Tri mix is the best gas for stainless MIG, but other mixes work ok too. I use 308LSi 0.023 wire for 16 GA. I welded my entire 3" exhaust with it and it came out pretty decent.
Getting the buzz sound perfect by adjusting heat and speed on some scraps is the key
Bought a mill, made some fuel rails..
Finally made some time again for my car and welded some fancy dumps.
1989 535i - sold
1999 M3 Tiag/Dove - sold
How much for the fuel rails?
Sent from my SM-G935V using Tapatalk
1989 535i - sold
Finishing up my exhaust. First fabrication project. Built with a cordless Dremel, sawzall, and mig welder.
https://imgur.com/eHQzGnm
Was buttoning up my engine last night then went to surf the internet. Got bored and went to make my power steering reservoir. That's what happens when I'm left home alone with metal and a welder
Nice, but your dog is obviously not impressed with your welding antics.
No the corgis give zero f*cks. Why is the stupid human awake?
Watch out with the fixed cap on the PS. The factory cap is vented (which is why the original res is gross all the time) because the PS fluid gets hot, expands, vapor, etc. I ran my fixed cap one for a while and kept pushing out the rubber seal on the lid. I should get back to that project Nothing a 1/16" drill bit can't fix!
Tisk tisk.. theres a little wave in the middle colby.
1989 535i - sold
Inside
That's medical grade stuff right there!
Damn all you guys, mostly TheJuggernaut...
Stuff happened and I picked up an Lincoln 180 mig pak and a Eastwood tig 200 both for dirt cheap....I haven't mig welded in like 9 years but I'm completely new to tig welding...it's pretty awesome. Will post pics of boogers
It's all over for you now
i bought something new..
1989 535i - sold
1989 535i - sold
Nice back scratcher....
1989 535i - sold
