I like where YOU'RE coming from,
(though I agree with Otis...I've never heard or seen reports of failures)
the ONE good reason I can think of for a flex spot
is to make REinstallation as easy as the first time.
After heat cycles,
do the metals start to shift a bit, making these FOUR (4) piece puzzles (manifold, turbo, DP & WG) a bit of a tight fit.
I noticed that putting my 666/MAXpsi puzzle back together took some nudging after the heat cycles. I remember thinking, "Golly, I wish one of these pipes had a flex fitting." Was I simply having a difficult moment or do the 4 piece puzzle shift a little?
*I actually use the word "golly" in my thought processes*
Pm'd
OLD
E30
636whp
1/4 mile: 10.91@144.38
http://www.youtube.com/watch?v=L_f7fUVqblI
NEW BUILD
335d
520whp
635wtq
120.51mph trap speed
Stop it. LolOriginally Posted by RK-Tunes
Follow my builds on youtube and IG.
www.youtube.com/thenameskam
@thenameskam on IG
I fabbed up this motor mount arm using mild steel, tigged the section that bolts to the block and migged the gussets. I normally mig mild steel, but tig not so much I used 70S2 steel rod. Is there a different type rod used for mild steel?
Made it to fit a 4" intake.
My manifolds powering 8sec and over 1000rwp cars
Home of the highest HP stock M30 in the world 550rwhp/622rwtq
1/4 mile---> 9.81 @138 C4 Auto
10.08 in car vid --->https://youtu.be/OiinFhUomjg
Dyno vid... http://www.youtube.com/watch?v=C7aM7..._order&list=UL
^^you my friend need a tube bender. i would mimic the triangle gusset on the other cut/angled part also. When I have to angle square tube, I don't cut the outside part, instead I cut a V out of the inside, that way you keep the metal intact on the outside corner. I should get off my arse and build these. I have a JD2 tube bender collecting dust in my garage. Welds look great!
Got a new welder today for the shop. Left the Diversion 165 at home.
Miller SyncroWave 200, picked it up for $1500 with the bottle & a new torch head from the guys across the street. Used for maybe 15 hours max, been sitting in their shop since they stopped custom work. Cleaned it up with some degreaser and it looks new.
'02 E39 530i/5sp Topaz Blue/Black Interior - MegaSquirt3x - Garrett GTX3582R turbo - E85 fuel - Apex FL-5 - 265/295 tires - Custom Porsche Brembo BBK - 600whp @ 22 PSI
'15 E84 X1 35i M Sport Alpine White/Coral Red Interior - H&R Sports & Bilstein B6 - Velgen VMB5 - 265/305 tires - ETS FMIC - MPI Charge pipe & DME Flash - 3.5" down pipe
Lucky!!!
Sent from my iPhone 5 using BF.com
This is my signature....
Nice Jack - but darn, the transformer machines are hugeeeee lol
Thermal Arc 186 is looking pretty sweet...
and now the OTHER side...so it looks like this?
Quick vid of something I am working on:
[ame]http://vimeo.com/54826152[/ame]
I love machines.
97 BMW M3 (s52b32) - VF-Supercharger kit ( Vortech V2-SQ supercharger, 32 pound injectors, VF tuning ), VDO/LeatherZ Gauge Kit (Oil Temp, Oil Pressure, and Boost), UUC Motorwerks RSC36 Exhaust, Stainless Steel 6-2 Exhaust Headers, Bilstein Sports, Rear Adjustable Camber bushings, Wheel Spacers 10mm in front 25mm in back, Uprated Clutch, UUC Shift Knob, Short Shifter and Clutch Stop, Cross Brace, Mason Engineering front strut bar, Contour Wheels, Euro Ellipsoid (Angel Eyes) HID Headlights, braided steel brake lines, aluminum thermostat housing, mishimoto aluminum radiator and silicone hoses and a partridge in a pear tree
My friend has a vise with a bent up old handle that he's trying to restore. So...
[ame]http://vimeo.com/54987324[/ame]
Finished up the handle for my buddies vise:
Vise Handle by Jon Kensy, on Flickr
Vise handle by Jon Kensy, on Flickr
Not bad all in all
Looks nice. I have bent a couple of vise handles.
