Page 1 of 80 12345678910112651 ... LastLast
Results 1 to 25 of 1976
Thread: Forced Induction Section Fabrication Thread
    Sep 2002
    USA
    BMWs
    So why not a fabrication thread to see what everyone is working on or has worked on?
    With all the manifold chat it'd be interesting to see what guys are using for fixtures and such and share what we're working on.
    If you've got something you're proud of post it up! Try and keep the bashing to a minimum!
    I made a pipe beveler using a bosch router, a carbide bit, and some steel plate:
    Pipe Beveler Project by Jon Kensy, on Flickr
    Very useful for welding thicker wall schedule pipe.
    Feb 2008
    Denver, CO USA
    Swapped e-Dirty
    Don't make me show you up rookie.
    ar design stage 1 turbo kit - 11.7 @ 127mph 12psi of boost..... 5300ft elevation E36 S50 stock long block w/ARP
    sales@ardesign.info | tel. 303.351.3515| www.ardesign.info
    Powering some of the world's fastest BMWs
    Sep 2002
    USA
    BMWs
    Quote Originally Posted by ar design View Post
    Show me up sun that's what the threads for... sharing projies.
    Feb 2008
    Denver, CO USA
    Swapped e-Dirty
    Sorry, what was that? Hard to hear you when you are ALL THE WAY OVER THERE IN THE KITCHEN! (Thanks for that Mike )
    Prepping parts for a batch of downpipes....
    Moar plz?
    Completed parts....
    Manifolds
    Equal length manifold for a Porsche 996TT
    996TT Exhaust
    Sep 2002
    USA
    BMWs
    ^^^ Sick!
    Get some vids of you laying beads! I need to take note.
    Still learning here.
    After troubleshooting some boring database crap yesterday I went home to make this antenna mount bracket for a project at work:
    Antenna Mount by Jon Kensy, on Flickr
    IT by day, metal gluing by night. It was fun though.
    Aug 2009
    Dakota County, Minnesota
    1997 BMW 328i
    Ooooh. Shiny things.
    I like this thread
    Dallas, TX
    98' M3/4/6T, Jeep XJ
    Wow. I hate life now.
    bonita springs fl
    oloa 318ti
    THAT PORSCHE STUFF IS SO SICK... it would be cool to have a subforum for fabrication. so i can ask questions like what is a good entry level tig welder that i can weld stainless and alum?
    one lap of america s52/gt35r 318ti..500whp 533wtq 19psi via rk-tunes....
    follow me on instagram @whitecord1
    Sep 2002
    USA
    BMWs
    Quote Originally Posted by whitecord View Post
    I've asked for a fab sub-forum a number of times. I figured a thread would give us some access at least.
    Feb 2008
    Denver, CO USA
    Swapped e-Dirty
    The Miller Diversion welders are a GREAT product.
    Sep 2008
    Wilmington NC
    96 Oil Gobbler
    I bought an Everlast power pro 205 and absolutely love it. Tig ac/dc, stick and plasma cutter.
    Bellingham, WA
    e30
    Awesome thread idea!
    I dont have anything to add at this time unfortunately.
    I have a fab question though. I only have a MIG, not optimal, but its what I have. Has anyone used stainless wire in their MIG? I have read with stainless wire and a different gas mix (Helium based) you can get decent results.
    I figure I will try it at least and see how it goes.
    Jon do you have the Diversion 180?
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
    Louisville, KY
    turbo m3
    Quote Originally Posted by 5mall5nail5
    ^^^ Sick!
    Nice Jon!
    My question is why do you want/need that pipe beveler?
    Sent from my iPhone 5 using BF.com
    This is my signature....
    Sep 2002
    USA
    BMWs
    Quote Originally Posted by wazzu70 View Post
    I run stainless in my Hobart 140 all the time. To have proper shielding yes you should have tri-mix gas. It's not very expensive. I keep a bottle of tri-mix on hand just in case I need to mig stainless. Tri-mix is getting more expensive though due to the helium shortage.
    Yep, I have a Diversion 180 but as you can see in my antenna bracket pic I have modified the hose/torch.
    Quote Originally Posted by BadBoostedBmwM3 View Post
    Nice Jon!
    Pipe beveler is very useful for schedule pipe because it's so thick. If you look at the pic AR Design posted of the "Equal Lenght 996TT" manifold you'll notice each piece of schedule pipe has a bevel. This helps for penetration.
    With a nice bevel you can get a autogenous root pass without needing to backpurge much:
    Autogenous Weld Root Pass by Jon Kensy, on Flickr
    You would follow that up with a cap pass.
    Vancouver, B.C., Canada
    '97 M3
    +1 to the Miller Diversion 180
    Sent from my GTX3582R
    Miami, FL
    '02 530i & '15 X1 35i
    Yes they are, I love my 165, but I have to get a SyncroWave or a Dynasty for the shop, the little guy isn't up for welding for hours lol
    '02 E39 530i/5sp Topaz Blue/Black Interior - MegaSquirt3x - Garrett GTX3582R turbo - E85 fuel - Apex FL-5 - 265/295 tires - Custom Porsche Brembo BBK - 600whp @ 22 PSI
    '15 E84 X1 35i M Sport Alpine White/Coral Red Interior - H&R Sports & Bilstein B6 - Velgen VMB5 - 265/305 tires - ETS FMIC - MPI Charge pipe & DME Flash - 3.5" down pipe
    Sep 2002
    USA
    BMWs
    Quote Originally Posted by JackEatsEmoKids View Post
    Yep for shop use it comes down to duty cycle.
    Miami, FL
    Quote Originally Posted by 5mall5nail5 View Post
    Yup plus the torch gets nice and warm lol btw where did you source the red flex hose for yours? I'm sick of mine, likes to go its own ways.
    Sep 2002
    USA
    BMWs
    Its a weldcraft ultra flex hose. Its amazing. You need an adapter for inside the diversion. There's a guy on a 4x4 site that makes them. Search google I will try and post a link later.
    Miami, FL
    You the man, thanks!
    Feb 2008
    Denver, CO USA
    Swapped e-Dirty
    Water cooled torches will change your life.
    It says made in China right on it Kennesey. Stop trying to take credit for the hard work of others.
    Sep 2002
    USA
    BMWs
    If the machine can only do 20% DC at hot amps it ain't worth water cooling.
    Quit frontin' sun
    Feb 2008
    Denver, CO USA
    Swapped e-Dirty
    I am sorry your machine is inadequate, sir.
    Bellingham, WA
    e30
    Jon, thanks for the info on MIG and stainless! Very helpful.
    -Nick
    91 E30 M42 on VEMS
    Sep 2002
    USA
    BMWs
    I make the best of what I've got!
    No prob post up some results once you get going.
