Page 65 of 80 FirstFirst ... 1540555657585960616263646566676869707172737475 ... LastLast
Results 1,601 to 1,625 of 1976
Thread: Forced Induction Section Fabrication Thread
  1. #1601
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by somebody5788 View Post
    80 fpm is too fast? It has 3 speeds 80 to 200 fpm
    Oh shoot i shoulda clicked the link. The vertical saw is too fast. That combo horizontal/vertical is the right speed.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  2. #1602
    Apr 2015
    Tennessee
    1998 BMW 328i
    Got my Mig supplies today. The guy at my local airgas said for mig welding stainless i should use 100% argon gas and a .030 ER308/308L wire. So thats what i got. Sound right?
  3. #1603
    Manchester, N.H.
    96 332IS 6466 turbo
    Maybe next round get Tri-mix for mig welding stainless.
    100% argon is for tig the majority of the time.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  4. #1604
    Apr 2015
    Tennessee
    1998 BMW 328i
    Good to know. Next round will be cheaper. $20 for a refill or $120 for a tank. Dann son. I still ended up buying two tanks. One for stainless and one for mild.
  5. #1605
    Apr 2006
    Minnesota eh?
    86 325es
    I have mig welded stainless and mild with 100% argon and it works like shit in both.
  6. #1606
    Apr 2015
    Tennessee
    1998 BMW 328i
    Well I made my first welds today. Probably should have started with something other than the reinforcement plates for the rear subframe. But it's been done. I just stitched it, so I figure I can go back over and redo it if need be. Also I think I should have spent twice as long cleaning. Take a look at these beads and tell me how I can improve. Thanks.
  7. #1607
    Apr 2006
    Minnesota eh?
    86 325es
    It would help alot if you had a Co2 argon mix. With pure argon it doesn't penetrate.
  8. #1608
    Apr 2015
    Tennessee
    1998 BMW 328i
    Those welds were made with a 75%/25% Co2 argon mix. Wire speed was about 35/100, Voltage was 4/5, gas feed was at about 20-25 psi. Wire used was er70s-6 .030 inch
  9. #1609
    Manchester, N.H.
    96 332IS 6466 turbo
    You really need to clean down to bare steel before welding. Here is a pic of the prep I did before welding those reinforcements in. It makes all the difference.
    1996 332IS
    Built 3.2
  10. #1610
    Apr 2015
    Tennessee
    1998 BMW 328i
    Yeah i kinda figured my prep work was shitty. Do you think i should redo it? Or will mine hold?
  11. #1611
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by XnWarden View Post
    It will hold. Or clean better, and stitch another section. Turn the wire feed down and heat up.
    1996 332IS
    Built 3.2
  12. #1612
    Apr 2015
    Tennessee
    1998 BMW 328i
    Thanks for the input. Ill touch it up a lil. Welding overhead from your back sucks so much compared to sitting or standing and welding down. Any tips for getting a good torch angle?
  13. #1613
    Apr 2006
    Minnesota eh?
    86 325es
    the right ratio of amperage and wire speed is really critical with mig. Play with it on a piece of scrap to dial it in first. I agree that more amperage is needed.
  14. #1614
    Jun 2004
    The D, MI
    97 M3, 98 328i, 13 Cruze
    One more point to add..
    Lots of the strength from a sheet metal reinforcement like this comes from the rosette weld. You missed every single one of them on every plate.. You should really fill those in.
  15. #1615
    Vancouver, B.C., Canada
    '97 M3
    Rosette weld: A type of circular weld created by making a hole in one section of a tube or blind channel and joining it to a second piece inserted inside. Also known as a rosette weld.
    The holes in the plates get filled in with weld, connecting the plates to the body.
  16. #1616
    Apr 2015
    Tennessee
    1998 BMW 328i
    Quote Originally Posted by chikinhed View Post
    Gotcha, thanks for clarifying. Ill weld in those holes.
  17. #1617
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Quote Originally Posted by Kevin325i View Post
    Visual aids, and going one step further, to reach the heavier gauge panel above the thin sheetmetal (E-46 M3 Touring)l:
    All paint ground off and hit with a coat of Copperweld (which works great, but despite efforts to clean tip/tube, clogs up to be useless the next time you try to use it; I'll try another can in a few years, to see if they've improved it...)
    I seal-weld around the entire plate, as well as the plug-weld, to prevent any moisture from getting between the panels.
    Surface ground flat and primed
    Seams sealed.
    Prep for and application of rubberized textured undercoating.
    Match factory E-coat color with PPG paint.
    You're welcome to view the whole album to see an M3 trunkfloor assembly being fitted to this E-46 Touring (so the S-54 M3's exhaust could be fitted.
  18. #1618
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by Randy Forbes View Post
    That there is baller to the n'th degree!!
  19. #1619
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    So, this Harbor Freight Band Saw is AMAZING!!!!!! Finished the hot side piping up, the cuts were so perfect that I mostly just fusion welded everything with only a little filler in a couple spots.
    So I do realize my welds are a little too gray, at this point that's fine as I really didn't want to have a bright polished pipe under the hood. I will probably get it powder coated with some sort of textured finish. That being said this is technically my first real project TIG welding and the most SS experience I've had before was a few practice lines on a plate. I think I did ok for being so new to it.
    IMG_20170327_175649305_HDR.jpg IMG_20170327_192859749.jpg IMG_20170327_192911520.jpg
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
  20. #1620
    UT
    98 M3/4/5
    some master welders in this thread
    98 Estoril ///M3 4/6
    S54 swap CSL
  21. #1621
    Manchester, N.H.
    96 332IS 6466 turbo
    <img src="https://www.bimmerforums.com/forum/attachment.php?attachmentid=596427"/> <img src="https://www.bimmerforums.com/forum/attachment.php?attachmentid=596428"/> <img src="https://www.bimmerforums.com/forum/attachment.php?attachmentid=596429"/>
    The gray will be either too much heat or not enough gas coverage.
    Stainless steel is a "get in, get out" situation.
    Pipe like that only needs 50-60amps to fusion weld, 10-15cfm argon . if you pulse with the pedal, or set the machine to pulse or will keep the heat down a little. Or take your time and skip around from tack to tack.
    Good job !
    1996 332IS
    Built 3.2
  22. #1622
    Jan 2006
    Chicago, IL
    2003 330i ZHP
    Link to said saw?
  23. #1623
    Nov 2008
    Indiana
    Quote Originally Posted by boostd4 View Post
    Link to said saw?
    http://www.harborfreight.com/horizon...saw-93762.html
    First thing is clean out the gearbox and replace the oil. Then just properly adjust the blade using a square against the table. Once it's setup right it's good to go. I've been using the blade it came with on 309SS without any issues so far. Will upgrade to a starrett blade later.
  24. #1624
    DeWitt, Michigan
    '97 540i/6, '97 328i
    For a regular guy, who isn't an instagram showoff welder (yet ), those welds look great!
  25. #1625
    A house
    '86 325e, '14 VW EPA
    Pulsing will help but I wouldn't use it to fix this problem. Pulsing should be used to improve good technique not cover bad. With stainless it's critical not to linger. Use more heat than you think you need and get moving, fast. Also make sure you have good gas coverage. If your machine allows it, try turning up the pre-flow. Using a gas lens helps a lot too, I like the Furick FUPA or sometimes even the Weldtec Megaflo. Beware that these lenses require a lot more flow to work properly (25cfh for the Furick, 30+ for the Megaflo).
    It also probably means you're not backpurging. Probably not a huge deal for a charge pipe but if you're going to do stainless work on anything load bearing, backpurging is critical with stainless welding or you compromise it significantly. If you have black "sugar" on the back of the weld, that part of the weld will lose the corrosion resistance and will corrode and crack in time.
    One tip I recently picked up for welding stainless structures where back purging is not practical, like boxed structures (I'm making a tubular structure), this is the saviour. On the youtubes they say you have to use methanol but it's not true, that's only if you have to meet mil spec. Otherwise it works just as well with Isopropyl.
    http://www.solarflux.com/Pages/Productinfo.html
