Page 3 of 80 FirstFirst 123456789101112132853 ... LastLast
Results 51 to 75 of 1976
Thread: Forced Induction Section Fabrication Thread
  1. #51
    UK
    E34+ RF900 streetfighter
    Otis for that manifold is it a case of trial and error for the piececs between the head flange and the 3-1 collectors. I mean do you try a piece and then trim it if needed and try it again Or do you have templates/jigs for each of the pieces already.
    Its a 3 dimensional jigsaw.
    Welding the runners onto a 3-1 collector seems doable but I'll never get how someone welds the inside of the last runner onto a 6-1 collector, theres no room and the welding torch doesnt look that dainty Whats the trick to that?
    E3.4
  2. #52
    Suffolk, VA
    99 Mcoupe|12 X5D|11 335D
    All of it....
    Amazing DIY work!! You have access to some awesome tooling to help innovate.
  3. #53
    Sep 2002
    USA
    BMWs
    Quote Originally Posted by 5271990 View Post
    Gas lens, WP-9 torch w/ small back cap, stick the tungsten out far (because of gas lens). Use a large nozzle, 1/16" tungsten
  4. #54
    Bellingham, WA
    e30
    Cool stuff Someguy2800!
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  5. #55
    Feb 2008
    Denver, CO USA
    Swapped e-Dirty
    Little sum'n sum'n we are working on as a winter project....
    ar design stage 1 turbo kit - 11.7 @ 127mph 12psi of boost..... 5300ft elevation E36 S50 stock long block w/ARP
    sales@ardesign.info | tel. 303.351.3515| www.ardesign.info
    Powering some of the world's fastest BMWs
  6. #56
    Boostville 08723
    Turbo M50 E30, 95 M3
    Ever see a valve cover and coil wires melt because the turbo was to close to it? I have. This does not compute.
    85' Turbo M50 E30 | 95' M3 Nitrous, Coilovers, DJ Autos, UUC SSK
  7. #57
    Feb 2008
    Denver, CO USA
    Swapped e-Dirty
    Thermal wrap + we are flipping coil packs.
  8. #58
    Apr 2006
    Minnesota eh?
    86 325es
    here are a few more that I don't have pictures of
    this is how I prefer to file piston rings
    clamps into the bench vise
    simple rod bolt stretch gauge
    this tool I made for moching up a roll cage. You slide pieces of pvc pipe on the ends and a bolt goes through the center of the two pieces with a wing nut on the backside. they can be adjusted to any angle and the pcv tube slide in and out to change length. This way you can play with fitment as much as you want. Once you get it where you want, lock it down and take measurments. I thought about getting these injection molded and selling them.
    This is a hoist I built to go in my garage. Printed out of ABS plastic. I calculated a safe load rating of 1000 lbs. If I made this out of a different material it could be made with a safe load rating of up to 3000 lbs without making it any thicker.
    It rides between two 2x6's in the rafters
    beats the shit out of a cherry picker
    86 325es, 2.8L m50, S472sxe, MS3pro Ultimate, e85, solid rear axle, 4 link, spool, TH400 trans, Protorque converter, 28x10.5w slicks, zip ties
    Best = 9.43 @ 149.15 mph, 1.30 60 foot 28 psi boost
  9. #59
    Vancouver, B.C., Canada
    '97 M3
    I use to use a come along as an engine hoist back in the day. Lag hooks into beams can hold a lot of weight. I like that yours has som side to side action.
    Sent from my GTX3582R
  10. #60
    Aug 2003
    San Diego,CA,USA
    1997 Turbo M3 Coupe
    Can I just say that I LOVE THIS FOCKING THREAD!
    ...Stay tuned for more. I have a bunch of other stuff I already threw away and more yet to be built. My current project is to 3d print an instrument cluster to bolt in the stock position and hold my aftermarket gauges.
    I was a fan and then you had to break out the gunsmith shite!
    Quote Originally Posted by cragg56 View Post
    Any details on how you "mold" two "larger" diameter pipes at the divided flange? Realize that is not in the picture you have here, but you would eventually need to get there. That was the one thing I have been curious about.
    +1
    I am very curious as to what the engineers/physicists say about the diameter of the runner after the 3-1 for proper scavenge/etc.
    Where have I been? Astral projecting.
    Quote Originally Posted by jszy25 View Post
    Get drunk with Mike Radowski they said, it'll be fun they said...A broken toe, the worst hangover known to man, and bite marks in my arm said otherwise
  11. #61
    Apr 2006
    Minnesota eh?
    86 325es
    thanks cam! just ordered my tig
  12. #62
    Sep 2002
    USA
    BMWs
    Which did you get?
  13. #63
    air, dirt, fire, water
    95M3 92525iT 78810 95525
  14. #64
    RI, USA
    crazy
    welding
    Ever wonder how Mike R. Gets those muscles on his eye brows and forehead....... I weld things up so people can lift them up and put them down. It gives you the strength to drive a force fed BMW
  15. #65
    NY
    skateboard
    Quote Originally Posted by dc47a View Post
    ever wonder how mike r. Gets those muscles on his eye brows and forehead....... I weld things up so people can lift them up and put them down. It gives you the strength to drive a force fed bmw
    OmA
    ― George Orwell
  16. #66
    Jul 2012
    E21 Legion
    500whp 10.5@133mph
    jig for cutting collectors...
    ended up becoming this!
    cant wait to make my next one for the E21.
  17. #67
    Quote Originally Posted by DC47A View Post
    I weld things up
    OK,
    but what is it you're welding? dumbells?
    Share some of your ideas, skills, practices, failures, stories, etc
  18. #68
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by 5mall5nail5 View Post
    Which did you get?
    Everlast 185. I have no money and they offered me a great deal. They are coming out with a update in 3 weeks so I pre ordered that. They threw in a pedal, a 110V kit, and a 17 torch for 850 shipped. Those are normally extra. Promised the wife I will make it pay for itself, so looks like I'm looking for fab work. Anyone want a shortened 9 inch with disc brakes!
  19. #69
    Sep 2002
    USA
    BMWs
    Nice - Everlast kind of worries me and their pedal setup is so weird. Their pedal has 0 - 100% amperage all the time. Not sure I could get used to that.
    Good luck and let us know how she works out. I know the guy on weldingtipsandtricks uses them from time to time with great results. The only thing that sucks is their support.
  20. #70
    Dicktone Limo
    so jelly. you guys are jerks.
  21. #71
    Apr 2006
    Minnesota eh?
    86 325es
    yeah I've heard that as well. If you want more resolution for low amperage you can also run them on 110V. that will give you approximately 0-100 amps at the pedal. I would like to get a diversion 180 but the money isn't there. They have a 5 year waranty but I guess I will have to see how much yelling and arm twisting is involved.
  22. #72
    Bellingham, WA
    e30
    Talking
    Quote Originally Posted by ar design View Post
    That turbine orientation makes sense in a cramped e36 engine bay. Interested to see how it works out.
    Perry, please give an update on how you like the welder.
    Has anyone used the Eastwood TIG? Obviously not top tier quality, but their stuff is usually decent.
    -Nick
    91 E30 M42 on VEMS
  23. #73
    Sep 2002
    USA
    BMWs
    Quote Originally Posted by wazzu70
    I haven't used the eastwood tig but I thought about picking one up before I got mine
    Sent from my Galaxy S 3 using BF.com
  24. #74
    Apr 2006
    Minnesota eh?
    86 325es
    It will be about a month wait before I get the everlast. I do have a eastwood 135 mig, which I used for all the fabrication on my car. It is actually a pretty nice little unit. Weld quality is great, nice stable arc and consistant feed. It is also quite powerful. Below is a pic I snapped about 30 secounds after finishing a weld when I was fabricating my frame rail. This is on two 3/16 plates. You can also see the penetration from the weld on the side, which was done from the inside of the tube. The supplied gun, clamp, and regulator are all very nice. I have had a couple quality issues. The tip shield the unit cam with are garbage. I threw them in the trash on the first day and rused the ones from my old welder. Also there was a shielding gas leak inside the unit so I had to remove the side covers and fix that. I drained two tanks of gas through it because I left the regulator on before fixing the leak. Also lately the tip has started to stay electofied even without the trigger pressed which is very annoying. I will be sending it back for warranty once I get the tig. I have about 15 lbs of wire through it so far.
    Overall, it is a very well performing unit, but cheap. If I could do it again I would not buy it. I would try to find a used miller 135 or hobart handler 140, which are both excellent 110v units, and can be outfitted with spool guns.
  25. #75
    baltimore,md
    97 m3
    I asked if you could do this for me already, have you changed your mind?
