canadia
  13. #1713
    '97 M3
    Did it come with the TB & TB flange?
  14. #1714
    A house
    Did it come with the TB & flange?
    No, that's one of the reasons I am doing this, I get to do it my way. I'm using a K-Tuned 90mm TB Mustang 5.0 fitment. Made right here in the GTA, really nice piece.
    But PPF has everything you'd need to finish it, incl TBs, fuel rails etc.
  15. #1715
    Bellingham, WA
    e30
    Nice work Mr. Juggernaut! Excited to see how this works out.
    -Nick
    91 E30 M42 on VEMS
  16. #1716
    A house
    I should probably update my thread at some point but for now there's so much I have done and have to do I'll just keep sharing some of the fab stuff.
    Finished the motor mounts, moving the engine back 0.3" to give the drysump mandrel a little breathing room.
    The oil pan is for an E36 so even being low profile, it didn't clear the crossmember and the steering rack had to be moved forward, but all good now.
    Before the engine can go in I need to make the intake up to the plenum to take advantage of the convenience. The only hard part with the PPF kit is that the billet flange is oval while the bends are generic round tubing. I thought about it and made a crushing jig out of a large round pipe. Tried it on a piece of scrap and it worked so well I made one runner. Looks like I'm in business, 5 more then I can stick it all together. Ended here as I was getting tired and wanted to end on a high
  17. #1717
    Mar 2012
    Renton, Wa
    98 m3
    Niiice.
    I have a similar jig for exhaust work
    1989 535i - sold
  18. #1718
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    I could build a nice table but this is really tempting.... Besides after time and materials I feel like you could get close to that price trying to reproduce something with all of the options. Some have been sold in the $900 range I'm told.
    https://store.snapon.com/MIG-Welders...k-P818845.aspx Plus there's room for 2 tanks so I can get a personal MIG later and have it all in one place.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
  19. #1719
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by somebody5788 View Post
    I built a large table with 2x2 square and 1/4" plate for like (iirc)240$ and 3-4 hours.
    1989 535i - sold
  20. #1720
    SW Florida
    99-01 M Cpe & Rdts, X5M
    When we moved to our current (final...?) location, I wanted nice, fast/easy and not overly expensive; five (5) years ago, I bought one of these for around $1k. Looks like the list price is about double that now, but I'm sure you can shop around for online bargains (relatively speaking).
    I have my Miller Dynasty 200DX & Spectrum 625 (older/larger than the same 625 of today) and Argon bottle on it. The MIG (Millermatic 252) & bottle are on their own (built in) rig, and the spot-welder is also stand-alone.
    The welding shield is still in the box, since I work alone. I did buy a second set of casters though, since I didn't want it to sag in the middle, and I';m not about to run the adjusters down to the floor every time I move it.
  21. #1721
    A house
    The flange part is done, next just need to mount the fuel rail then wait until the engine's in the car to figure out the plenum dimensions.
  22. #1722
    Mar 2012
    Renton, Wa
    98 m3
    Dont you love aluminum? No back purging!
    1989 535i - sold
  23. #1723
    A house
    Yeah but it's "pleasant" in its own way
  24. #1724
    Bellingham, WA
    e30
    Looks nice juggernaut!
    -Nick
    91 E30 M42 on VEMS
  25. #1725
    DeWitt, Michigan
    '97 540i/6, '97 328i
