For the pedal, just get the thermal arc pedal specifically for the 186. I got mine from IOC (Indiana Oxygen Comp) I think. Cheapest price on google shopping, free shipping. It was ~$180.
For the torch, a WP-9 has a small body and small consumables:
http://www.ebay.com/itm/12-WP9-Tig-W...item27d39ba8ac
They also have WP-17s (small body, large consumables) for $100 for the 12' as well. It's $30 more for a flex head(I've heard they can sometimes break).
The stock torch is a WP-26 - it's a freaking beast... but it does come with 4 different thumb controls if you didn't want to use the pedal.
That's what she said.
― George Orwell
My manifolds powering 8sec and over 1000rwp cars
Home of the highest HP stock M30 in the world 550rwhp/622rwtq
1/4 mile---> 9.81 @138 C4 Auto
10.08 in car vid --->https://youtu.be/OiinFhUomjg
Dyno vid... http://www.youtube.com/watch?v=C7aM7..._order&list=UL
I'm surprised that you are still finding ways of organizing the pipe with smoother bends within the engine compartment.
I just googled an article that talked about 3D printing a design in order to test flow prior to fabbing a prototype. Are you using a computer to simulate/design the manifolds at this point or do you look at it and say "I think that could be smoother and still close to equal length if I bent it that way" and then test the airflow afterwards?
97 BMW M3 (s52b32) - VF-Supercharger kit ( Vortech V2-SQ supercharger, 32 pound injectors, VF tuning ), VDO/LeatherZ Gauge Kit (Oil Temp, Oil Pressure, and Boost), UUC Motorwerks RSC36 Exhaust, Stainless Steel 6-2 Exhaust Headers, Bilstein Sports, Rear Adjustable Camber bushings, Wheel Spacers 10mm in front 25mm in back, Uprated Clutch, UUC Shift Knob, Short Shifter and Clutch Stop, Cross Brace, Mason Engineering front strut bar, Contour Wheels, Euro Ellipsoid (Angel Eyes) HID Headlights, braided steel brake lines, aluminum thermostat housing, mishimoto aluminum radiator and silicone hoses and a partridge in a pear tree
Looks like another beautiful work of art!
And if you ever need that thing tested..
I see Vband
Follow my builds on youtube and IG.
www.youtube.com/thenameskam
@thenameskam on IG
Love the Vband entrance Otis!
By any chance can you measure the ID of the Vband turbine flange?
Nice work Otis. Is this going to be for a twin turbo set up?
WOT
Thanks a ton Otis!
Thanks, the 2" diameter is equivalent is x-sectional area as a T3 open flange, however should flow more being round. I assume there is a larger v-band housing as well to compete with the T4?
War Eagle!
WOT
The flex heads do break eventually if you move them around often enough.... Dont see why they are so expensive for you guys.. we buy em in for $15~ each for wp 17 and wp 26 sizes.
They are just twisted copper tubes inside.... the copper tube eventually fatigues and breaks when you move them too much. Ill grab a photo next time I replace a broken one and cut it open.
Colby what'd you use to cut the intersecting hole
OLD
E30
636whp
1/4 mile: 10.91@144.38
http://www.youtube.com/watch?v=L_f7fUVqblI
NEW BUILD
335d
520whp
635wtq
120.51mph trap speed
Guess who picked up a TIG welder couple weeks ago...
This guy.
Eastwood Pro TIG 200
